Введение
This guide will help users replace their Vizio CT15 keyboard when the whole keyboard is not responding.
Выберете то, что вам нужно
Turn the laptop off and remove all power cables.
Remove the six Phillips #0 screws.
Pull the back cover off.
Use the plastic opening tool or your fingers to pry the battery up and pull it from the laptop.
Use the flat end of a spudger to lift up the black tab on the ZIF connector.
Pull the ribbon cables out of the ZIF connector.
Pull off the black strips of tape from the speaker wires and remove the speakers from the laptop.
Remove the four Philips #0 screws from the heatsink.
Pull up and out to remove the heatsink from the laptop.
Remove the eight Phillips #0 screws from the motherboard.
Lift the motherboard up and out to remove it from the laptop.
Use a metal spudger to carefully push the keyboard out of place.
Carefully flip the laptop over and pull the keyboard out.
3 человек успешно провели ремонт по этому руководству.
