iHome iD95 iPod Adapter Replacement
Выберете то, что вам нужно
  1. iHome iD95 iPod Adapter Replacement, Backup Battery: шаг 1, изображение 1 из 1
    • Before taking apart the iD95, disconnect the AC cord from the wall socket and AC adapter from the DC jack. Remove any iPods, iPhones, and iPads attached to the device.
    • Flip over the iD95 so the bottom cover is visible and the LCD screen is facing you.
    Спросите у FixBot
    Добавить комментарий
  2. iHome iD95 iPod Adapter Replacement: шаг 2, изображение 1 из 1
    • Remove the 10 mm-length, 5 mm-head screw using a Phillips #1 screwdriver.
    Спросите у FixBot
  3. iHome iD95 iPod Adapter Replacement: шаг 3, изображение 1 из 1
    • Use a plastic opening tool to take out the backup battery.
    Спросите у FixBot
  4. iHome iD95 iPod Adapter Replacement, Bottom Cover: шаг 4, изображение 1 из 1
    • Unscrew five 17 mm-length, 6 mm-head screws using a Phillips #1 screwdriver.
    Спросите у FixBot
  5. iHome iD95 iPod Adapter Replacement: шаг 5, изображение 1 из 2 iHome iD95 iPod Adapter Replacement: шаг 5, изображение 2 из 2
    • The bottom cover is attached to the back cover by two plastic clips. Don't use excessive force.
    • Insert a plastic opening tool between the edge of the bottom cover and the main body.
    • Gently pry the bottom cover from the body. Start anywhere along the front side of the iD95 and work your way around.
    • Grip the bottom portion of the device and gently lift the front part of the bottom cover a couple centimeters up.
    Спросите у FixBot
  6. iHome iD95 iPod Adapter Replacement: шаг 6, изображение 1 из 2 iHome iD95 iPod Adapter Replacement: шаг 6, изображение 2 из 2
    • Potential for device damage: Be careful not to use too much force or you might break the plastic rings holding the side panels in place.
    • Lift up the bottom cover. Pull the side panel up first, out, and away from the device.
    • The side panels have plastic rings that will need to be lifted up and off the cylinders they are placed around.
    Спросите у FixBot
  7. iHome iD95 iPod Adapter Replacement: шаг 7, изображение 1 из 2 iHome iD95 iPod Adapter Replacement: шаг 7, изображение 2 из 2
    • Apply the same techniques from the previous step to remove the remaining side panel.
    Спросите у FixBot
  8. iHome iD95 iPod Adapter Replacement: шаг 8, изображение 1 из 3 iHome iD95 iPod Adapter Replacement: шаг 8, изображение 2 из 3 iHome iD95 iPod Adapter Replacement: шаг 8, изображение 3 из 3
    • Locate the two plastic clips holding the bottom and back cover together.
    • Which clip you remove first is up to you. Rotate the device 90 degrees either left or right. Insert the flat end of a spudger horizontally between the back speaker and the back cover.
    • Place the flat end of the spudger behind one clip and pry it open. This may take repeated attempts.
    • This is the hardest step because the angle is awkward and the visibility is poor. If possible, have someone hold the device or provide lighting.
    • Once a clip has been removed, hold the bottom cover open so the clip will not fall back into place. One clip remains to be removed; you are almost there!
    Спросите у FixBot
  9. iHome iD95 iPod Adapter Replacement: шаг 9, изображение 1 из 2 iHome iD95 iPod Adapter Replacement: шаг 9, изображение 2 из 2
    • Use the same steps to remove the remaining clip.
    • The bottom cover is still connected to the motherboard by wiring.
    Спросите у FixBot
  10. iHome iD95 iPod Adapter Replacement: шаг 10, изображение 1 из 2 iHome iD95 iPod Adapter Replacement: шаг 10, изображение 2 из 2
    • Use a plastic opening tool to pry off the white ZIF connector joining the wires to the motherboard.
    • Don't pull the wires. Take your time using a plastic opening tool.
    Спросите у FixBot
  11. iHome iD95 iPod Adapter Replacement, Speakers: шаг 11, изображение 1 из 1
    • Take out four 14 mm screws using a Phillips #1 screwdriver.
    Спросите у FixBot
  12. iHome iD95 iPod Adapter Replacement: шаг 12, изображение 1 из 3 iHome iD95 iPod Adapter Replacement: шаг 12, изображение 2 из 3 iHome iD95 iPod Adapter Replacement: шаг 12, изображение 3 из 3
    • Use a plastic opening tool to lift the two speaker zip connectors from the logic board.
    • Do not pull on the speaker wires directly. Continue to use a plastic opening tool.
    Спросите у FixBot
  13. iHome iD95 iPod Adapter Replacement: шаг 13, изображение 1 из 1
    • Lift and remove both speakers.
    Спросите у FixBot
  14. iHome iD95 iPod Adapter Replacement, iPod Adapter: шаг 14, изображение 1 из 2 iHome iD95 iPod Adapter Replacement, iPod Adapter: шаг 14, изображение 2 из 2
    • Flip the logic board over.
    • Use a plastic opening tool to pry and lift the iPod adapter zip connector from the logic board.
    Спросите у FixBot
  15. iHome iD95 iPod Adapter Replacement: шаг 15, изображение 1 из 2 iHome iD95 iPod Adapter Replacement: шаг 15, изображение 2 из 2
    • Remove two 4 mm-head 12 mm-length screws using a Phillips #1 screwdriver.
    • Pull the iPod adapter from the top cover.
    Спросите у FixBot
  16. iHome iD95 iPod Adapter Replacement: шаг 16, изображение 1 из 2 iHome iD95 iPod Adapter Replacement: шаг 16, изображение 2 из 2
    • Use a Phillips #1 screwdriver to take out the two, 12 mm-length 4 mm-head, screws holding the iPod adapter to its casing.
    Спросите у FixBot
Заключение
Еще один человек закончил это руководство.
Vincent Chan
Участник с: 04/18/13
19 Репутация
Автор 6 руководств
Команда
Cal Poly, Team 12-37, Amido Spring 2013 Участник Cal Poly, Team 12-37, Amido Spring 2013
CPSU-AMIDO-S13S12G37
4 членов
Автор 14 руководств
1 Комментарий к руководству
Great article. I have an iHome iDL95 and would like to swap the Lightening adapter with a 30-pin adapter so that I can utilize my iPod 5.5 Classic. Is this possible? If so, where do I obtain the required 30-pin replacement adapter? Thanks.
P. Matt - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 8
За последние 30 дней: 30
За всё время: 2,283
