Введение
This guide involves taking apart the Zoomer Dino Boomer in order to disconnect the sensor button from the main circuit board for replacement.
Выберете то, что вам нужно
Turn dinosaur over and hold upright.
Use the spudger to pry apart the back cover from the remainder of the Zoomer Dino Boomer.
Инструмент, используемый на этом этапе:Tweezers$4.99
Disconnect the wire that connects the back cover of the dino to the main circuit board by carefully pulling on the orange wire connector with tweezers.
Remove back cover.
Where the button is smallest, squeeze the two white tabs together and press the circular tab in-between them until the button comes loose.
Remove the back button.
