iBook G3 Clamshell Display Replacement
Выберете то, что вам нужно
    1. iBook G3 Clamshell Display Replacement, Battery: шаг 1, изображение 1 из 1
      • Use a coin to turn both battery locking screws 90 degrees to the left.
      • Remove the battery cover.
      • Remove the battery from the computer by pulling up on the plastic tab.
      Спросите у FixBot
      Добавить комментарий
    1. iBook G3 Clamshell Display Replacement, Airport Card: шаг 2, изображение 1 из 1
      • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free. Note that the keyboard ribbon is still attached to the logic board, so you cannot completely remove the keyboard yet.
      • If the keyboard does not come free, use a small flathead screwdriver to turn the keyboard locking screw (between F4 and F5 key) 180 degrees in either direction and try again.
      • Rotate the keyboard away from the screen and rest it face-down on the trackpad area.
      Спросите у FixBot
    2. iBook G3 Clamshell Display Replacement: шаг 3, изображение 1 из 1
      • If your computer does not have an airport card, you can skip the next two steps.
      • Grasp the clear plastic tab on the airport card and pull up and toward the display.
      Спросите у FixBot
    3. iBook G3 Clamshell Display Replacement: шаг 4, изображение 1 из 1
      • Hold the airport card in one hand and use your other hand to remove the antenna cable.
      Спросите у FixBot
    1. iBook G3 Clamshell Display Replacement, Keyboard: шаг 5, изображение 1 из 1
      • Remove the two Phillips screws that secure the RAM shield.
      Спросите у FixBot
    2. iBook G3 Clamshell Display Replacement: шаг 6, изображение 1 из 1
      • Grasp the wire metal bracket on top of the RAM shield and pull upward to remove the shield.
      Спросите у FixBot
    3. iBook G3 Clamshell Display Replacement: шаг 7, изображение 1 из 1
      • Pull up the keyboard connector cable by its clear plastic loop.
      Спросите у FixBot
    1. iBook G3 Clamshell Display Replacement, Upper Case: шаг 8, изображение 1 из 1
      • Use a straightened paperclip to manually eject the CD-ROM tray.
      Спросите у FixBot
    2. iBook G3 Clamshell Display Replacement: шаг 9, изображение 1 из 1
      • Turn the computer over so that the bottom is facing up.
      • Remove the following Torx screws:
      • Four short T8 Torx near the battery compartment.
      • Two long T8 Torx near the hinges.
      Спросите у FixBot
    3. iBook G3 Clamshell Display Replacement: шаг 10, изображение 1 из 1
      • Pull the CD-ROM drive tray partly out.
      • Remove the silver Phillips screw from the plastic casing.
      Спросите у FixBot
    4. iBook G3 Clamshell Display Replacement: шаг 11, изображение 1 из 1
      • Turn the computer over.
      • Remove the three Phillips screws.
      Спросите у FixBot
    5. iBook G3 Clamshell Display Replacement: шаг 12, изображение 1 из 1
      • This is a diagram of the trackpad ribbon clamp connector you will disconnect in the next step.
      • 1) With your fingernails, grasp the locking bar on either side and pull up a small amount (about 1/16" or 2 mm).
      • 2) After disengaging the locking bar, slide the cable out of the connector.
      Спросите у FixBot
    6. iBook G3 Clamshell Display Replacement: шаг 13, изображение 1 из 1
      • Loosen the trackpad clamp by pulling the top piece up slightly, freeing the trackpad ribbon.
      • Slide the orange trackpad ribbon out of the clamp.
      Спросите у FixBot
    7. iBook G3 Clamshell Display Replacement: шаг 14, изображение 1 из 1
      • Do not lift the upper case too far without first disconnecting the audio cable.
      • Push out the rim of the lower case and pull up on the upper case, grasping it just to the left of the optical drive.
      • Repeat the above step on the upper left corner of the upper case, grasping the bottom left corner of the upper case.
      Спросите у FixBot
    8. iBook G3 Clamshell Display Replacement: шаг 15, изображение 1 из 1
      • Disconnect the audio cable.
      Спросите у FixBot
    9. iBook G3 Clamshell Display Replacement: шаг 16, изображение 1 из 1
      • Grasp the upper case on either side of the keyboard space and rotate up and away from the screen.
      • You may be thinking you're about to break your upper case. Not to worry - the tabs holding the upper and lower cases together are very strong. Simply apply even pressure and continue to rotate the upper case up and away from the screen until it comes free.
      Спросите у FixBot
    1. iBook G3 Clamshell Display Replacement, Modem: шаг 17, изображение 1 из 1
      • Remove the following Phillips screws:
      • Remove the longer Phillips screw from the middle-rear of the modem shield.
      • Remove the three identical Phillips screws, two on either side of the EMI fingers, and the remaining one on the right side of the modem shield.
      • Remove the larger Phillips screw that secures the EMI fingers to the modem board.
      • Remove the EMI fingers.
      Спросите у FixBot
    2. iBook G3 Clamshell Display Replacement: шаг 18, изображение 1 из 1
      • Peel the modem shield away from the metal framework below, working from the right front and moving to the left.
      Спросите у FixBot
    3. iBook G3 Clamshell Display Replacement: шаг 19, изображение 1 из 1
      • Remove the Phillips screw from the left side of the modem.
      • Pry up the right side of the modem.
      Спросите у FixBot
    4. iBook G3 Clamshell Display Replacement: шаг 20, изображение 1 из 1
      • Lift the modem partially out and disconnect the cable on the left side.
      Спросите у FixBot
    1. iBook G3 Clamshell Display Replacement, Display: шаг 21, изображение 1 из 1
      • Remove the Phillips screw from the left hinge.
      • Peel up the airport cable from beneath the yellow tape.
      Спросите у FixBot
    2. iBook G3 Clamshell Display Replacement: шаг 22, изображение 1 из 1
      • Disconnect the large display data cable from the logic board and deroute it from the plastic and metal tabs.
      Спросите у FixBot
    3. iBook G3 Clamshell Display Replacement: шаг 23, изображение 1 из 1
      • Disconnect the backlight cable from the logic board and deroute it.
      Спросите у FixBot
    4. iBook G3 Clamshell Display Replacement: шаг 24, изображение 1 из 1
      • Remove the three small Phillips screws from the clutch cover.
      Спросите у FixBot
    5. iBook G3 Clamshell Display Replacement: шаг 25, изображение 1 из 1
      • Finally, support the display with one hand while unscrewing the last Phillips screw from the right hinge (push the display gently down to avoid putting pressure on the screw).
      • Remove the display assembly.
      • When re-installing the display assembly, make sure that the clutch cover goes over the white plastic tabs protruding from the rear underside of the laptop.
      Спросите у FixBot
Заключение
10 человек успешно провели ремонт по этому руководству.
Прикрепленные документы
iRobot
Участник с: 09/24/09
1 Репутация
Автор 635 руководств
2 Комментарии к руководству
Veryinformativeandexcellentguideforibookclamshell.thankyou.
Renee Blakemore - Ответить Поделиться
Wait, so is the display the whole clamshell? There isn't steps to swap out the display inside the clamshell?
The Wonderer - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 5
За последние 7 дней: 29
За последние 30 дней: 124
За всё время: 19,007
