iHome IBT16 Power Switch Replacement
Выберете то, что вам нужно
  1. iHome IBT16 Power Switch Replacement, Base Plate: шаг 1, изображение 1 из 2 iHome IBT16 Power Switch Replacement, Base Plate: шаг 1, изображение 2 из 2
    • Make sure to flip the device over to get into the correct orientation
    • Using the Philips #00 Screwdriver, unscrew and remove the four 9mm black screws on the base plate of the device.
    • Make sure to keep these screws in a safe location so you don't lose them
    Спросите у FixBot
    Добавить комментарий
  2. iHome IBT16 Power Switch Replacement: шаг 2, изображение 1 из 2 iHome IBT16 Power Switch Replacement: шаг 2, изображение 2 из 2
    • Using the plastic opening tool, insert into the crack between the base plate and the main body of the device
    • Using a lever like motion, push the opening tool down thus lifting the plate
    • You will need to use your fingers to lift the base plate off the main body of the device
    • The motherboard is directly underneath the base plate
    Спросите у FixBot
  3. iHome IBT16 Power Switch Replacement, Power Switch: шаг 3, изображение 1 из 2 iHome IBT16 Power Switch Replacement, Power Switch: шаг 3, изображение 2 из 2
    • Using the Philips #00 screwdriver, unscrew and remove the two silver 10mm screws holding the motherboard
    • Don't misplace the screws! Keep them in a safe place while working on the device
    • Make sure to ground yourself prior to continuing at this point
    Спросите у FixBot
  4. iHome IBT16 Power Switch Replacement: шаг 4, изображение 1 из 1
    • Using the plastic opening tool, pull the motherboard out of the casing
    • Make sure to lift it out at an angle to the back, as the plastic power switch is attached to the board and can be broken
    Спросите у FixBot
  5. iHome IBT16 Power Switch Replacement: шаг 5, изображение 1 из 2 iHome IBT16 Power Switch Replacement: шаг 5, изображение 2 из 2
    • Desolder the 10 points holding the power switch to the motherboard
    • Once complete, simply remove the switch from the board
    Спросите у FixBot
Заключение
Еще один человек закончил это руководство.
Ryan Edwards
Участник с: 03/21/17
331 Репутация
Автор 3 руководств
Команда
UMass Dartmouth, Team S3-G6, Botvin Spring 2017 Участник UMass Dartmouth, Team S3-G6, Botvin Spring 2017
UMASSD-BOTVIN-S17S3G6
2 членов
Автор 5 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 14
За всё время: 1,049
