iHome IBT16 Micro USB port Replacement
Выберете то, что вам нужно
  1. iHome IBT16 Micro USB port Replacement, Base Plate: шаг 1, изображение 1 из 2 iHome IBT16 Micro USB port Replacement, Base Plate: шаг 1, изображение 2 из 2
    • Make sure to flip the device over to get into the correct orientation
    • Using the Philips #00 Screwdriver, unscrew and remove the four 9mm black screws on the base plate of the device.
    • Make sure to keep these screws in a safe location so you don't lose them
    Спросите у FixBot
    Добавить комментарий
  2. iHome IBT16 Micro USB port Replacement: шаг 2, изображение 1 из 2 iHome IBT16 Micro USB port Replacement: шаг 2, изображение 2 из 2
    • Using the plastic opening tool, insert into the crack between the base plate and the main body of the device
    • Using a lever like motion, push the opening tool down thus lifting the plate
    • You will need to use your fingers to lift the base plate off the main body of the device
    • The motherboard is directly underneath the base plate
    Спросите у FixBot
  3. iHome IBT16 Micro USB port Replacement, Micro USB port: шаг 3, изображение 1 из 1
    • Inside the iHome remove the two silver Phillips screws that are on the motherboard.
    • Connect the ground strap to ground, and then put the strap around your wrist.
    Спросите у FixBot
  4. iHome IBT16 Micro USB port Replacement: шаг 4, изображение 1 из 1
    • Take the motherboard out of the device, use the plastic opening tool to ensure the power switch doesn't get stuck.
    Спросите у FixBot
  5. iHome IBT16 Micro USB port Replacement: шаг 5, изображение 1 из 1
    • On the other side of the motherboard unsolder the two biggest solder joints under the micro USB.
    Спросите у FixBot
  6. iHome IBT16 Micro USB port Replacement: шаг 6, изображение 1 из 1
    • On the side of the motherboard that the micro USB connector is there are five surface mount solder joints at the back of the connector. Unsolder these five solder joints.
    Спросите у FixBot
Заключение
Steven Ferreira
Участник с: 03/08/17
222 Репутация
Автор 2 руководств
Команда
UMass Dartmouth, Team S3-G6, Botvin Spring 2017 Участник UMass Dartmouth, Team S3-G6, Botvin Spring 2017
UMASSD-BOTVIN-S17S3G6
2 членов
Автор 5 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 2
За последние 30 дней: 18
За всё время: 1,715
