Verizon Ellipsis 8 Disassembly
Выберете то, что вам нужно
  1. Verizon Ellipsis 8 Disassembly, Power Down and Remove Sim Card: шаг 1, изображение 1 из 1
    Инструмент, используемый на этом этапе:
    • Open SIM card flap and remove SIM card. Use a pair of tweezers to get the SIM card out.
    Спросите у FixBot
    Добавить комментарий
  2. Verizon Ellipsis 8 Disassembly, Remove Rear Cover: шаг 2, изображение 1 из 1
    • Use a guitar pick to open the cover of the tablet. For most effective results, start at the corner of the tablet and continue.
    • **BE SURE NOT TO DAMAGE THE SIM CARD OR SD CARD SLOTS**
    Спросите у FixBot
  3. Verizon Ellipsis 8 Disassembly, Rear Cover Removal Cont.: шаг 3, изображение 1 из 2 Verizon Ellipsis 8 Disassembly, Rear Cover Removal Cont.: шаг 3, изображение 2 из 2
    • Continue opening the cover now using a metal spudger and wiggle it to pry the cover open.
    • You can look at the picture of the rear cover to see where the snaps are located.
    Спросите у FixBot
  4. Verizon Ellipsis 8 Disassembly, Remove Battery: шаг 4, изображение 1 из 1
    • Remove the screws attached to the circuit board on the battery using a Phillips 00 screw head and remove the battery.
    • There was no adhesive on the back of the battery, just along the sides.
    Спросите у FixBot
  5. Verizon Ellipsis 8 Disassembly, Remove Ribbon Cables and Smaller Circuit Boards: шаг 5, изображение 1 из 3 Verizon Ellipsis 8 Disassembly, Remove Ribbon Cables and Smaller Circuit Boards: шаг 5, изображение 2 из 3 Verizon Ellipsis 8 Disassembly, Remove Ribbon Cables and Smaller Circuit Boards: шаг 5, изображение 3 из 3
    • Be careful when removing the ribbon cables as there is adhesive on the back of them. To remove the cables flip up the rear part of the connector to slide the cable out - *gently*.
    • The USB Charging Connector and the Antenna Board both have adhesive on the back. Remove the screws and carefully lift up on the boards to remove them.
    • **Be careful with the antenna cable!**
    Спросите у FixBot
  6. Verizon Ellipsis 8 Disassembly, Remove Mainboard & Speaker: шаг 6, изображение 1 из 1
    • Remove the 5 screws holding the Mainboard and Speakers in to place. *One of the screws is under the ribbon cable*
    • There was no adhesive holding this board in and the whole assembly lifted out as one piece.
    Спросите у FixBot
Заключение
31 человек успешно провели ремонт по этому руководству.
SMcC21985
Участник с: 11/10/15
1 271 Репутация
Автор 2 руководств
4 Комментарии к руководству
what size screws are thoze i need to get some i lost some
stacy - Ответить Поделиться
My tablet is on, when I press to Open , it doesn't do anything
Gladys Lockhart - Ответить Поделиться
My tablet is on working, when I press to get is frozen, it doesn't let me in
Статистика просмотров:
За последние 24 часов: 4
За последние 7 дней: 19
За последние 30 дней: 80
За всё время: 21,336
