Введение
What you can expect from this guide is a step by step process on how to remove the LCD display screen on a Verizon Ellipsis Jetpack MHS800L.
Выберете то, что вам нужно
Инструмент, используемый на этом этапе:Phillips #00 Screwdriver$5.49
With the device on its back and the label facing you, remove the rubber screw cover on the top left corner of the device.
Under the rubber circle, remove the 1.25 mm screw using a Phillips #00 Screwdriver.
Инструмент, используемый на этом этапе:iFixit Opening Picks (Set of 6)$4.95
Use a plastic pick at the seams and pry open the case.
Once you have the case off of your device gently pull your battery away from the device.
Инструмент, используемый на этом этапе:Tweezers$4.99
With a pair of Tweezers remove the yellow tape covering the battery wires.
After removing the tape you may use the Tweezers to remove the wiring harness from the circuit board.
Locate the LCD screen cable and unlatch the harness connection form the circuit board.
Using the Tweezers gently coax the display data cable out of circuit board connector.
Gently insert the Tweezers underneath the LCD screen and lift the LCD screen off of the circuit board.
Еще один человек закончил это руководство.
