Xbox Series X Southbridge Board Replacement
Выберете то, что вам нужно
  1. Xbox Series X Southbridge Board Replacement, Uncover the back panel screws: шаг 1, изображение 1 из 2 Xbox Series X Southbridge Board Replacement, Uncover the back panel screws: шаг 1, изображение 2 из 2
    • Before you begin, completely power down and unplug all cables from your console.
    • Use a pair of tweezers to remove the sticker hiding the first screw on the back panel, near the base.
  2. Xbox Series X Southbridge Board Replacement: шаг 2, изображение 1 из 3 Xbox Series X Southbridge Board Replacement: шаг 2, изображение 2 из 3 Xbox Series X Southbridge Board Replacement: шаг 2, изображение 3 из 3
    • For cleaner removal, use an iOpener or hair dryer to heat the sticker.
    • Use a pair of blunt tweezers to peel back the large sticker on the back panel to reveal the second screw.
    • You only need to peel this sticker to where you can access the hidden screw. You don't need to pull it completely off.
    • Technically, these are tamper-evident stickers, but don't worry—Microsoft can't legally void your warranty, as long as you don't damage anything. Have fun!
  3. Xbox Series X Southbridge Board Replacement, Remove the back panel screws: шаг 3, изображение 1 из 1
    Инструмент, используемый на этом этапе:
    Magnetic Project Mat
    $19.95
    • Use a T8 Torx driver to remove the two 7.4 mm‑long screws securing the back panel.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your console.
  4. Xbox Series X Southbridge Board Replacement, Unclip the back panel: шаг 4, изображение 1 из 3 Xbox Series X Southbridge Board Replacement, Unclip the back panel: шаг 4, изображение 2 из 3 Xbox Series X Southbridge Board Replacement, Unclip the back panel: шаг 4, изображение 3 из 3
    • Insert the flat end of a spudger into the gap between the back panel and the shell, near the left side of the base.
    • Pry up the back panel to release it from the locking clips.
  5. Xbox Series X Southbridge Board Replacement: шаг 5, изображение 1 из 2 Xbox Series X Southbridge Board Replacement: шаг 5, изображение 2 из 2
    • Insert the flat end of a spudger into the gap between the back panel and the shell, near the right side of the base.
  6. Xbox Series X Southbridge Board Replacement, Remove the back panel: шаг 6, изображение 1 из 3 Xbox Series X Southbridge Board Replacement, Remove the back panel: шаг 6, изображение 2 из 3 Xbox Series X Southbridge Board Replacement, Remove the back panel: шаг 6, изображение 3 из 3
    • Grip the back panel at the opening you just created and pull it up and away from the shell to unclip the long edges.
    • During reassembly, press along the edges of the back panel to snap it into place.
  7. Xbox Series X Southbridge Board Replacement: шаг 7, изображение 1 из 3 Xbox Series X Southbridge Board Replacement: шаг 7, изображение 2 из 3 Xbox Series X Southbridge Board Replacement: шаг 7, изображение 3 из 3
    • The back panel slots into a gap at the top of the shell.
    • Tilt the back panel up and pull it away from the top edge of the shell to release it from the gap.
    • Remove the back panel.
  8. Xbox Series X Southbridge Board Replacement, Remove the fan screws: шаг 8, изображение 1 из 1
    • Use a T8 Torx driver to remove the three screws securing the fan to the center chassis:
    • One 10.5 mm pancake screw
    • Two 8.8 mm screws
  9. Xbox Series X Southbridge Board Replacement, Disconnect the fan cable: шаг 9, изображение 1 из 3 Xbox Series X Southbridge Board Replacement, Disconnect the fan cable: шаг 9, изображение 2 из 3 Xbox Series X Southbridge Board Replacement, Disconnect the fan cable: шаг 9, изображение 3 из 3
    • Use your fingers or a pair of blunt tweezers to grip the edges of the fan cable connector, and pull up to disconnect it from the center chassis.
    • Always pull cables by their connectors and not the wires themselves.
    • During reassembly, route the fan cable underneath its small cable guide on the fan housing so it doesn't interfere with the back panel.
  10. Xbox Series X Southbridge Board Replacement, Remove the fan: шаг 10, изображение 1 из 2 Xbox Series X Southbridge Board Replacement, Remove the fan: шаг 10, изображение 2 из 2
    • Slide the fan out of its slot to remove it.
    • During reinstallation, note that the fan can only be installed one way—make sure Master Chief is facing you.
    • If you're replacing the fan, a new fan might not include the plastic installation bracket, which is attached to the fan with four T10 Torx screws. This isn't pictured in this guide.
  11. Xbox Series X Southbridge Board Replacement, Unlatch the base: шаг 11, изображение 1 из 3 Xbox Series X Southbridge Board Replacement, Unlatch the base: шаг 11, изображение 2 из 3 Xbox Series X Southbridge Board Replacement, Unlatch the base: шаг 11, изображение 3 из 3
    • Use the flat end of a spudger to lift up on the locking tab holding the base to the shell.
  12. Xbox Series X Southbridge Board Replacement, Twist and remove the base: шаг 12, изображение 1 из 3 Xbox Series X Southbridge Board Replacement, Twist and remove the base: шаг 12, изображение 2 из 3 Xbox Series X Southbridge Board Replacement, Twist and remove the base: шаг 12, изображение 3 из 3
    • Grip the base and rotate it counterclockwise to unlock it from the shell.
    • You may need to hold the locking tab open while you get the base started.
    • Remove the base.
    • During reassembly, drop the base tabs into their holes on the shell and twist clockwise until the base snaps into the interior locking tab.
    • When locked in place, the "Hello from Seattle" line will be parallel with the device's sides.
  13. Xbox Series X Southbridge Board Replacement, Remove the optical drive screws: шаг 13, изображение 1 из 2 Xbox Series X Southbridge Board Replacement, Remove the optical drive screws: шаг 13, изображение 2 из 2
    • Use a T8 Torx driver to remove the two 8.8 mm screws securing the optical drive's vibration isolator to the shell: one on the base and one on the top of the isolator.
  14. Xbox Series X Southbridge Board Replacement, Remove the vibration isolator: шаг 14, изображение 1 из 3 Xbox Series X Southbridge Board Replacement, Remove the vibration isolator: шаг 14, изображение 2 из 3 Xbox Series X Southbridge Board Replacement, Remove the vibration isolator: шаг 14, изображение 3 из 3
    • Lift up the optical drive's vibration isolator to remove it.
    • The vibration isolator grips the sides of the optical drive with silicone pads, so you may need to "walk" the isolator off of the drive to slip it off each side.
    • During reassembly, ensure the vibration isolator is pushed down and around both edges of the optical drive, so it sits flush with the rest of the center chassis.
  15. Xbox Series X Southbridge Board Replacement, Disconnect the power and data cables: шаг 15, изображение 1 из 3 Xbox Series X Southbridge Board Replacement, Disconnect the power and data cables: шаг 15, изображение 2 из 3 Xbox Series X Southbridge Board Replacement, Disconnect the power and data cables: шаг 15, изображение 3 из 3
    • Use a pair of blunt tweezers to grip the edges of the optical drive power connector and pull up to disconnect it from the optical drive.
    • Use your fingers to pull up and disconnect the data cable from the optical drive.
  16. Xbox Series X Southbridge Board Replacement, Remove the optical drive: шаг 16, изображение 1 из 2 Xbox Series X Southbridge Board Replacement, Remove the optical drive: шаг 16, изображение 2 из 2
    • Grip the top edge of the optical drive and pull it out of its slot in the shell to remove it.
    • During reassembly, align the pegs on the bottom edge of the optical drive with the guide holes on the bottom of the shell.
    • If the drive is misaligned, the top vibration isolator will not be able to be installed correctly, and the disc reader will be misaligned with the front of the console.
  17. Xbox Series X Southbridge Board Replacement, Disconnect the USB port cable: шаг 17, изображение 1 из 3 Xbox Series X Southbridge Board Replacement, Disconnect the USB port cable: шаг 17, изображение 2 из 3 Xbox Series X Southbridge Board Replacement, Disconnect the USB port cable: шаг 17, изображение 3 из 3
    • The ribbon cables and their connectors are extremely fragile, so always open locking tabs gently and pull cables slowly.
    • Use the flat end of a spudger to flip open the metal locking tab on the USB port ribbon cable.
    • During reassembly, gently snap the metal locking tab back into place once the cable has been inserted.
  18. Xbox Series X Southbridge Board Replacement: шаг 18, изображение 1 из 2 Xbox Series X Southbridge Board Replacement: шаг 18, изображение 2 из 2
    • Use a pair of tweezers to pull up on the black plastic pull tab to disconnect the USB port cable.
    • Pull only on the pull tab, not the cable itself.
    • If the USB port cable feels adhered to the metal chassis, use an apply an iOpener or hair dryer to heat the cable. Depending on your model of Xbox, you may also need to slide an opening pick under the cable to separate the adhesive.
  19. Xbox Series X Southbridge Board Replacement, Disconnect the power button cable: шаг 19, изображение 1 из 3 Xbox Series X Southbridge Board Replacement, Disconnect the power button cable: шаг 19, изображение 2 из 3 Xbox Series X Southbridge Board Replacement, Disconnect the power button cable: шаг 19, изображение 3 из 3
    • Use the pointed end of a spudger to depress the metal tab on the side of the power button cable's board connector.
    • With the metal tab depressed, use a pair of tweezers to pull up on the pull tab to disconnect the power button cable from the center chassis.
    • Don't pull on the cable without depressing the metal tab, otherwise you risk damaging either the cable or the connector.
    • During reassembly, the cable should lightly "snap" into place when inserted.
  20. Xbox Series X Southbridge Board Replacement, Remove the chassis screws: шаг 20, изображение 1 из 1
    • Use a T8 Torx driver to remove the three 7.4 mm screws securing the center chassis assembly to the shell.
  21. Xbox Series X Southbridge Board Replacement, Peel up the USB port cable: шаг 21, изображение 1 из 2 Xbox Series X Southbridge Board Replacement, Peel up the USB port cable: шаг 21, изображение 2 из 2
    • Gently peel the taped USB port ribbon cable off of the heatsink.
    • Depending on your model of Xbox, the adhesive may be on the underside of the cable. If so, use an iOpener or hair dryer to heat the cable.
  22. Xbox Series X Southbridge Board Replacement, Remove the center chassis assembly: шаг 22, изображение 1 из 3 Xbox Series X Southbridge Board Replacement, Remove the center chassis assembly: шаг 22, изображение 2 из 3 Xbox Series X Southbridge Board Replacement, Remove the center chassis assembly: шаг 22, изображение 3 из 3
    • The center chassis is aligned to the shell with guide pegs. These pegs will need to slide out of their slots to allow the chassis to be lifted out.
    • Grip the center chassis and pull it towards the green fan grille at the top of the shell, uncoupling the guide pegs from the shell.
    • Lift out the center chassis assembly to remove it from the shell.
    • During reassembly, make sure neither of the ribbon cables get pinched as you lower the center chassis into the shell.
  23. Xbox Series X Southbridge Board Replacement, Unlatch the chassis strap: шаг 23, изображение 1 из 3 Xbox Series X Southbridge Board Replacement, Unlatch the chassis strap: шаг 23, изображение 2 из 3 Xbox Series X Southbridge Board Replacement, Unlatch the chassis strap: шаг 23, изображение 3 из 3
    • Unlatch the chassis strap from the right side of the power supply.
  24. Xbox Series X Southbridge Board Replacement: шаг 24, изображение 1 из 3 Xbox Series X Southbridge Board Replacement: шаг 24, изображение 2 из 3 Xbox Series X Southbridge Board Replacement: шаг 24, изображение 3 из 3
    • Pull the chassis strap over and off of the power supply.
    • Once the strap is off of the power supply, set the loose section to the side.
  25. Xbox Series X Southbridge Board Replacement, Remove the power cable port: шаг 25, изображение 1 из 1
    • Use a T8 Torx driver to remove the three screws securing the power cable port to the chassis:
    • Two 13.1 mm screws
    • One 35 mm screw
  26. Xbox Series X Southbridge Board Replacement: шаг 26, изображение 1 из 2 Xbox Series X Southbridge Board Replacement: шаг 26, изображение 2 из 2
    • Lift the power connector out of its recess in the chassis.
  27. Xbox Series X Southbridge Board Replacement, De-route the power cables: шаг 27, изображение 1 из 2 Xbox Series X Southbridge Board Replacement, De-route the power cables: шаг 27, изображение 2 из 2
    • Unlatch and open the lid on the power cable's plastic guide.
  28. Xbox Series X Southbridge Board Replacement: шаг 28, изображение 1 из 2 Xbox Series X Southbridge Board Replacement: шаг 28, изображение 2 из 2
    • Lift the power cable out from underneath the extra section of the cable guide.
  29. Xbox Series X Southbridge Board Replacement, Remove the corner cover: шаг 29, изображение 1 из 1
    • Use a T8 Torx driver to remove the 8.8 mm screw securing the power supply corner cover.
  30. Xbox Series X Southbridge Board Replacement: шаг 30, изображение 1 из 2 Xbox Series X Southbridge Board Replacement: шаг 30, изображение 2 из 2
    • Your Xbox may not have this cover depending on the model.
    • Use your fingers or a pair of tweezers to lift and remove the power supply corner cover.
  31. Xbox Series X Southbridge Board Replacement, Remove the accessory antenna board: шаг 31, изображение 1 из 1
    • Use a T8 Torx driver to remove the three 9.6 mm screws securing the accessory antenna board to the center chassis.
  32. Xbox Series X Southbridge Board Replacement: шаг 32, изображение 1 из 3 Xbox Series X Southbridge Board Replacement: шаг 32, изображение 2 из 3 Xbox Series X Southbridge Board Replacement: шаг 32, изображение 3 из 3
    • Grip the antenna board and pull it directly away from the center chassis to disconnect it.
    • During reassembly, align the board's connector with the port on the center chassis and press to reconnect.
  33. Xbox Series X Southbridge Board Replacement, Remove the board shield: шаг 33, изображение 1 из 1
    • Use a T8 Torx driver to remove the nine screws securing the board shield:
    • Six 8.8 mm black screws
    • Two 35 mm silver screws
    • One 13.1 mm silver screw
  34. Xbox Series X Southbridge Board Replacement: шаг 34, изображение 1 из 3 Xbox Series X Southbridge Board Replacement: шаг 34, изображение 2 из 3 Xbox Series X Southbridge Board Replacement: шаг 34, изображение 3 из 3
    • Lift up the board shield to remove it from the center chassis.
  35. Xbox Series X Southbridge Board Replacement, Remove the chassis strap: шаг 35, изображение 1 из 3 Xbox Series X Southbridge Board Replacement, Remove the chassis strap: шаг 35, изображение 2 из 3 Xbox Series X Southbridge Board Replacement, Remove the chassis strap: шаг 35, изображение 3 из 3
    • Disconnect the chassis strap from the locking tabs on either side of the power supply.
  36. Xbox Series X Southbridge Board Replacement: шаг 36, изображение 1 из 2 Xbox Series X Southbridge Board Replacement: шаг 36, изображение 2 из 2
    • Remove the chassis strap.
  37. Xbox Series X Southbridge Board Replacement, Remove the 10-pin power cable: шаг 37, изображение 1 из 3 Xbox Series X Southbridge Board Replacement, Remove the 10-pin power cable: шаг 37, изображение 2 из 3 Xbox Series X Southbridge Board Replacement, Remove the 10-pin power cable: шаг 37, изображение 3 из 3
    • Grip and compress the locking tab on the 10-pin power connector.
    • While compressing the locking tab, lift the connector straight up to disconnect it from the board.
  38. Xbox Series X Southbridge Board Replacement, Remove the 2-pin power cable: шаг 38, изображение 1 из 3 Xbox Series X Southbridge Board Replacement, Remove the 2-pin power cable: шаг 38, изображение 2 из 3 Xbox Series X Southbridge Board Replacement, Remove the 2-pin power cable: шаг 38, изображение 3 из 3
    • Grip and compress the locking tab on the 2-pin power connector.
  39. Xbox Series X Southbridge Board Replacement, Open the cable guide: шаг 39, изображение 1 из 2 Xbox Series X Southbridge Board Replacement, Open the cable guide: шаг 39, изображение 2 из 2
    • Open the lid on the power supply's plastic cable guide.
  40. Xbox Series X Southbridge Board Replacement, Remove the power supply screws: шаг 40, изображение 1 из 2 Xbox Series X Southbridge Board Replacement, Remove the power supply screws: шаг 40, изображение 2 из 2
    • Use a T8 Torx driver to remove the four screws securing the power supply around its perimeter:
    • Three 35 mm silver screws
    • One 8.8 mm black screw
  41. Xbox Series X Southbridge Board Replacement, Remove the power supply: шаг 41, изображение 1 из 2 Xbox Series X Southbridge Board Replacement, Remove the power supply: шаг 41, изображение 2 из 2
    • Remove the power supply.
  42. Xbox Series X Southbridge Board Replacement, Remove the Wi-Fi board: шаг 42, изображение 1 из 1
    • Use a T8 Torx driver to remove the three 8.8 mm screws securing the Wi-Fi antenna board.
  43. Xbox Series X Southbridge Board Replacement: шаг 43, изображение 1 из 3 Xbox Series X Southbridge Board Replacement: шаг 43, изображение 2 из 3 Xbox Series X Southbridge Board Replacement: шаг 43, изображение 3 из 3
    • Don't pull the antenna board up until it's completely disconnected.
    • Remove the antenna board.
  44. Xbox Series X Southbridge Board Replacement, Disconnect the interconnect cable: шаг 44, изображение 1 из 3 Xbox Series X Southbridge Board Replacement, Disconnect the interconnect cable: шаг 44, изображение 2 из 3 Xbox Series X Southbridge Board Replacement, Disconnect the interconnect cable: шаг 44, изображение 3 из 3
    • Depending on your model of Xbox, the interconnect cable locking tab may be in the middle of the socket. If so, skip to the next step.
    • Grip the base of the interconnect cable connector with your fingers.
    • Depress each side of the connector to unlock the cable locking tabs.
    • With the locking tabs depressed, grip the edges of the interconnect cable and pull it straight out of the connector to disconnect it.
    • With the locking tabs depressed correctly, the interconnect cable will slide out with very little force.
    • During reassembly, the interconnect cable should "snap" into place when fully inserted.
  45. Xbox Series X Southbridge Board Replacement: шаг 45, изображение 1 из 3 Xbox Series X Southbridge Board Replacement: шаг 45, изображение 2 из 3 Xbox Series X Southbridge Board Replacement: шаг 45, изображение 3 из 3
    • Use your fingers to pinch the locking tab in the center of the interconnect cable connector.
    • While pinching the tab, insert the flat end of a spudger between the top of the socket and the connector's tab.
    • Twist the spudger to lift the connector out of its socket until the clip in the center disengages.
    • Use your fingers to pull the connector straight up and out of its socket.
    • During reassembly, insert the interconnect cable connector into its socket and press down on both edges until the connector snaps into place.
  46. Xbox Series X Southbridge Board Replacement, Remove the southbridge board shield: шаг 46, изображение 1 из 1
    • Use a T8 Torx driver to remove the seven 8.8 mm screws securing the southbridge board shield.
  47. Xbox Series X Southbridge Board Replacement, Remove the center chassis: шаг 47, изображение 1 из 3 Xbox Series X Southbridge Board Replacement, Remove the center chassis: шаг 47, изображение 2 из 3 Xbox Series X Southbridge Board Replacement, Remove the center chassis: шаг 47, изображение 3 из 3
    • Lift the center chassis off of the motherboard and heatsink assembly.
    • Route the interconnect cable through the cutout on the center chassis as you remove it.
  48. Xbox Series X Southbridge Board Replacement: шаг 48, изображение 1 из 2 Xbox Series X Southbridge Board Replacement: шаг 48, изображение 2 из 2
    • Remove the board shield.
  49. Xbox Series X Southbridge Board Replacement, Remove the cable guide: шаг 49, изображение 1 из 2 Xbox Series X Southbridge Board Replacement, Remove the cable guide: шаг 49, изображение 2 из 2
    • Lift up to remove the power supply cable guide from the southbridge board.
  50. Xbox Series X Southbridge Board Replacement, Remove the southbridge board: шаг 50, изображение 1 из 2 Xbox Series X Southbridge Board Replacement, Remove the southbridge board: шаг 50, изображение 2 из 2
    • Remove the southbridge board from the center chassis.
    • Check if your replacement board comes with power and data cables installed. If it doesn't remove them from the original board and transfer them to your new one.
Заключение
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Xbox Series X Answers community for help.
7 человек успешно провели ремонт по этому руководству.
Carsten Frauenheim
Участник с: 03/10/20
135 590 Репутация
Автор 371 руководств
Команду
iFixit Участник iFixit
Staff
118 членов
Автор 19 425 руководств
Один комментарий
I replace the south bridge board and now my console turns on then off instantly after replacing it. I know the board was working since i got it from another working console that just had a bad HDMI port. Originally this console would turn on then off so that’s when i change the power supply and it worked but the eject button would not work so that’s when I changed the board and after doing that its now turning on then off instantly like it use to do. Let me know if theirs anything else to check in case i missed anything or if it’s just a bad main board. Thanks
360 N One - Ответить
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 15
За последние 7 дней: 99
За последние 30 дней: 374
За всё время: 17,311
