iPhone 15 Plus Front Camera Assembly Replacement
Выберете то, что вам нужно
  1. iPhone 15 Plus Front Camera Assembly Replacement, Prepare your phone for disassembly: шаг 1, изображение 1 из 2 iPhone 15 Plus Front Camera Assembly Replacement, Prepare your phone for disassembly: шаг 1, изображение 2 из 2
    • Allow your phone's battery to drain below 25%, as a charged lithium-ion battery is a potential safety hazard.
    • Unplug any cables from your phone.
    • Hold the power and either volume buttons and slide to power off your phone.
  2. iPhone 15 Plus Front Camera Assembly Replacement, Tape over any cracks: шаг 2, изображение 1 из 2 iPhone 15 Plus Front Camera Assembly Replacement, Tape over any cracks: шаг 2, изображение 2 из 2
    • If your screen or back glass is badly cracked, lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier.
    • Make sure there's a smooth area near the bottom edge that's big enough for a suction cup to stick to.
  3. iPhone 15 Plus Front Camera Assembly Replacement, Mark your opening picks: шаг 3, изображение 1 из 3 iPhone 15 Plus Front Camera Assembly Replacement, Mark your opening picks: шаг 3, изображение 2 из 3 iPhone 15 Plus Front Camera Assembly Replacement, Mark your opening picks: шаг 3, изображение 3 из 3
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
    • Apple sells an Adhesive Cutter tool for cutting the display adhesive safely in their Self Repair Store.
  4. iPhone 15 Plus Front Camera Assembly Replacement, Remove the pentalobe screws: шаг 4, изображение 1 из 1
    • Use a P2 pentalobe driver to remove the two 7.7 mm-long screws on either side of the charging port.
  5. iPhone 15 Plus Front Camera Assembly Replacement, Heat the bottom edge: шаг 5, изображение 1 из 1
    • Use a hair dryer or heat gun to heat the bottom edge of the back glass until it's hot to the touch.
    • Be careful not to heat the phone hotter than this—the battery is susceptible to heat damage.
  6. iPhone 15 Plus Front Camera Assembly Replacement, Insert an opening pick: шаг 6, изображение 1 из 3 iPhone 15 Plus Front Camera Assembly Replacement, Insert an opening pick: шаг 6, изображение 2 из 3 iPhone 15 Plus Front Camera Assembly Replacement, Insert an opening pick: шаг 6, изображение 3 из 3
    • Apply a suction handle to the bottom edge of the back glass.
    • Pull up on the handle with a strong, steady force to create a gap between the back glass and the frame.
    • Insert the tip of an opening pick into the gap.
  7. iPhone 15 Plus Front Camera Assembly Replacement, Back glass information: шаг 7, изображение 1 из 1
    • As you slice the adhesive securing the back glass in the next steps, be careful of the following areas:
    • There's a delicate cable connecting the back glass to the phone, right next to the volume up button. Don't insert your pick here to avoid slicing the cable.
    • There are multiple spring contacts around the perimeter of the phone. Be extra careful not to insert your pick deeper than suggested in each step to avoid bending these contacts.
  8. iPhone 15 Plus Front Camera Assembly Replacement, Separate the bottom edge adhesive: шаг 8, изображение 1 из 3 iPhone 15 Plus Front Camera Assembly Replacement, Separate the bottom edge adhesive: шаг 8, изображение 2 из 3 iPhone 15 Plus Front Camera Assembly Replacement, Separate the bottom edge adhesive: шаг 8, изображение 3 из 3
    • Don't insert your opening pick deeper than 5 mm along the bottom edge.
    • Slide your pick back and forth along the bottom edge to separate the adhesive.
    • Leave your pick inserted in the bottom right corner to prevent the adhesive from re-sealing.
  9. iPhone 15 Plus Front Camera Assembly Replacement, Heat the right edge: шаг 9, изображение 1 из 1
    • Heat the right edge of the back glass until it's hot to the touch.
  10. iPhone 15 Plus Front Camera Assembly Replacement, Separate the bottom right corner adhesive: шаг 10, изображение 1 из 3 iPhone 15 Plus Front Camera Assembly Replacement, Separate the bottom right corner adhesive: шаг 10, изображение 2 из 3 iPhone 15 Plus Front Camera Assembly Replacement, Separate the bottom right corner adhesive: шаг 10, изображение 3 из 3
    • Don't insert your pick deeper than 7 mm along the right edge.
    • Rotate your pick around the bottom right corner and slide it halfway up the right edge or until you feel a hard stop at a clip securing the back glass.
    • Don't slice near the volume buttons to avoid damaging the wireless charging cable.
    • Leave this pick inserted to prevent the adhesive from resealing.
  11. iPhone 15 Plus Front Camera Assembly Replacement, Heat the left edge: шаг 11, изображение 1 из 1
    • Heat the left edge of the back glass until it's hot to the touch.
  12. iPhone 15 Plus Front Camera Assembly Replacement, Separate the left edge adhesive: шаг 12, изображение 1 из 3 iPhone 15 Plus Front Camera Assembly Replacement, Separate the left edge adhesive: шаг 12, изображение 2 из 3 iPhone 15 Plus Front Camera Assembly Replacement, Separate the left edge adhesive: шаг 12, изображение 3 из 3
    • Don't insert your pick deeper than 5 mm along the left edge.
    • Insert a second opening pick at the bottom edge.
    • Rotate the second pick around the bottom left corner.
    • Slide this pick up to the top left corner to separate the adhesive.
  13. iPhone 15 Plus Front Camera Assembly Replacement, Heat the top edge: шаг 13, изображение 1 из 1
    • Heat the top edge of the back glass until it's hot to the touch.
  14. iPhone 15 Plus Front Camera Assembly Replacement, Separate the top edge adhesive: шаг 14, изображение 1 из 3 iPhone 15 Plus Front Camera Assembly Replacement, Separate the top edge adhesive: шаг 14, изображение 2 из 3 iPhone 15 Plus Front Camera Assembly Replacement, Separate the top edge adhesive: шаг 14, изображение 3 из 3
    • Don't insert your pick deeper than 3 mm along the top edge.
    • Rotate your second opening pick around the top left corner and slide it to the top right corner to separate the adhesive.
    • You might hear and feel clicks as the top two clips release.
    • Leave this pick in place to prevent the adhesive from resealing.
  15. iPhone 15 Plus Front Camera Assembly Replacement, Heat the top right corner: шаг 15, изображение 1 из 1
    • Heat the top right corner of the back glass until it's hot to the touch.
  16. iPhone 15 Plus Front Camera Assembly Replacement, Separate the top right corner adhesive: шаг 16, изображение 1 из 3 iPhone 15 Plus Front Camera Assembly Replacement, Separate the top right corner adhesive: шаг 16, изображение 2 из 3 iPhone 15 Plus Front Camera Assembly Replacement, Separate the top right corner adhesive: шаг 16, изображение 3 из 3
    • Don't insert your pick deeper than 4 mm along the right edge.
    • Rotate the second opening pick around the top right corner and slide it to the volume up button to separate the adhesive.
  17. iPhone 15 Plus Front Camera Assembly Replacement, Swing open the back glass: шаг 17, изображение 1 из 2 iPhone 15 Plus Front Camera Assembly Replacement, Swing open the back glass: шаг 17, изображение 2 из 2
    • Gently swing open the back glass to the right of the phone.
    • If the back glass feels stuck, go back around the perimeter to check for missed sections of adhesive or stuck clips.
    • Rest the back glass against a raised surface so it doesn't strain the cable.
  18. iPhone 15 Plus Front Camera Assembly Replacement, Unfasten the lower connector cover: шаг 18, изображение 1 из 2 iPhone 15 Plus Front Camera Assembly Replacement, Unfasten the lower connector cover: шаг 18, изображение 2 из 2
    Инструмент, используемый на этом этапе:
    FixMat
    $36.95
    • Use a tri-point Y000 driver to remove the two 1.3 mm-long screws securing the lower connector cover.
  19. iPhone 15 Plus Front Camera Assembly Replacement, Remove the lower connector cover: шаг 19, изображение 1 из 3 iPhone 15 Plus Front Camera Assembly Replacement, Remove the lower connector cover: шаг 19, изображение 2 из 3 iPhone 15 Plus Front Camera Assembly Replacement, Remove the lower connector cover: шаг 19, изображение 3 из 3
    • Use tweezers to slide the cover toward the top of the phone to unlatch it from the logic board.
    • Remove the cover.
  20. iPhone 15 Plus Front Camera Assembly Replacement: шаг 20, изображение 1 из 3 iPhone 15 Plus Front Camera Assembly Replacement: шаг 20, изображение 2 из 3 iPhone 15 Plus Front Camera Assembly Replacement: шаг 20, изображение 3 из 3
    • Hold the back glass upright with one hand and rotate the bottom edge to the left to reveal the battery press connector just below the volume buttons.
    • Use the tip of an opening pick to pry up and disconnect the battery press connector from the logic board.
    • A plus and minus sign is printed on the head of this connector.
    • To reconnect a press connector, align it over its socket and gently press down on one side until it clicks into place, then press down on the other side. Make sure it sits flat, as the insulating rubber around the sockets might prevent it from connecting fully.
  21. iPhone 15 Plus Front Camera Assembly Replacement, Remove the upper connector cover: шаг 21, изображение 1 из 3 iPhone 15 Plus Front Camera Assembly Replacement, Remove the upper connector cover: шаг 21, изображение 2 из 3 iPhone 15 Plus Front Camera Assembly Replacement, Remove the upper connector cover: шаг 21, изображение 3 из 3
    • Use your tri-point Y000 driver to remove the two 1.3 mm‑long screws securing the upper connector cover.
    • Remove the cover.
  22. iPhone 15 Plus Front Camera Assembly Replacement, Disconnect the front camera assembly: шаг 22, изображение 1 из 3 iPhone 15 Plus Front Camera Assembly Replacement, Disconnect the front camera assembly: шаг 22, изображение 2 из 3 iPhone 15 Plus Front Camera Assembly Replacement, Disconnect the front camera assembly: шаг 22, изображение 3 из 3
    • Use the tip of an opening pick to pry up and disconnect the antenna, front sensors, and front camera press connectors (three connectors in total).
  23. iPhone 15 Plus Front Camera Assembly Replacement, Remove the front camera and sensors: шаг 23, изображение 1 из 2 iPhone 15 Plus Front Camera Assembly Replacement, Remove the front camera and sensors: шаг 23, изображение 2 из 2
    • Use tweezers or your fingers to pull the front camera and sensors out of their recess in the frame and remove them.
Заключение
To reassemble your phone, follow these instructions in reverse order.
After your repair, depending on the replacement part, you may be able to calibrate it using Apple's Repair Assistant, available as of iOS 18. Update your device, navigate to Settings General About Parts & Service History, tap Restart & Finish Repair, and follow the onscreen prompts.
Еще один человек закончил это руководство.
Clay Eickemeyer
Участник с: 09/19/22
96 949 Репутация
Автор 470 руководств
Команда
Guide Team Участник Guide Team
Staff
10 членов
Автор 16 009 руководств
0 Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 5
За последние 7 дней: 35
За последние 30 дней: 110
За всё время: 1,593
