Введение
If the device is not changing speed it may be because of a broken speed adjuster.
Выберете то, что вам нужно
While pressing the spindle lock button, unscrew the collet nut and remove it along with the brass collet.
To remove the front panel, pry the device apart while holding the device with the other hand.
Identify the screws.
Unscrew the two 3mm phillips PH2.
Phillips PH2
Flathead 2.5mm
2 человек успешно провели ремонт по этому руководству.
