eMac PRAM Battery Replacement
Выберете то, что вам нужно
    1. eMac PRAM Battery Replacement, PRAM Battery: шаг 1, изображение 1 из 2 eMac PRAM Battery Replacement, PRAM Battery: шаг 1, изображение 2 из 2
      • Lay a towel (to protect the screen) on your work area and place the unit face down with the bottom facing you.
      Спросите у FixBot
      Добавить комментарий
    2. eMac PRAM Battery Replacement: шаг 2, изображение 1 из 2 eMac PRAM Battery Replacement: шаг 2, изображение 2 из 2
      • The access panel is held in place by one Phillips screw. Unscrew it.
      • Unplug the machine after touching the metal housing to prevent ESD (electro static discharge)
      Спросите у FixBot
    3. eMac PRAM Battery Replacement: шаг 3, изображение 1 из 1
      • The battery is located just to the left and below the RAM slots.
      • Note the positive is to the right and negative to the left. There is a + sign located on the logic board to the right of the battery.
      • Care must be taken when removing the battery to prevent it dropping into the machine. It pulls straight out. Use a small instrument like a dental pick or flathead screwdriver to lift the + end out. I use a large hemostat to hold the battery.
      • After removal of the old battery and replace with a new one by pressing it into place.
      • Replace the access panel. Turn it over and plug it in. Start up and go under the Apple to System Preferences - System - Date & Time. If you have an internet connection check the box to automatically and select Apple Americas.
      • If no internet just set the date and time manually.
      • Next select the Time Zone box. Click the curser on the map to the closest city to you.
      • Next click the Clock box and select the type of display you prefer.
      Спросите у FixBot
Заключение
27 человек успешно провели ремонт по этому руководству.
mayer
Участник с: 01/04/10
690 453 Репутация
Автор 11 руководств
1 Комментарий к руководству
Alguien sabe el.modo serie de la batería???? Todo muy bien pero faltó lomas importante el modelo serie o número de pieza de la bateria
ru vera - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 13
За последние 30 дней: 76
За всё время: 24,932
