Введение
If your camera's back case is damaged, you might consider changing it. To remove the back panel you will need a small blue plastic opening tool.
Выберете то, что вам нужно
Introduce the plastic opening tool into any of the sides of the camera.
Pry with the plastic opening tool at the seam between the front and the back panel.
Slide prying tool along the seam until front panel is fully separated from the back panel.
Remove the four 3.8 mm Phillips #000 screws located in the outer corners of the motherboard.
Инструмент, используемый на этом этапе:Tweezers$4.99
Pull on and remove the black spacer located at the top inside of the camera body using the tweezers and set the part aside.
Remove the motherboard from from the back case by gently pulling on the lens housing.
Back panel remains.
10 человек успешно провели ремонт по этому руководству.
2 Комментарии к руководству
Where can I buy back panel for Xiaomi Yi?
Where can i buy the back panel replacement ?
