iHome iH27B Power Connector Replacement
Выберете то, что вам нужно
    1. iHome iH27B Power Connector Replacement, Outer Case: шаг 1, изображение 1 из 1
      • Remove any iPod or apple music device connected to the iHome and unplug from any power source.
      • Flip the iHome so the speakers are laying on a flat surface, and you have the concealed battery areas facing you.
      Спросите у FixBot
      Добавить комментарий
    2. iHome iH27B Power Connector Replacement: шаг 2, изображение 1 из 3 iHome iH27B Power Connector Replacement: шаг 2, изображение 2 из 3 iHome iH27B Power Connector Replacement: шаг 2, изображение 3 из 3
      • Using your fingers, press down firmly on the plastic slide and push in the direction of the arrows shown above the word "Open" on the plastic.
      • Remove the plastic slide from its location and set it aside.
      • These plastic slides are not interchangeable, so make sure each goes back to its original location in reassembly.
      • Remove all 4 AA batteries by placing your fingernail at one end of the battery and applying force upwards until the battery is freed from its holder.
      • Insert your fingernail or a prying tool under the notch of the plastic slide that is protecting the watch battery.
      • Set the plastic covering and the watch battery aside.
      Спросите у FixBot
    3. iHome iH27B Power Connector Replacement: шаг 3, изображение 1 из 1
      • Remove the following screws:
      • Eight 10 mm using the Phillips #0 on the bottom of your device.
      • Cataloging each screw by size in plastic bags or separate places on a flat surface will make them easier to find when reassembling.
      Спросите у FixBot
    4. iHome iH27B Power Connector Replacement: шаг 4, изображение 1 из 1
      • Use your fingers or a plastic opening tool to carefully pry apart the plastic connections still connecting the base to the top.
      • Be careful not to pry too hard. Cracking the plastic connections could make reassembly harder.
      Спросите у FixBot
    5. iHome iH27B Power Connector Replacement: шаг 5, изображение 1 из 1
      • Slowly lift the plastic base towards you and lay it on the flat surface. The base should still be connected to the rest of the iHome by a few wires.
      • You should have visible access to most of the components inside the iHome now.
      Спросите у FixBot
    1. iHome iH27B Power Connector Replacement, Power Connector: шаг 6, изображение 1 из 2 iHome iH27B Power Connector Replacement, Power Connector: шаг 6, изображение 2 из 2
      • Firmly grasp the power connector, which is the plastic rectangular piece with the white and black wires connected to it.
      • Pull upwards and dislodge the connector.
      Спросите у FixBot
    2. iHome iH27B Power Connector Replacement: шаг 7, изображение 1 из 1
      • Using the scissors on your wire strippers, cut the connecting wires.
      • Using your wire strippers, remove about 1/4 " of the plastic tubing surrounding the end of your exposed wire, careful to not damage the wires.
      • Using a wire-nut or electrician's tape, connect the wires of the replacement power connector to your exposed wires. Connect white wire to white, and black to black.
      Спросите у FixBot
Заключение
John Kraemer
Участник с: 10/09/12
76 Репутация
Автор 9 руководств
Команда
Cal Poly, Team 3-21, Amido Fall 2012 Участник Cal Poly, Team 3-21, Amido Fall 2012
CPSU-AMIDO-F12S3G21
4 членов
Автор 27 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 8
За последние 30 дней: 33
За всё время: 2,511
