Введение
If the VTech VM3245 will not switch on, the battery may need to be replaced. The information below specifically states how to remove the battery and replace it with a new one. The only tools needed include a Phillips #00 screwdriver, Jimmy, and one opening pick. You will not have any difficult steps, but remove the front cover of the device attentively.
Выберете то, что вам нужно
Turn the monitor on its back, and remove the two 8 mm Phillips #0 case screws.
Use the iFixit Jimmy tool to begin removing the face of the monitor.
Once the screen has been separated, lift it from the case.
Remove the four 8 mm Phillips #00 screws from the bracket that secures the battery.
Remove the bracket.
Gently remove the battery from its location.
Carefully disconnect the bundled cable connector from the circuit board.
1 Комментарий к руководству
What is the battery that needs to be replaced called?
