Why Face ID Not Working After Repair
Видеообзор
  1. Why Face ID Not Working After Repair, Face ID System: шаг 1, изображение 1 из 2 Why Face ID Not Working After Repair, Face ID System: шаг 1, изображение 2 из 2
    • There are 8 components packed into the front of the phone. Infrared Camera; Flood Illuminator; Proximity Sensor; Ambient Light Sensor; Speaker; Microphone; Front Camera; Dot Projector;
    • The infrared camera, the dot projector and the front camera are located on the back glass assembly.
    • The flood illuminator, the proximity sensor, the ambient light sensor, the speaker and the microphone are located on the display assembly.
    • Please be careful when disassembling or repairing the phone. Damage of any component will cause Face ID failure.
    • Please be noted that there is a slot on the display assembly. When assembling the phone, the fold of the speaker flex cable should be placed correspondingly in the slot to prevent the cable from getting broken. Which will also result in the failure of Face ID.
    Спросите у FixBot
    Добавить комментарий
  2. Why Face ID Not Working After Repair, Disassemble The Flood Illuminator Module: шаг 2, изображение 1 из 1
    • We can see that there are many holes on the flood illuminator that are arranged in a matrix of 11×11.
    • The chip is connected to the circuit board with the help of gold wires.
    • Once water damaged, these holes can be blocked. And you will be faced up with Face ID failure.
    Спросите у FixBot
  3. Why Face ID Not Working After Repair, Chips On The Flood Illuminator Module: шаг 3, изображение 1 из 1
    • Chip 1 is an unencrypted chip.
    • Chip 2 is the flood illuminator. Chip 3 and Chip 4 are proximity sensors that are responsible for receiving and transmitting respectively.
    • Independent of each other, the three chips are indispensable.
    Спросите у FixBot
  4. Why Face ID Not Working After Repair, Disassemble The Dot Projector: шаг 4, изображение 1 из 1
    • The outer layer of the dot projector is sealed with resin and protected by metal welding techniques.
    • Pay attention to these welding points. They can easily fall off once the phone is dropped. And once off, they cannot be restored.
    • Once the dot projector has been detached, we can see a crystal that looks just like a diamond lens.
    • The infrared light is emitted from here. Then reflected by the crystal. Its projection range is determined by the lens afterwards.
    Спросите у FixBot
  5. Why Face ID Not Working After Repair, Internal Structure Of The Dot Projector: шаг 5, изображение 1 из 2 Why Face ID Not Working After Repair, Internal Structure Of The Dot Projector: шаг 5, изображение 2 из 2
    • The chip on the left is used to store data, whereas the chip on the right side acts just like a projector. We can see that there are thousands of dots arranged here. The infrared light is emitted from here.
    • Since necessary power supply is needed for chip on the right side to work normally, once water damaged, circuits here are most likely to get short. Which can also result in Face ID not working.
    • And please be noted that the chip is exposed without black adhesive seal. So it can be easily damaged once water-damaged or dropped. What’s more, it also can not be restored once damaged.
    Спросите у FixBot
  6. Why Face ID Not Working After Repair, The Crystal Part Of The Dot Projector: шаг 6, изображение 1 из 1
    • We can see that there is a concave lens and a convex lens on the crystal. And the two are made of glass. Once dropped, Face ID can also be affected.
    Спросите у FixBot
  7. Why Face ID Not Working After Repair, Face ID Fault-finding: шаг 7, изображение 1 из 1
    • Judging by what we have learned during the disassembling, main circuits of the Face ID are exposed. Once water damaged or exposed to a relatively humid environment, there might be electricity leakage or short-circuit problem that can result in Face ID failure.
    • What’s more, most of the Face ID parts are made of glass. Once dropped, Face ID is most likely to be unavailable.
    Спросите у FixBot
    • In summary, Face ID can be easily damaged and hard to be restored. Therefore, please be very careful in daily use. Make sure the phone is protected from water-damage or heavy falling. Repair technicians must exercise caution when repairing the logic board or replacing the display assembly.
    Спросите у FixBot
Финишная прямая
50 человек успешно провели ремонт по этому руководству.
Phryne
Участник с: 11/17/19
21 808 Репутация
Автор 18 руководств
15 Комментарии к руководству
Brilliant! keep up with your good work.
HAKU_LYU - Ответить Поделиться
Thanks for your support!
Phryne - Ответить Поделиться
I send my iPhone for repair bcos not able to activate but instead my Face ID has problems now
Vian - Ответить Поделиться
Face ID relevant flex cables might have been ripped-off or relevant components were knocked-off during phone disassembly.
Best information I found on web about Face ID Failure. Keep up the great work.
Pranav Hargotra - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 18
За последние 7 дней: 163
За последние 30 дней: 711
За всё время: 214,047
