Xbox One S Hard Drive Assembly
Выберете то, что вам нужно
  1. Xbox One S Hard Drive Assembly, Case: шаг 1, изображение 1 из 1
    • Flip the Xbox One S so that the bottom of the case is facing upward.
    Спросите у FixBot
    Добавить комментарий
  2. Xbox One S Hard Drive Assembly: шаг 2, изображение 1 из 1
    • Begin by working at the case on the rear where the warranty sticker is located. Insert the plastic opening tool into the gap between the bottom of the case and the grated top side. Then find the clips in between that hold the case in place. Use the opening tool to pop the clips out. The best method is to pry the black case away from the bottom.
    • Use the opening tool to pop the clips out. The best method is to pry the black case away from the bottom.
    • You will hear clicking sounds when you are prying the case open. It may be fairly difficult to remove the bottom.
    • It's possible that the clips may break when you remove the bottom from the case.
    • We recommend starting at the back where the warranty sticker is located. Pry along the rear edge until all clips are free. From there do each side. When three sides are free start at the end of the front opposite the sync button. Be cautious and take your time and all should separate without any damage.
    Спросите у FixBot
  3. Xbox One S Hard Drive Assembly: шаг 3, изображение 1 из 1
    • Once all of the clips are opened, remove the bottom part of the case.
    Спросите у FixBot
  4. Xbox One S Hard Drive Assembly: шаг 4, изображение 1 из 2 Xbox One S Hard Drive Assembly: шаг 4, изображение 2 из 2
    • Use a T10 Torx screwdriver to remove the six green 50 mm long screws from the metal case labeled F1 through F6.
    Спросите у FixBot
  5. Xbox One S Hard Drive Assembly: шаг 5, изображение 1 из 2 Xbox One S Hard Drive Assembly: шаг 5, изображение 2 из 2
    • Gently separate the interior case from the white exterior case using the appropriate method.
    • Pry the white plastic sides outwards at the rear to separate from the plastic I/O shield.
    Спросите у FixBot
  6. Xbox One S Hard Drive Assembly, Interior Case Top Panel: шаг 6, изображение 1 из 1
    • Flip the interior case so it is fan side upward.
    Спросите у FixBot
  7. Xbox One S Hard Drive Assembly: шаг 7, изображение 1 из 1
    • To access the hardware within the casing, you can pop and lift the top panel of the casing. It should come right off.
    Спросите у FixBot
  8. Xbox One S Hard Drive Assembly, Hard Drive Assembly: шаг 8, изображение 1 из 2 Xbox One S Hard Drive Assembly, Hard Drive Assembly: шаг 8, изображение 2 из 2
    • To replace the hard drive, flip over the console and remove the two 10 mm T-10 Torx screws, C3 and C5, from the backside of the Xbox One S.
    • Some models may require C4 and C5.
    • This will allow the plastic casing surrounding the hard drive to become detached from the rest of the console.
    Спросите у FixBot
  9. Xbox One S Hard Drive Assembly: шаг 9, изображение 1 из 3 Xbox One S Hard Drive Assembly: шаг 9, изображение 2 из 3 Xbox One S Hard Drive Assembly: шаг 9, изображение 3 из 3
    • Gently disconnect the hard drive from the motherboard (at the two plastic connector bodies).
    Спросите у FixBot
Заключение
19 человек успешно провели ремонт по этому руководству.
Victoria Law
Участник с: 04/26/17
1 126 Репутация
Автор 3 руководств
Команда
Cal Poly, Team S22-G3, Livingston Spring 2017 Участник Cal Poly, Team S22-G3, Livingston Spring 2017
CPSU-LIVINGSTON-S17S22G3
4 членов
Автор 59 руководств
2 Комментарии к руководству
My F3 isn't coming out. The screwdriver isn't sitting tight like it is for the other ones. Any idea on how to fix that?
ben mccord - Ответить Поделиться
Where is the guide to the replacing of hardrive to a HDD 3.5 instead of 2.5, I thought I found it on here but I have not been able to locate it since.
awesomedaisy - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 4
За последние 7 дней: 42
За последние 30 дней: 209
За всё время: 16,021
