iPhone 15 Plus Loudspeaker Replacement
Выберете то, что вам нужно
  1. iPhone 15 Plus Loudspeaker Replacement, Prepare your phone for disassembly: шаг 1, изображение 1 из 2 iPhone 15 Plus Loudspeaker Replacement, Prepare your phone for disassembly: шаг 1, изображение 2 из 2
    • Allow your phone's battery to drain below 25%, as a charged lithium-ion battery is a potential safety hazard.
    • Unplug any cables from your phone.
    • Hold the power and either volume buttons and slide to power off your phone.
  2. iPhone 15 Plus Loudspeaker Replacement, Tape over any cracks: шаг 2, изображение 1 из 2 iPhone 15 Plus Loudspeaker Replacement, Tape over any cracks: шаг 2, изображение 2 из 2
    • If your screen or back glass is badly cracked, lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier.
    • Make sure there's a smooth area near the bottom edge that's big enough for a suction cup to stick to.
  3. iPhone 15 Plus Loudspeaker Replacement, Mark your opening picks: шаг 3, изображение 1 из 3 iPhone 15 Plus Loudspeaker Replacement, Mark your opening picks: шаг 3, изображение 2 из 3 iPhone 15 Plus Loudspeaker Replacement, Mark your opening picks: шаг 3, изображение 3 из 3
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
  4. iPhone 15 Plus Loudspeaker Replacement, Remove the pentalobe screws: шаг 4, изображение 1 из 1
    • Use a P2 pentalobe driver to remove the two 7.7 mm-long screws on either side of the charging port.
  5. iPhone 15 Plus Loudspeaker Replacement, Heat the bottom edge: шаг 5, изображение 1 из 1
    • Use a hair dryer or heat gun to heat the bottom edge of the back glass until it's hot to the touch.
    • Be careful not to heat the phone hotter than this—the battery is susceptible to heat damage.
  6. iPhone 15 Plus Loudspeaker Replacement, Insert an opening pick: шаг 6, изображение 1 из 3 iPhone 15 Plus Loudspeaker Replacement, Insert an opening pick: шаг 6, изображение 2 из 3 iPhone 15 Plus Loudspeaker Replacement, Insert an opening pick: шаг 6, изображение 3 из 3
    • Apply a suction handle to the bottom edge of the back glass.
    • Pull up on the handle with a strong, steady force to create a gap between the back glass and the frame.
    • Insert the tip of an opening pick into the gap.
  7. iPhone 15 Plus Loudspeaker Replacement, Back glass information: шаг 7, изображение 1 из 1
    • As you slice the adhesive securing the back glass in the next steps, be careful of the following areas:
    • There's a delicate cable connecting the back glass to the phone, right next to the volume up button. Don't insert your pick here to avoid slicing the cable.
    • There are multiple spring contacts around the perimeter of the phone. Be extra careful not to insert your pick deeper than suggested in each step to avoid bending these contacts.
  8. iPhone 15 Plus Loudspeaker Replacement, Separate the bottom edge adhesive: шаг 8, изображение 1 из 3 iPhone 15 Plus Loudspeaker Replacement, Separate the bottom edge adhesive: шаг 8, изображение 2 из 3 iPhone 15 Plus Loudspeaker Replacement, Separate the bottom edge adhesive: шаг 8, изображение 3 из 3
    • Don't insert your opening pick deeper than 5 mm along the bottom edge.
    • Slide your pick back and forth along the bottom edge to separate the adhesive.
    • Leave your pick inserted in the bottom right corner to prevent the adhesive from re-sealing.
  9. iPhone 15 Plus Loudspeaker Replacement, Heat the right edge: шаг 9, изображение 1 из 1
    • Heat the right edge of the back glass until it's hot to the touch.
  10. iPhone 15 Plus Loudspeaker Replacement, Separate the bottom right corner adhesive: шаг 10, изображение 1 из 3 iPhone 15 Plus Loudspeaker Replacement, Separate the bottom right corner adhesive: шаг 10, изображение 2 из 3 iPhone 15 Plus Loudspeaker Replacement, Separate the bottom right corner adhesive: шаг 10, изображение 3 из 3
    • Don't insert your pick deeper than 7 mm along the right edge.
    • Rotate your pick around the bottom right corner and slide it halfway up the right edge or until you feel a hard stop at a clip securing the back glass.
    • Don't slice near the volume buttons to avoid damaging the wireless charging cable.
    • Leave this pick inserted to prevent the adhesive from resealing.
  11. iPhone 15 Plus Loudspeaker Replacement, Heat the left edge: шаг 11, изображение 1 из 1
    • Heat the left edge of the back glass until it's hot to the touch.
  12. iPhone 15 Plus Loudspeaker Replacement, Separate the left edge adhesive: шаг 12, изображение 1 из 3 iPhone 15 Plus Loudspeaker Replacement, Separate the left edge adhesive: шаг 12, изображение 2 из 3 iPhone 15 Plus Loudspeaker Replacement, Separate the left edge adhesive: шаг 12, изображение 3 из 3
    • Don't insert your pick deeper than 5 mm along the left edge.
    • Insert a second opening pick at the bottom edge.
    • Rotate the second pick around the bottom left corner.
    • Slide this pick up to the top left corner to separate the adhesive.
  13. iPhone 15 Plus Loudspeaker Replacement, Heat the top edge: шаг 13, изображение 1 из 1
    • Heat the top edge of the back glass until it's hot to the touch.
  14. iPhone 15 Plus Loudspeaker Replacement, Separate the top edge adhesive: шаг 14, изображение 1 из 3 iPhone 15 Plus Loudspeaker Replacement, Separate the top edge adhesive: шаг 14, изображение 2 из 3 iPhone 15 Plus Loudspeaker Replacement, Separate the top edge adhesive: шаг 14, изображение 3 из 3
    • Don't insert your pick deeper than 3 mm along the top edge.
    • Rotate your second opening pick around the top left corner and slide it to the top right corner to separate the adhesive.
    • You might hear and feel clicks as the top two clips release.
    • Leave this pick in place to prevent the adhesive from resealing.
  15. iPhone 15 Plus Loudspeaker Replacement, Heat the top right corner: шаг 15, изображение 1 из 1
    • Heat the top right corner of the back glass until it's hot to the touch.
  16. iPhone 15 Plus Loudspeaker Replacement, Separate the top right corner adhesive: шаг 16, изображение 1 из 3 iPhone 15 Plus Loudspeaker Replacement, Separate the top right corner adhesive: шаг 16, изображение 2 из 3 iPhone 15 Plus Loudspeaker Replacement, Separate the top right corner adhesive: шаг 16, изображение 3 из 3
    • Don't insert your pick deeper than 4 mm along the right edge.
    • Rotate the second opening pick around the top right corner and slide it to the volume up button to separate the adhesive.
  17. iPhone 15 Plus Loudspeaker Replacement, Swing open the back glass: шаг 17, изображение 1 из 2 iPhone 15 Plus Loudspeaker Replacement, Swing open the back glass: шаг 17, изображение 2 из 2
    • Gently swing open the back glass to the right of the phone.
    • If the back glass feels stuck, go back around the perimeter to check for missed sections of adhesive or stuck clips.
    • Rest the back glass against a raised surface so it doesn't strain the cable.
  18. iPhone 15 Plus Loudspeaker Replacement, Unfasten the lower connector cover: шаг 18, изображение 1 из 2 iPhone 15 Plus Loudspeaker Replacement, Unfasten the lower connector cover: шаг 18, изображение 2 из 2
    Инструмент, используемый на этом этапе:
    FixMat
    $36.95
    • Use a tri-point Y000 driver to remove the two 1.3 mm-long screws securing the lower connector cover.
  19. iPhone 15 Plus Loudspeaker Replacement, Remove the lower connector cover: шаг 19, изображение 1 из 3 iPhone 15 Plus Loudspeaker Replacement, Remove the lower connector cover: шаг 19, изображение 2 из 3 iPhone 15 Plus Loudspeaker Replacement, Remove the lower connector cover: шаг 19, изображение 3 из 3
    • Use tweezers to slide the cover toward the top of the phone to unlatch it from the logic board.
    • Remove the cover.
  20. iPhone 15 Plus Loudspeaker Replacement: шаг 20, изображение 1 из 3 iPhone 15 Plus Loudspeaker Replacement: шаг 20, изображение 2 из 3 iPhone 15 Plus Loudspeaker Replacement: шаг 20, изображение 3 из 3
    • Hold the back glass upright with one hand and rotate the bottom edge to the left to reveal the battery press connector just below the volume buttons.
    • Use the tip of an opening pick to pry up and disconnect the battery press connector from the logic board.
    • A plus and minus sign is printed on the head of this connector.
    • To reconnect a press connector, align it over its socket and gently press down on one side until it clicks into place, then press down on the other side. Make sure it sits flat, as the insulating rubber around the sockets might prevent it from connecting fully.
  21. iPhone 15 Plus Loudspeaker Replacement, Unfasten the Taptic Engine connector cover: шаг 21, изображение 1 из 1
    • Use your Phillips #000 driver to remove the four screws securing the Taptic Engine and its connector cover:
    • One 1.4 mm‑long screw
    • One 1.9 mm‑long screw (larger screw head)
    • One 1.9 mm‑long screw (smaller screw head)
    • One 2.1 mm‑long screw
  22. iPhone 15 Plus Loudspeaker Replacement, Remove the cover: шаг 22, изображение 1 из 2 iPhone 15 Plus Loudspeaker Replacement, Remove the cover: шаг 22, изображение 2 из 2
    • Use tweezers to remove the Taptic Engine connector cover.
    • During reassembly, orient the cover so that its gold spring contact is closest to the edge of the frame.
  23. iPhone 15 Plus Loudspeaker Replacement, Disconnect the Taptic Engine: шаг 23, изображение 1 из 2 iPhone 15 Plus Loudspeaker Replacement, Disconnect the Taptic Engine: шаг 23, изображение 2 из 2
    • Use the point of your spudger to pry up and disconnect the Taptic Engine press connector.
  24. iPhone 15 Plus Loudspeaker Replacement, Unfasten the Taptic Engine: шаг 24, изображение 1 из 1
    Standoff Screwdriver for iPhones
    $5.49
    • Use a standoff driver to remove the 3.3 mm screw securing the top left of the Taptic Engine.
    • If you don't have a standoff driver, you may use a thin flathead driver—but be careful not to strip the shallow notches in the screw heads.
  25. iPhone 15 Plus Loudspeaker Replacement, Remove the Taptic Engine: шаг 25, изображение 1 из 2 iPhone 15 Plus Loudspeaker Replacement, Remove the Taptic Engine: шаг 25, изображение 2 из 2
    • Use tweezers or your fingers to remove the Taptic Engine.
  26. iPhone 15 Plus Loudspeaker Replacement, Unfasten the loudspeaker: шаг 26, изображение 1 из 1
    • Use your tri-point Y000 driver to remove the 1.3 mm screw securing a grounding contact and the loudspeaker.
    • Use your Phillips #000 driver to remove the four screws securing the loudspeaker:
    • Two 1.6 mm screws
    • Two 2.0 mm screws
  27. iPhone 15 Plus Loudspeaker Replacement, Remove the loudspeaker: шаг 27, изображение 1 из 2 iPhone 15 Plus Loudspeaker Replacement, Remove the loudspeaker: шаг 27, изображение 2 из 2
    • Grab the loudspeaker and remove it.
Заключение
To reassemble your phone, follow these instructions in reverse order.
Clay Eickemeyer
Участник с: 09/19/22
101 215 Репутация
Автор 471 руководств
Команда
Guide Team Участник Guide Team
Staff
10 членов
Автор 17 179 руководств
0 Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 4
За последние 7 дней: 31
За последние 30 дней: 184
За всё время: 2,370
