Valve Index Controller Right Index Controller Battery Replacement
Выберете то, что вам нужно
  1. Valve Index Controller Right Index Controller Battery Replacement, Open controller grip: шаг 1, изображение 1 из 3 Valve Index Controller Right Index Controller Battery Replacement, Open controller grip: шаг 1, изображение 2 из 3 Valve Index Controller Right Index Controller Battery Replacement, Open controller grip: шаг 1, изображение 3 из 3
    • Use either a guitar pick or thin sheet of metal, pry open the grip sensing panel.
    • There are five plastic clips around and under the grip sensor. Use the tool to pry up around the sensor to lift it out of the handle.
    • Tuck in starting closer to the top of the controller, and apply force to lift the panel away. Move further around the sensor, using a second tool if needed to keep the grip sensor off of the handle.
    • With gentle force, the propped grip can be removed from the main handle.
    • Be careful when removing! There is a ribbon cable underneath the panel, tucked between the circuit board and outer housing, and attached to the circuit board buried inside. Make sure the cable doesn't detach.
    Спросите у FixBot
    Добавить комментарий
  2. Valve Index Controller Right Index Controller Battery Replacement, Detach ribbon cables: шаг 2, изображение 1 из 3 Valve Index Controller Right Index Controller Battery Replacement, Detach ribbon cables: шаг 2, изображение 2 из 3 Valve Index Controller Right Index Controller Battery Replacement, Detach ribbon cables: шаг 2, изображение 3 из 3
    • There are two ribbon cables in the way of the battery that must be removed.
    • Each ribbon cable is fragile, and pinching either one incorrectly can rip it, causing grip functions to not work anymore.
    • The smaller ribbon cable is wrapped around the top of the battery and inserted into the circuit board. Use tweezers to free the cable and detach it from the board.
    • The larger ribbon cable is attached from the back of the grip panel to a wider connector on the circuit board, held down by a black connector lid.
    • Use a thin, flat spudger to lift the connector lid, then pull it out from the circuit board to disconnect the grip panel from the conntroller.
    • Do NOT use a sharp metal tool to lift the connector. Doing so can risk puncturing the battery, causing a fire!
    Спросите у FixBot
  3. Valve Index Controller Right Index Controller Battery Replacement, Unscrew the housing: шаг 3, изображение 1 из 3 Valve Index Controller Right Index Controller Battery Replacement, Unscrew the housing: шаг 3, изображение 2 из 3 Valve Index Controller Right Index Controller Battery Replacement, Unscrew the housing: шаг 3, изображение 3 из 3
    • Unscrew one (1) Torx T9 screw on the side top.
    • Unscrew four (4) Torx T5 screws around the side of the housing.
    • The Torx screwdriver needs a long, narrow extension; the screws are in deep inserts.
    • After all five (5) screws are removed, use a rigid spudger to pry open the battery housing from the controller handle.
    • The controller cannot be fully disassembled; there is significant cement-like adhesive on the bottom and around the knuckle ring of the controller. There's no known way to open the controller further without destroying it. Only pry it open far enough to expose and extract the battery.
    Спросите у FixBot
  4. Valve Index Controller Right Index Controller Battery Replacement, Remove the adhesive, then the battery: шаг 4, изображение 1 из 3 Valve Index Controller Right Index Controller Battery Replacement, Remove the adhesive, then the battery: шаг 4, изображение 2 из 3 Valve Index Controller Right Index Controller Battery Replacement, Remove the adhesive, then the battery: шаг 4, изображение 3 из 3
    • The battery is securely adhesed to the housing; use a hairdryer or hot air gun at moderate heat for 10 seconds to loosen the adhesive.
    • Use a plastic guitar pick or spudger to separate the adhesive from the plastic housing. There should be less resistance; if it's still not budging, re-warm the area and try again.
    • Do NOT use a sharp, metal object; this will risk puncturing the battery and causing a fire!
    • This adhesive is very tough, lasting several years. Be patient cutting through.
    • Once the adhesive is freed, separate the controller apart more to handle the battery, and remove it from the main handle.
    • The battery is plugged into the printed circuit board via an MX2 connector.
    • Be careful when removing! The inside chamber holding the battery has several sharp corners that could puncture the battery, and cause a fire!
    Спросите у FixBot
  5. Valve Index Controller Right Index Controller Battery Replacement, Transfer the rubberized part.: шаг 5, изображение 1 из 3 Valve Index Controller Right Index Controller Battery Replacement, Transfer the rubberized part.: шаг 5, изображение 2 из 3 Valve Index Controller Right Index Controller Battery Replacement, Transfer the rubberized part.: шаг 5, изображение 3 из 3
    • There is a rubber strip stuck on one side of the OEM battery, protecting the printed circuit board from the battery,.
    • SAVE THIS PIECE. It is a crucial component to prevent battery damage.
    • Separate it from the white housing, and replace it onto the replacement battery.
    • Install the new battery, rubberized side facing the printed circuit board, and apply a replacement adhesive strip on the other side of the battery to keep it stuck on the outer frame.
    • When ready, unplug the old battery from the circuit board, and install the new battery's cable.
    Спросите у FixBot
  6. Valve Index Controller Right Index Controller Battery Replacement, Insert replacement battery: шаг 6, изображение 1 из 2 Valve Index Controller Right Index Controller Battery Replacement, Insert replacement battery: шаг 6, изображение 2 из 2
    • Insert the battery connector onto the connector on the printed circuit board, and press down onto the board.
    • Bend the battery wires to arc the connection route better.
    • The manufacturer may have glued down the battery cable onto the circuit board's connector. If the connector is not secure, reinforce with electrical tape or pressure on top of the connector.
    • Now, test that the controller can be powered via USB for a couple minutes, then unplug and attempt to turn on the controller.
    • Once the connection is established, place thick double-sided adhesive onto the replacement battery opposite the rubberized part, and insert the battery into its chamber on the handle.
    • Carefully insert! There are sharp corners around the handle, which could puncture the battery and cause a fire!
    • The battery wires should be nested on the side of the battery, not over, under, or in the way of the housing edges.
    Спросите у FixBot
  7. Valve Index Controller Right Index Controller Battery Replacement, Reinsert the ribbon cables: шаг 7, изображение 1 из 3 Valve Index Controller Right Index Controller Battery Replacement, Reinsert the ribbon cables: шаг 7, изображение 2 из 3 Valve Index Controller Right Index Controller Battery Replacement, Reinsert the ribbon cables: шаг 7, изображение 3 из 3
    • Start with the wider ribbon cable from the grip panel. Position the cable end properly by hand or with plastic, dull tweezers, then insert it into the connector under the open black lid.
    • Do NOT use a sharp, metal object to attempt to insert the cable or close the lid; this could risk puncturing the battery and causing a fire!
    • Once the cable is inside the connector, pull down the black lid to close it. The cable should be securely in place.
    • Tuck in the excess of the ribbon cable underneath the printed circuit board, slightly rolling it into the pocket underneath.
    • Do NOT score or sharply bend this cable, as this could damage it and break the grip function of the controller.
    • Use tweezers to wrap the smaller ribbon cable around the battery, and insert it into its connector closer to the top of the printed circuit board.
    Спросите у FixBot
Заключение
Once the ribbon cables are reinserted, insert the 5 screws back into their holes, and clamp the controller together, ensuring the cables are away from any clips and creases.
10 человек успешно провели ремонт по этому руководству.
Damian
Участник с: 08/31/18
1 795 Репутация
Автор 7 руководств
7 Комментарии к руководству
The link for the battery part leads to a missing page as of 4/18/2025
Jevan - Ответить Поделиться
Searching the part name seems to get results with the same model number, for instance : https://www.aliexpress.com/item/10050046...
IneffaWolf - Ответить Поделиться
I tried to change battery, but frankly it is a nightmare to do it. Just to remove one screw in the deep hole was a challenge and I had to use driller.
For second controller I bought the Mako iFixit set and was after some attempts successful. To remove battery I did not need the hot air, after 6 years the glue was not in good condition anymore. But the connector was glued very well and I broke it in both controllers, it is just too fragile.
The controllers are made to be not repaired. I found out, that they work even without battery, connected with USB cable, they are just getting warmer.
So I gave up and will use them wired, as I am not capable to solder the battery.
Deathcoltd - Ответить Поделиться
All right... Notes from having done this today:
1. I'd add that the controller's battery chamber doesn't fully separate from the main body during this operation - you're just spreading the two halves to get at the battery.
2. The black clip on the palm-sensor's ribbon connector is super-fragile and easy to permanently detach... if it does, you're going to need tape or hot glue to reattach the ribbon cable.
3. If your battery connector has hot glue on it, you're going to need isopropyl alcohol, tweezers, and patience to remove it before you can remove the connector from the board.
4. The replacement batteries... I purchased a couple of Cameron Sino batteries from Amazon. The leads connecting to the batteries are also fragile. I'd recommend taping over the leads and end of the battery to create some re-enforcement.
5. I'd test charging and powering up at several stages - first connection, part way through re-assembly, and again post re-assembly. It's easy to get an imperfect connection on the battery.
Craig Harwood - Ответить Поделиться
I'll add a note about point 1 to the end of Step 3. I've already mentioned that it's impossible to fully disassemble the controller without destroying it in the beginning, but it's worth reinforcing.
Damian - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 35
За последние 7 дней: 244
За последние 30 дней: 1,085
За всё время: 13,355
