iPhone 15 Plus Microphone Replacement
Выберете то, что вам нужно
  1. iPhone 15 Plus Microphone Replacement, Prepare your phone for disassembly: шаг 1, изображение 1 из 2 iPhone 15 Plus Microphone Replacement, Prepare your phone for disassembly: шаг 1, изображение 2 из 2
    • Allow your phone's battery to drain below 25%, as a charged lithium-ion battery is a potential safety hazard.
    • Unplug any cables from your phone.
    • Hold the power and either volume buttons and slide to power off your phone.
    Спросите у FixBot
    Добавить комментарий
  2. iPhone 15 Plus Microphone Replacement, Tape over any cracks: шаг 2, изображение 1 из 2 iPhone 15 Plus Microphone Replacement, Tape over any cracks: шаг 2, изображение 2 из 2
    • If your screen or back glass is badly cracked, lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier.
    • Make sure there's a smooth area near the bottom edge that's big enough for a suction cup to stick to.
    Спросите у FixBot
  3. iPhone 15 Plus Microphone Replacement, Mark your opening picks: шаг 3, изображение 1 из 3 iPhone 15 Plus Microphone Replacement, Mark your opening picks: шаг 3, изображение 2 из 3 iPhone 15 Plus Microphone Replacement, Mark your opening picks: шаг 3, изображение 3 из 3
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
    Спросите у FixBot
  4. iPhone 15 Plus Microphone Replacement, Remove the pentalobe screws: шаг 4, изображение 1 из 1
    • Use a P2 pentalobe driver to remove the two 7.7 mm-long screws on either side of the charging port.
    Спросите у FixBot
  5. iPhone 15 Plus Microphone Replacement, Heat the bottom edge: шаг 5, изображение 1 из 1
    • Use a hair dryer or heat gun to heat the bottom edge of the back glass until it's hot to the touch.
    • Be careful not to heat the phone hotter than this—the battery is susceptible to heat damage.
    Спросите у FixBot
  6. iPhone 15 Plus Microphone Replacement, Insert an opening pick: шаг 6, изображение 1 из 3 iPhone 15 Plus Microphone Replacement, Insert an opening pick: шаг 6, изображение 2 из 3 iPhone 15 Plus Microphone Replacement, Insert an opening pick: шаг 6, изображение 3 из 3
    • Apply a suction handle to the bottom edge of the back glass.
    • Pull up on the handle with a strong, steady force to create a gap between the back glass and the frame.
    • Insert the tip of an opening pick into the gap.
    Спросите у FixBot
  7. iPhone 15 Plus Microphone Replacement, Back glass information: шаг 7, изображение 1 из 1
    • As you slice the adhesive securing the back glass in the next steps, be careful of the following areas:
    • There's a delicate cable connecting the back glass to the phone, right next to the volume up button. Don't insert your pick here to avoid slicing the cable.
    • There are multiple spring contacts around the perimeter of the phone. Be extra careful not to insert your pick deeper than suggested in each step to avoid bending these contacts.
    Спросите у FixBot
  8. iPhone 15 Plus Microphone Replacement, Separate the bottom edge adhesive: шаг 8, изображение 1 из 3 iPhone 15 Plus Microphone Replacement, Separate the bottom edge adhesive: шаг 8, изображение 2 из 3 iPhone 15 Plus Microphone Replacement, Separate the bottom edge adhesive: шаг 8, изображение 3 из 3
    • Don't insert your opening pick deeper than 5 mm along the bottom edge.
    • Slide your pick back and forth along the bottom edge to separate the adhesive.
    • Leave your pick inserted in the bottom right corner to prevent the adhesive from re-sealing.
    Спросите у FixBot
  9. iPhone 15 Plus Microphone Replacement, Heat the right edge: шаг 9, изображение 1 из 1
    • Heat the right edge of the back glass until it's hot to the touch.
    Спросите у FixBot
  10. iPhone 15 Plus Microphone Replacement, Separate the bottom right corner adhesive: шаг 10, изображение 1 из 3 iPhone 15 Plus Microphone Replacement, Separate the bottom right corner adhesive: шаг 10, изображение 2 из 3 iPhone 15 Plus Microphone Replacement, Separate the bottom right corner adhesive: шаг 10, изображение 3 из 3
    • Don't insert your pick deeper than 7 mm along the right edge.
    • Rotate your pick around the bottom right corner and slide it halfway up the right edge or until you feel a hard stop at a clip securing the back glass.
    • Don't slice near the volume buttons to avoid damaging the wireless charging cable.
    • Leave this pick inserted to prevent the adhesive from resealing.
    Спросите у FixBot
  11. iPhone 15 Plus Microphone Replacement, Heat the left edge: шаг 11, изображение 1 из 1
    • Heat the left edge of the back glass until it's hot to the touch.
    Спросите у FixBot
  12. iPhone 15 Plus Microphone Replacement, Separate the left edge adhesive: шаг 12, изображение 1 из 3 iPhone 15 Plus Microphone Replacement, Separate the left edge adhesive: шаг 12, изображение 2 из 3 iPhone 15 Plus Microphone Replacement, Separate the left edge adhesive: шаг 12, изображение 3 из 3
    • Don't insert your pick deeper than 5 mm along the left edge.
    • Insert a second opening pick at the bottom edge.
    • Rotate the second pick around the bottom left corner.
    • Slide this pick up to the top left corner to separate the adhesive.
    Спросите у FixBot
  13. iPhone 15 Plus Microphone Replacement, Heat the top edge: шаг 13, изображение 1 из 1
    • Heat the top edge of the back glass until it's hot to the touch.
    Спросите у FixBot
  14. iPhone 15 Plus Microphone Replacement, Separate the top edge adhesive: шаг 14, изображение 1 из 3 iPhone 15 Plus Microphone Replacement, Separate the top edge adhesive: шаг 14, изображение 2 из 3 iPhone 15 Plus Microphone Replacement, Separate the top edge adhesive: шаг 14, изображение 3 из 3
    • Don't insert your pick deeper than 3 mm along the top edge.
    • Rotate your second opening pick around the top left corner and slide it to the top right corner to separate the adhesive.
    • You might hear and feel clicks as the top two clips release.
    • Leave this pick in place to prevent the adhesive from resealing.
    Спросите у FixBot
  15. iPhone 15 Plus Microphone Replacement, Heat the top right corner: шаг 15, изображение 1 из 1
    • Heat the top right corner of the back glass until it's hot to the touch.
    Спросите у FixBot
  16. iPhone 15 Plus Microphone Replacement, Separate the top right corner adhesive: шаг 16, изображение 1 из 3 iPhone 15 Plus Microphone Replacement, Separate the top right corner adhesive: шаг 16, изображение 2 из 3 iPhone 15 Plus Microphone Replacement, Separate the top right corner adhesive: шаг 16, изображение 3 из 3
    • Don't insert your pick deeper than 4 mm along the right edge.
    • Rotate the second opening pick around the top right corner and slide it to the volume up button to separate the adhesive.
    Спросите у FixBot
  17. iPhone 15 Plus Microphone Replacement, Swing open the back glass: шаг 17, изображение 1 из 2 iPhone 15 Plus Microphone Replacement, Swing open the back glass: шаг 17, изображение 2 из 2
    • Gently swing open the back glass to the right of the phone.
    • If the back glass feels stuck, go back around the perimeter to check for missed sections of adhesive or stuck clips.
    • Rest the back glass against a raised surface so it doesn't strain the cable.
    Спросите у FixBot
  18. iPhone 15 Plus Microphone Replacement, Unfasten the lower connector cover: шаг 18, изображение 1 из 2 iPhone 15 Plus Microphone Replacement, Unfasten the lower connector cover: шаг 18, изображение 2 из 2
    Инструмент, используемый на этом этапе:
    FixMat
    $36.95
    • Use a tri-point Y000 driver to remove the two 1.3 mm-long screws securing the lower connector cover.
    Спросите у FixBot
  19. iPhone 15 Plus Microphone Replacement, Remove the lower connector cover: шаг 19, изображение 1 из 3 iPhone 15 Plus Microphone Replacement, Remove the lower connector cover: шаг 19, изображение 2 из 3 iPhone 15 Plus Microphone Replacement, Remove the lower connector cover: шаг 19, изображение 3 из 3
    • Use tweezers to slide the cover toward the top of the phone to unlatch it from the logic board.
    • Remove the cover.
    Спросите у FixBot
  20. iPhone 15 Plus Microphone Replacement: шаг 20, изображение 1 из 3 iPhone 15 Plus Microphone Replacement: шаг 20, изображение 2 из 3 iPhone 15 Plus Microphone Replacement: шаг 20, изображение 3 из 3
    • Hold the back glass upright with one hand and rotate the bottom edge to the left to reveal the battery press connector just below the volume buttons.
    • Use the tip of an opening pick to pry up and disconnect the battery press connector from the logic board.
    • A plus and minus sign is printed on the head of this connector.
    • To reconnect a press connector, align it over its socket and gently press down on one side until it clicks into place, then press down on the other side. Make sure it sits flat, as the insulating rubber around the sockets might prevent it from connecting fully.
    Спросите у FixBot
  21. iPhone 15 Plus Microphone Replacement, Unfasten the Taptic Engine connector cover: шаг 21, изображение 1 из 1
    • Use your Phillips #000 driver to remove the four screws securing the Taptic Engine and its connector cover:
    • One 1.4 mm‑long screw
    • One 1.9 mm‑long screw (larger screw head)
    • One 1.9 mm‑long screw (smaller screw head)
    • One 2.1 mm‑long screw
    Спросите у FixBot
  22. iPhone 15 Plus Microphone Replacement, Remove the cover: шаг 22, изображение 1 из 2 iPhone 15 Plus Microphone Replacement, Remove the cover: шаг 22, изображение 2 из 2
    • Use tweezers to remove the Taptic Engine connector cover.
    • During reassembly, orient the cover so that its gold spring contact is closest to the edge of the frame.
    Спросите у FixBot
  23. iPhone 15 Plus Microphone Replacement, Disconnect the Taptic Engine: шаг 23, изображение 1 из 2 iPhone 15 Plus Microphone Replacement, Disconnect the Taptic Engine: шаг 23, изображение 2 из 2
    • Use the point of your spudger to pry up and disconnect the Taptic Engine press connector.
    Спросите у FixBot
  24. iPhone 15 Plus Microphone Replacement, Unfasten the Taptic Engine: шаг 24, изображение 1 из 1
    Standoff Screwdriver for iPhones
    $5.49
    • Use a standoff driver to remove the 3.3 mm screw securing the top left of the Taptic Engine.
    • If you don't have a standoff driver, you may use a thin flathead driver—but be careful not to strip the shallow notches in the screw heads.
    Спросите у FixBot
  25. iPhone 15 Plus Microphone Replacement, Remove the Taptic Engine: шаг 25, изображение 1 из 2 iPhone 15 Plus Microphone Replacement, Remove the Taptic Engine: шаг 25, изображение 2 из 2
    • Use tweezers or your fingers to remove the Taptic Engine.
    Спросите у FixBot
  26. iPhone 15 Plus Microphone Replacement, Unfasten the loudspeaker: шаг 26, изображение 1 из 1
    • Use your tri-point Y000 driver to remove the 1.3 mm screw securing a grounding contact and the loudspeaker.
    • Use your Phillips #000 driver to remove the four screws securing the loudspeaker:
    • Two 1.6 mm screws
    • Two 2.0 mm screws
    Спросите у FixBot
  27. iPhone 15 Plus Microphone Replacement, Remove the loudspeaker: шаг 27, изображение 1 из 2 iPhone 15 Plus Microphone Replacement, Remove the loudspeaker: шаг 27, изображение 2 из 2
    • Grab the loudspeaker and remove it.
    Спросите у FixBot
  28. iPhone 15 Plus Microphone Replacement, Disconnect the microphone: шаг 28, изображение 1 из 2 iPhone 15 Plus Microphone Replacement, Disconnect the microphone: шаг 28, изображение 2 из 2
    • Use the point of your spudger to pry up and disconnect the microphone press connector.
    Спросите у FixBot
  29. iPhone 15 Plus Microphone Replacement, Unfasten the microphone: шаг 29, изображение 1 из 1
    • Use your tri-point Y000 driver to remove the 1.3 mm screw securing a grounding contact and the microphone.
    • Use your Phillips #000 driver to remove the two screws securing the right side of the microphone:
    • One 1.9 mm screw
    • One 1.3 mm screw
    • Use your standoff driver to remove the 3.2 mm standoff screw securing the top left of the microphone.
    Спросите у FixBot
  30. iPhone 15 Plus Microphone Replacement, Remove the microphone: шаг 30, изображение 1 из 3 iPhone 15 Plus Microphone Replacement, Remove the microphone: шаг 30, изображение 2 из 3 iPhone 15 Plus Microphone Replacement, Remove the microphone: шаг 30, изображение 3 из 3
    Tesa 61395 Tape
    $10.95
    • Insert the flat end of a spudger under the top right screw mount of the microphone and pry up until you can grab it with your fingers.
    • Peel the microphone from the adhesive securing it to the frame and remove it.
    • During reassembly, you may replace the adhesive that secures the microphone with thin, double-sided tape, but make sure your new adhesive doesn't block the sound cutouts.
    Спросите у FixBot
Заключение
To reassemble your phone, follow these instructions in reverse order.
Clay Eickemeyer
Участник с: 09/19/22
103 988 Репутация
Автор 476 руководств
Команда
Guide Team Участник Guide Team
Staff
10 членов
Автор 17 855 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 5
За последние 7 дней: 33
За последние 30 дней: 157
За всё время: 3,113
