Введение
Is the camera on your Yuneec Breeze 4K Drone not recording? Consider using this guide to replace the camera in your drone.
Выберете то, что вам нужно
Before you begin start by putting on a ESD wrist strap to prevent ESD damage and remove the battery.
Once the battery is taken out, flip over the drone so that the cameras are now facing up.
Remove the four white rubber dampeners located in each corner of the frame that hold the it in place.
Slightly lift the M7 board to remove the two plugs located under the rear of the board.
Once all plugs on top of the M7 board are disconnected, carefully lift the M7 board onto its side and remove all plugs on the bottom.
Tilt the M7 board onto its side. Using the Phillips #00 screwdriver remove the two black screws connected to the large black two pronged input.
There will be 4 screws that hold the A9 board together. Using a H1.5 Alan bit unscrew those bolts to take the A9 board apart.
Pull apart the frame from the other board. The camera will be connected by a plug and it should pull out easily.
3 человек успешно провели ремонт по этому руководству.
1 Комментарий к руководству
Excellent! I don’t think that the process could of have been any more clear than this.
