iBook G3 Clamshell RAM Replacement
Выберете то, что вам нужно
    1. iBook G3 Clamshell RAM Replacement, Battery: шаг 1, изображение 1 из 1
      • Use a coin to turn both battery locking screws 90 degrees to the left.
      • Remove the battery cover.
      • Remove the battery from the computer by pulling up on the plastic tab.
      Спросите у FixBot
      Добавить комментарий
    1. iBook G3 Clamshell RAM Replacement, Airport Card: шаг 2, изображение 1 из 1
      • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free. Note that the keyboard ribbon is still attached to the logic board, so you cannot completely remove the keyboard yet.
      • If the keyboard does not come free, use a small flathead screwdriver to turn the keyboard locking screw (between F4 and F5 key) 180 degrees in either direction and try again.
      • Rotate the keyboard away from the screen and rest it face-down on the trackpad area.
      Спросите у FixBot
    2. iBook G3 Clamshell RAM Replacement: шаг 3, изображение 1 из 1
      • If your computer does not have an airport card, you can skip the next two steps.
      • Grasp the clear plastic tab on the airport card and pull up and toward the display.
      Спросите у FixBot
    3. iBook G3 Clamshell RAM Replacement: шаг 4, изображение 1 из 1
      • Hold the airport card in one hand and use your other hand to remove the antenna cable.
      Спросите у FixBot
    1. iBook G3 Clamshell RAM Replacement, Keyboard: шаг 5, изображение 1 из 1
      • Remove the two Phillips screws that secure the RAM shield.
      Спросите у FixBot
    2. iBook G3 Clamshell RAM Replacement: шаг 6, изображение 1 из 1
      • Grasp the wire metal bracket on top of the RAM shield and pull upward to remove the shield.
      Спросите у FixBot
    3. iBook G3 Clamshell RAM Replacement: шаг 7, изображение 1 из 1
      • Pull up the keyboard connector cable by its clear plastic loop.
      Спросите у FixBot
    1. iBook G3 Clamshell RAM Replacement, RAM: шаг 8, изображение 1 из 1
      • Your laptop should look approximately like this.
      Спросите у FixBot
    2. iBook G3 Clamshell RAM Replacement: шаг 9, изображение 1 из 1
      • Release the tabs on each side of the RAM chip at the same time. These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
      • Pull the chip directly out from its connectors.
      Спросите у FixBot
Заключение
20 человек успешно провели ремонт по этому руководству.
Прикрепленные документы
iRobot
Участник с: 09/24/09
1 Репутация
Автор 635 руководств
1 Комментарий к руководству
I love that iFixit will sell you a quarter ($0.25) for $2.99 plus tax and shipping, another $3.29 shipping (totally reasonable), and sales tax for my location - the total is $6.59. I wish I could sell quarters for $6.59. 🤣
UnCoopervised - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 4
За последние 7 дней: 25
За последние 30 дней: 91
За всё время: 24,668
