Weed Whacker Line Replacement
  1. Weed Whacker Line Replacement, Line: шаг 1, изображение 1 из 3 Weed Whacker Line Replacement, Line: шаг 1, изображение 2 из 3 Weed Whacker Line Replacement, Line: шаг 1, изображение 3 из 3
    • Remove cutting line guard from weed whacker. This is usually attached by a wing-nut or a bolt and nut, so it can be removed either by hand or with the correct sized wrench.
    Спросите у FixBot
    Добавить комментарий
  2. Weed Whacker Line Replacement: шаг 2, изображение 1 из 1
    • Flip weed whacker upside down so that bottom of cutting piece is facing up.
    Спросите у FixBot
  3. Weed Whacker Line Replacement: шаг 3, изображение 1 из 1
    • There will be a bottom cap of the rotor setup that needs to be removed. In some models this will be held on with a nut and bolt fixture, but in many models there will be a circular cap that can be rotated counter clockwise for removal. Remove this piece in the manner necessary.
    Спросите у FixBot
  4. Weed Whacker Line Replacement: шаг 4, изображение 1 из 2 Weed Whacker Line Replacement: шаг 4, изображение 2 из 2
    • Once the bottom piece is removed, there will be another circular piece that may or may not have cutting line coiled around it. Remove this piece from the weed whacker.
    Спросите у FixBot
  5. Weed Whacker Line Replacement: шаг 5, изображение 1 из 2 Weed Whacker Line Replacement: шаг 5, изображение 2 из 2
    • There should be slots to coil cutting line around, with a hole in each for line to be anchored. If no line is coiled around the part, insert the end of about three feet of cutting line into each of the holes, and coil the cutting line snugly around the part, making sure that there are no tangles in the line.
    Спросите у FixBot
  6. Weed Whacker Line Replacement: шаг 6, изображение 1 из 1
    • If there are plastic tabs on the plastic part to hold the cutting line, insert each line into one these tabs. Leave approximately a foot of each line hanging out from the coils.
    Спросите у FixBot
  7. Weed Whacker Line Replacement: шаг 7, изображение 1 из 2 Weed Whacker Line Replacement: шаг 7, изображение 2 из 2
    • On the weed whacker rotor, there will be eyelets for the cutting line to be fed through. Feed each line through each of these eyelets, being careful not to let the line come uncoiled.
    Спросите у FixBot
  8. Weed Whacker Line Replacement: шаг 8, изображение 1 из 1
    • Replace the plastic piece with the cutting lines back onto the rotor, being sure that the coils remain in place, and the lines remain in place through the eyelets.
    Спросите у FixBot
  9. Weed Whacker Line Replacement: шаг 9, изображение 1 из 1
    • Replace the cap that was removed at the beginning of the assembly.
    Спросите у FixBot
  10. Weed Whacker Line Replacement: шаг 10, изображение 1 из 2 Weed Whacker Line Replacement: шаг 10, изображение 2 из 2
    • Replace the cutting line guard.
    Спросите у FixBot
Финишная прямая
2 человек успешно провели ремонт по этому руководству.
Hannah Akey
Участник с: 10/02/17
191 Репутация
1 руководство автора
Команда
Michigan Tech, Team S5-G10, Galliah Fall 2017 Участник Michigan Tech, Team S5-G10, Galliah Fall 2017
MTU-GALLIAH-F17S5G10
2 членов
Автор 1 руководств
1 Комментарий к руководству
It spins besept not with enough power to cut the grass why is
Mercedes Bush - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 5
За последние 30 дней: 28
За всё время: 1,093
