Withings Smart Body Analyzer LCD Screen Replacement
Выберете то, что вам нужно
    1. Withings Smart Body Analyzer LCD Screen Replacement, Withings Smart Body Analyzer Disassembly: шаг 1, изображение 1 из 1
      • Push the battery door
      • Open the compartment
      • Gently remove the batteries from their designated positions
      • Place them aside, away from the reach of children
      Спросите у FixBot
      Добавить комментарий
    2. Withings Smart Body Analyzer LCD Screen Replacement: шаг 2, изображение 1 из 3 Withings Smart Body Analyzer LCD Screen Replacement: шаг 2, изображение 2 из 3 Withings Smart Body Analyzer LCD Screen Replacement: шаг 2, изображение 3 из 3
      • With caution, insert the plastic opening tools in between the disk and the glass face
      • It's a tight fit, so don't be afraid to apply a little bit of force
      • As soon as you hear a faint crackling sound, that means that the adhesive is budging out of place
      • Gently rotate the plastic spudger around the disk to get around the adhesive
      • Gently lift the metal disk
      • After the disk has been lifted, a wire and a small copper plate can be seen attached to the back of the disk
      • Carefully remove the wire and plate by peeling back the adhesive sticker that has been positioned around them
      Спросите у FixBot
    3. Withings Smart Body Analyzer LCD Screen Replacement: шаг 3, изображение 1 из 2 Withings Smart Body Analyzer LCD Screen Replacement: шаг 3, изображение 2 из 2
      • After all the above steps have been completed, proceed by removing the glass face
      • Carefully insert a plasic spudger in the small gap that exist in between the glass face and the plastic back
      • Run the plastic spudger all around the scale to increase the gap size
      • Place a plastic spudger in every corner, since the feet of the scale are also attached to the glass face using adhesive
      • Carefully insert the metal spudger underneath the adhesive that is located underneath the feet of the scale, and gently keep pushing until the adhesive is out of place
      • Repeat the above steps four times
      • After all the adhesives has been removed, gently lift the glass face off
      Спросите у FixBot
    1. Withings Smart Body Analyzer LCD Screen Replacement, LCD Screen: шаг 4, изображение 1 из 2 Withings Smart Body Analyzer LCD Screen Replacement, LCD Screen: шаг 4, изображение 2 из 2
      • After the tempered glass panel has been removed, the screen can be accessed and is connected by a ribbon cable via the circuit board.
      • Gently remove the wire from the circuit board by gently pushing downward and away from the screen, on the metal tab that connects the wire to the circuit board.
      Спросите у FixBot
    2. Withings Smart Body Analyzer LCD Screen Replacement: шаг 5, изображение 1 из 1
      • Using the Phillips screwdriver head, unscrew the two screws that hold the screen in place.
      Спросите у FixBot
    3. Withings Smart Body Analyzer LCD Screen Replacement: шаг 6, изображение 1 из 1
      • The screen should be free from all constraints and all that is left is to carefully lift and remove the screen.
      Спросите у FixBot
Заключение
2 человек успешно провели ремонт по этому руководству.
omar shehadi
Участник с: 03/22/17
219 Репутация
Автор 2 руководств
Команда
UMass Dartmouth, Team S4-G1, Julie Spring 2017 Участник UMass Dartmouth, Team S4-G1, Julie Spring 2017
UMASSD-JULIE-S17S4G1
4 членов
Автор 5 руководств
2 Комментарии к руководству
Where can I get a new LCD screen for replacement?
Putra Jaya - Ответить Поделиться
problem is that I didn´t find new LCD on the internet :-(
krwell - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 8
За последние 30 дней: 36
За всё время: 4,173
