Withings Smart Body Analyzer Pressure Sensor Replacement
Выберете то, что вам нужно
    1. Withings Smart Body Analyzer Pressure Sensor Replacement, Withings Smart Body Analyzer Disassembly: шаг 1, изображение 1 из 1
      • Push the battery door
      • Open the compartment
      • Gently remove the batteries from their designated positions
      • Place them aside, away from the reach of children
      Спросите у FixBot
      Добавить комментарий
    2. Withings Smart Body Analyzer Pressure Sensor Replacement: шаг 2, изображение 1 из 3 Withings Smart Body Analyzer Pressure Sensor Replacement: шаг 2, изображение 2 из 3 Withings Smart Body Analyzer Pressure Sensor Replacement: шаг 2, изображение 3 из 3
      • With caution, insert the plastic opening tools in between the disk and the glass face
      • It's a tight fit, so don't be afraid to apply a little bit of force
      • As soon as you hear a faint crackling sound, that means that the adhesive is budging out of place
      • Gently rotate the plastic spudger around the disk to get around the adhesive
      • Gently lift the metal disk
      • After the disk has been lifted, a wire and a small copper plate can be seen attached to the back of the disk
      • Carefully remove the wire and plate by peeling back the adhesive sticker that has been positioned around them
      Спросите у FixBot
    3. Withings Smart Body Analyzer Pressure Sensor Replacement: шаг 3, изображение 1 из 2 Withings Smart Body Analyzer Pressure Sensor Replacement: шаг 3, изображение 2 из 2
      • After all the above steps have been completed, proceed by removing the glass face
      • Carefully insert a plasic spudger in the small gap that exist in between the glass face and the plastic back
      • Run the plastic spudger all around the scale to increase the gap size
      • Place a plastic spudger in every corner, since the feet of the scale are also attached to the glass face using adhesive
      • Carefully insert the metal spudger underneath the adhesive that is located underneath the feet of the scale, and gently keep pushing until the adhesive is out of place
      • Repeat the above steps four times
      • After all the adhesives has been removed, gently lift the glass face off
      Спросите у FixBot
    1. Withings Smart Body Analyzer Pressure Sensor Replacement, Pressure Sensor: шаг 4, изображение 1 из 1
      • Notice the red and black wires connecting the circuit board to each of the pressure sensors.
      • Using a soldering iron and de-soldering braid, remove the soldered red and black wires from the circuit board
      Спросите у FixBot
    2. Withings Smart Body Analyzer Pressure Sensor Replacement: шаг 5, изображение 1 из 2 Withings Smart Body Analyzer Pressure Sensor Replacement: шаг 5, изображение 2 из 2
      • Use a Phillips-head screwdriver to remove the screw from the sensor. There will be two screws per sensor.
      Спросите у FixBot
    3. Withings Smart Body Analyzer Pressure Sensor Replacement: шаг 6, изображение 1 из 2 Withings Smart Body Analyzer Pressure Sensor Replacement: шаг 6, изображение 2 из 2
      • Remove any sensors you need and you are now ready to replace or repair depending on your needs.
      Спросите у FixBot
Заключение
Еще один человек закончил это руководство.
Ashley Dauphinee
Участник с: 03/22/17
323 Репутация
Автор 2 руководств
Команда
UMass Dartmouth, Team S4-G1, Julie Spring 2017 Участник UMass Dartmouth, Team S4-G1, Julie Spring 2017
UMASSD-JULIE-S17S4G1
4 членов
Автор 5 руководств
3 Комментарии к руководству
Where do I get those replacements?
karina - Ответить Поделиться
where can I buy pressure sensors?
Andrey Kolesov - Ответить Поделиться
The issue is not the pressure sensor, but a weak area within the foot.
Having taken my scales apart to repair them I found the the foot (pictured within the plastic ring above) has a metal disc in it, that is supported by a few weak plastic ribs that easily damage. I filled them in with Araldyte to create a firm level surface and all is good again.
As a design engineer who fault-finds all day, I would say this is either poor design (an oversight), or brilliant salesmanship (a weak point that allows Withings to sell more scales). Which is true? Only they know.
FlashingIcon - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 9
За последние 30 дней: 50
За всё время: 4,770
