Введение
To complete this guide, you will need precision accuracy and some elbow grease.
Pry off the backplate by inserting a spudger or plastic opening tool into each corner and popping them open.
Un-stick the battery from the motherboard assembly with the plastic opening tool.
Инструмент, используемый на этом этапе:Tweezers$4.99
Desolder the battery wires from the motherboard.
Remove each of the four 4 mm screws from the motherboard pictured to the left.
Use a Phillips #00 precision screwdriver.
Use the spudger to pry the instrument array from its plastic housing.
Slowly slide the spudger underneath the adhesive tape to un-sitck it.
Be careful not to harm the array of wires leading to this tape.
De-tatch the motherboard output wires from the screen using the tweezers.
Remove the charging pin holster.
Clamp on the end of the holster with the tweezers and twist until it becomes detached.
Repeat for the other side.
To reassemble your device, follow these instructions in reverse order. The charging pin holster needs to be soldered back into place.
Еще один человек закончил это руководство.
