iMac G5 17" Model A1058 PRAM Battery Replacement
Выберете то, что вам нужно
    1. iMac G5 17" Model A1058 PRAM Battery Replacement, Rear Panel: шаг 1, изображение 1 из 1
      • Lay the iMac display-side down on a flat surface.
      • Loosen the three Phillips screws securing the rear panel to the iMac.
      • These screws are captive in the iMac. The center screw will stop turning after about 3.5 turns and the outer screws will stop turning after about 5.5 turns. Do not try to remove these screws from your iMac.
      Спросите у FixBot
      Добавить комментарий
    2. iMac G5 17" Model A1058 PRAM Battery Replacement: шаг 2, изображение 1 из 3 iMac G5 17" Model A1058 PRAM Battery Replacement: шаг 2, изображение 2 из 3 iMac G5 17" Model A1058 PRAM Battery Replacement: шаг 2, изображение 3 из 3
      • Lift the rear panel slightly from the bottom edge of the iMac.
      • Pull the rear panel toward yourself and remove it from the iMac.
      Спросите у FixBot
    1. iMac G5 17" Model A1058 PRAM Battery Replacement, AirPort Extreme: шаг 3, изображение 1 из 1
      • Lift the AirPort card slightly by its plastic tab and pull it straight away from its socket.
      • During reinstallation, insert the AirPort card such that the antenna side is nearest the center of the logic board.
      Спросите у FixBot
    2. iMac G5 17" Model A1058 PRAM Battery Replacement: шаг 4, изображение 1 из 1
      • Insert the flat end of a spudger between the body of the AirPort card and its antenna connector.
      • Push the spudger away from the AirPort card to disconnect the AirPort antenna.
      • When reassembling your iMac, be sure to insert the AirPort card the way it was before disassembly.
      Спросите у FixBot
    1. iMac G5 17" Model A1058 PRAM Battery Replacement, PRAM Battery: шаг 5, изображение 1 из 1
      • Remove the two 5.5 mm T6 Torx screws securing the AirPort bracket to the logic board.
      Спросите у FixBot
    2. iMac G5 17" Model A1058 PRAM Battery Replacement: шаг 6, изображение 1 из 1
      • Slightly lift the AirPort bracket off the logic board.
      • De-route the AirPort antenna through the slot in the AirPort bracket.
      Спросите у FixBot
    3. iMac G5 17" Model A1058 PRAM Battery Replacement: шаг 7, изображение 1 из 1
      • Slightly insert the tip of a spudger (or any other small wedge-shaped object) under the PRAM battery directly across from its retaining clip.
      • Do not bend the metal retaining clip up, as it is brittle and will break.
      • Use another spudger to slide the PRAM battery out from under its socket's retaining clip.
      Спросите у FixBot
Заключение
10 человек успешно провели ремонт по этому руководству.
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 19
За последние 30 дней: 77
За всё время: 19,577
