Wooting 60HE Keycap Replacement
Выберете то, что вам нужно
    1. Wooting 60HE Keycap Replacement, Keycap: шаг 1, изображение 1 из 1
      • Use a small, soft bristle brush to remove small hairs or dust from the keyboard.
      • For this replacement, we will be replacing the "A" keycap.
      Спросите у FixBot
      Добавить комментарий
    2. Wooting 60HE Keycap Replacement: шаг 2, изображение 1 из 2 Wooting 60HE Keycap Replacement: шаг 2, изображение 2 из 2
      • Hook the two metal brackets of the keycap puller at a slight angle on the corners of the key.
      • Slightly tug upwards, and the key should come out smoothly. Place the key to the side.
      • It is essential to be gentle; excessive force can cause cracks or scratches on the key.
      Спросите у FixBot
    3. Wooting 60HE Keycap Replacement: шаг 3, изображение 1 из 1
      Инструмент, используемый на этом этапе:
      • Using tweezers, carefully extract debris from the exposed backboard of the keyboard.
      • Try to avoid the key nub, as it is lubricated, and outside contact can ruin it.
      Спросите у FixBot
    4. Wooting 60HE Keycap Replacement: шаг 4, изображение 1 из 1
      • Hold a multi-purpose electronics duster three inches away and at an angle from the exposed key.
      • Press the trigger in short bursts.
      • This will help get rid of any debris that you could not get from using your tweezers.
      Спросите у FixBot
    5. Wooting 60HE Keycap Replacement: шаг 5, изображение 1 из 2 Wooting 60HE Keycap Replacement: шаг 5, изображение 2 из 2
      • Place a cotton swab on a napkin and lightly coat the head of the swab with 70% isopropyl alcohol.
      Спросите у FixBot
    6. Wooting 60HE Keycap Replacement: шаг 6, изображение 1 из 1
      • Gently pat around the white backboard of the keyboard with the cotton swab.
      • This will help get rid of any built up residue, oils, or any possible spills that could have occurred in the past.
      • Isopropyl alcohol can strip the lubricant on the key, so put emphasis on dabbing the white backboard and not the key itself.
      Спросите у FixBot
    7. Wooting 60HE Keycap Replacement: шаг 7, изображение 1 из 3 Wooting 60HE Keycap Replacement: шаг 7, изображение 2 из 3 Wooting 60HE Keycap Replacement: шаг 7, изображение 3 из 3
      • Line the keycap in the upright position above the nub and press down lightly.
      • The key should slide back in place.
      Спросите у FixBot
Финишная прямая
Aryav Balia
Участник с: 10/25/23
157 Репутация
1 руководство автора
Команда
CSU Los Angeles, Team 1-1, Briggs Fall 2023 Участник CSU Los Angeles, Team 1-1, Briggs Fall 2023
CSULA-BRIGGS-F23S1G1
6 членов
Автор 11 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 6
За последние 7 дней: 19
За последние 30 дней: 61
За всё время: 1,636
