Введение
If your device is over heating you may need to replace your motor fan. This guide will show you how.
Выберете то, что вам нужно
While pressing the spindle lock button, unscrew the collet nut and remove it along with the brass collet.
To remove the front panel, pry the device apart while holding the device with the other hand.
The fan assembly is attached to the rotor beam, it can be disassembled to change the fan by simply pulling off the pieces.
2 человек успешно провели ремонт по этому руководству.
1 Комментарий к руководству
Donde puedo conseguir ese motor completo?
