iPhone 11 Pro Back Glass Replacement
Видеообзор
    1. iPhone 11 Pro  Back Glass Replacement, Choose The Right Laser Drawing: шаг 1, изображение 1 из 1
      • Place the iPhone 11 Pro back glass under the probe for focusing. Then place the iPhone 11 Pro back glass on the operating panel.
      • Choose ‘iPhone 11 Pro’ from the model list and click ‘Load’ to load the drawing.
      Спросите у FixBot
      Добавить комментарий
    2. iPhone 11 Pro  Back Glass Replacement, Scan The Back Glass With Laser: шаг 2, изображение 1 из 1
      • Adjust the laser light scanning area on the back glass.
      • Once finished, get the parameter set and click ‘Mark’ to scan the back glass with the laser light.
      Спросите у FixBot
    3. iPhone 11 Pro  Back Glass Replacement, Scan The Glass Around The Triple-lens Camera With Laser: шаг 3, изображение 1 из 1
      • The laser light scanning didn’t work well with the triple-lens camera area here.
      • After several attempts and experiments, REWA LAB successfully completed a specialized drawing for the triple-lens camera area.
      • Scan the triple-lens camera area again with the laser with the help of the drawing.
      Спросите у FixBot
    4. iPhone 11 Pro  Back Glass Replacement, Separate The Back Glass From The Mid-frame: шаг 4, изображение 1 из 1
      • The scanned back glass can be separated easily. However, the glass around the triple-lens camera needs further operation.
      • Our commonly used tools failed to remove the glass here, so we used a glass cutter, a grinding tool, a Sculpture Knife and a Cutting Nipper to remove the glass around the triple-lens camera.
      • Once completed, remove residual black adhesive with the Laser Machine.
      Спросите у FixBot
    5. iPhone 11 Pro  Back Glass Replacement, Big Hole Back Glass: шаг 5, изображение 1 из 1
      • The camera holder ring of iPhone 11 series is harder and comes with thick inside walls, adding to the difficulty of polishing. Meanwhile, the camera lens can also be easily damaged during polishing.
      • So we highly recommend replacement back glass with a big camera hole for iPhone 11 series back glass repair.
      Спросите у FixBot
Заключение
Due to the special arrangement of the three cameras of iPhone 11 Pro, the space between the three cameras is also narrow, adding to the difficulty of back glass separating. Therefore, the Laser Machine may be the safest and most efficient solution for iPhone 11 Pro back glass repair.
12 человек успешно провели ремонт по этому руководству.
Phryne
Участник с: 11/17/19
21 862 Репутация
Автор 18 руководств
1 Комментарий к руководству
Et un fois réparer ça tiens 3 mois vue que le châssis et quasiment toujours plier suite au choc ou la vitre arrière est pas coller et ceux séparé avec le temps…
niko rad - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 6
За последние 7 дней: 43
За последние 30 дней: 184
За всё время: 104,229
