Visual Land Prestige Pro 7D Camera Replacement
Выберете то, что вам нужно
  1. Visual Land Prestige Pro 7D Camera Replacement, Back Panel: шаг 1, изображение 1 из 1
    • Unscrew the two 4.0mm Phillips head screws found near the ports at the bottom of the device using a PH #00 screwdriver.
    Спросите у FixBot
    Добавить комментарий
  2. Visual Land Prestige Pro 7D Camera Replacement: шаг 2, изображение 1 из 1
    • Be careful when taking the back panel off. The speaker is connected to both the front and back panels, and may get pulled out if you are not gentle when lifting the back panel away.
    • Slide the plastic prying tool in between the front and back panel and pry them apart on all 4 sides.
    • It may be easiest to start on one of the sides, and work your way around the device. The bottom, with the ports, is the most difficult side and can be saved for last.
    • There are small latches that make this difficult. Moderate force may be required to separate the two panels.
    Спросите у FixBot
  3. Visual Land Prestige Pro 7D Camera Replacement, Front-Facing Camera: шаг 3, изображение 1 из 2 Visual Land Prestige Pro 7D Camera Replacement, Front-Facing Camera: шаг 3, изображение 2 из 2
    • Remove the black pad on the back of the camera by peeling it off.
    Спросите у FixBot
  4. Visual Land Prestige Pro 7D Camera Replacement: шаг 4, изображение 1 из 1
    • With the bottom of the device facing away from you, pull the camera out of its black housing.
    • The camera will come right out when you lift with your fingers.
    Спросите у FixBot
  5. Visual Land Prestige Pro 7D Camera Replacement: шаг 5, изображение 1 из 1
    Инструмент, используемый на этом этапе:
    • Use the tweezers to lift the grey connector, connecting the camera ribbon to the circuit board, up from the beige housing. It should rotate up, and allow you to slide the ribbon out from under the connector.
    Спросите у FixBot
Заключение
Brandon Kodama
Участник с: 10/17/14
229 Репутация
1 руководство автора
Команда
Cal Poly, Team 10-41, Amido Fall 2014 Участник Cal Poly, Team 10-41, Amido Fall 2014
CPSU-AMIDO-F14S10G41
4 членов
Автор 12 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 5
За последние 30 дней: 16
За всё время: 717
