Введение
You can use this guide if you have a cracked back cover for your ZTE Grand X Max Plus and want to replace it.
You can also use this as a guide to open your phone.
Выберете то, что вам нужно
Heat the phone using a heating pad, heat gun, or hair dryer to loosen the glue. You just need to heat the back of the phone.
After the phone is heated, use the blue plastic opening tool on both sides of the phone.
2 человек успешно провели ремонт по этому руководству.
1 Комментарий к руководству
There seems to be an antenna attached to the mid frame that gets stuck to the back glass on the top left. Does anyone know what this is??
