Введение
This guide will help you access and remove the battery from the ZTE Maven 2 (model Z831). The battery is what what holds the charge for the phone and is required for any function of the phone. If your phone hasn't been charging consistently, at all, or is overheating, you may need to remove and replace the battery of the device.
Выберете то, что вам нужно
Pry off the back cover by inserting an opening tool into the small space on the bottom left between the phone's cover and body.
Work your way around the phone with an opening pick to loosen the rest of the back cover.
Remove the cover.
Push in and then up on the bottom of the battery to free it from its compartment.
Pull the battery out.
