Введение
Is the baby monitor screen in your YOTON YB02 not holding enough power to last? If so, here is a guide to access and replace the battery unit inside the monitor. There are no difficult steps but be careful when prying off the battery from the motherboard.
Выберете то, что вам нужно
Use a Phillips #0 screwdriver to remove the four 7 mm screws from the back panel of the monitor.
Using the plastic tool, disconnect the cables connecting the battery to the motherboard.
Еще один человек закончил это руководство.
