Введение
Having issues turning on and off the Vtech Learning Tunes Karaoke? Follow this guide to solve the problem.
Выберете то, что вам нужно
To remove the battery door, loosen the 4mm screw using a Flathead screwdriver.
Remove the six 9.5 mm Phillips #2 screws.
Remove the six 6.0 mm Phillips #2 screws.
Gently pull up on the rear panel.
Gently place the back panel underneath the top panel with the tops facing each other, as shown in the picture.
