iPhone 15 Plus Screen Replacement
Выберете то, что вам нужно
  1. iPhone 15 Plus Screen Replacement, Prepare your phone for disassembly: шаг 1, изображение 1 из 2 iPhone 15 Plus Screen Replacement, Prepare your phone for disassembly: шаг 1, изображение 2 из 2
    • Allow your phone's battery to drain below 25%, as a charged lithium-ion battery is a potential safety hazard.
    • Unplug any cables from your phone.
    • Hold the power and either volume buttons and slide to power off your phone.
  2. iPhone 15 Plus Screen Replacement, Tape over any cracks: шаг 2, изображение 1 из 2 iPhone 15 Plus Screen Replacement, Tape over any cracks: шаг 2, изображение 2 из 2
    • If your screen or back glass is badly cracked, lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier.
    • Make sure there's a smooth area near the bottom edge that's big enough for a suction cup to stick to.
  3. iPhone 15 Plus Screen Replacement, Mark your opening picks: шаг 3, изображение 1 из 3 iPhone 15 Plus Screen Replacement, Mark your opening picks: шаг 3, изображение 2 из 3 iPhone 15 Plus Screen Replacement, Mark your opening picks: шаг 3, изображение 3 из 3
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
    • Apple sells an Adhesive Cutter tool for cutting the display adhesive safely in their Self Repair Store.
  4. iPhone 15 Plus Screen Replacement, Remove the pentalobe screws: шаг 4, изображение 1 из 1
    • Use a P2 pentalobe driver to remove the two 7.7 mm-long screws on either side of the charging port.
  5. iPhone 15 Plus Screen Replacement, Heat the bottom edge: шаг 5, изображение 1 из 1
    • Use a hair dryer or heat gun to heat the bottom edge of the screen until it's hot to the touch.
    • Be careful not to heat the phone hotter than this—the battery is susceptible to heat damage.
  6. iPhone 15 Plus Screen Replacement, Insert an opening pick: шаг 6, изображение 1 из 3 iPhone 15 Plus Screen Replacement, Insert an opening pick: шаг 6, изображение 2 из 3 iPhone 15 Plus Screen Replacement, Insert an opening pick: шаг 6, изображение 3 из 3
    • Apply a suction handle to the bottom edge of the screen.
    • Pull up on the handle with a strong, steady force to create a gap between the screen and the frame.
    • Insert the tip of an opening pick into the gap.
  7. iPhone 15 Plus Screen Replacement, Screen information: шаг 7, изображение 1 из 2 iPhone 15 Plus Screen Replacement, Screen information: шаг 7, изображение 2 из 2
    • As you slice the adhesive securing the screen in the next steps, be careful of the following areas:
    • There are two delicate cables connecting the screen to the phone, one just above the mute switch, and the other about halfway between the volume down button and the bottom of the phone.
    • There are multiple spring contacts around the perimeter of the phone. Be extra careful not to insert your pick deeper than suggested in these locations to avoid bending the contacts.
  8. iPhone 15 Plus Screen Replacement, Separate the bottom edge adhesive: шаг 8, изображение 1 из 3 iPhone 15 Plus Screen Replacement, Separate the bottom edge adhesive: шаг 8, изображение 2 из 3 iPhone 15 Plus Screen Replacement, Separate the bottom edge adhesive: шаг 8, изображение 3 из 3
    • Don't insert your opening pick deeper than 3 mm along the bottom edge.
    • Slide your pick back and forth along the bottom edge to separate the adhesive.
    • Leave your pick inserted in the bottom right corner to prevent the adhesive from re-sealing.
  9. iPhone 15 Plus Screen Replacement, Heat the right edge: шаг 9, изображение 1 из 1
    • Heat the right edge of the screen until it's hot to the touch.
  10. iPhone 15 Plus Screen Replacement, Separate the right edge adhesive: шаг 10, изображение 1 из 3 iPhone 15 Plus Screen Replacement, Separate the right edge adhesive: шаг 10, изображение 2 из 3 iPhone 15 Plus Screen Replacement, Separate the right edge adhesive: шаг 10, изображение 3 из 3
    • Don't insert your pick deeper than 5 mm along the right edge.
    • Insert a second opening pick to the right of the first one.
    • Slide the pick along the right edge of the screen to release the clips and separate the adhesive securing it.
  11. iPhone 15 Plus Screen Replacement, Heat the top edge: шаг 11, изображение 1 из 1
    • Heat the top edge of the screen until it's hot to the touch.
  12. iPhone 15 Plus Screen Replacement, Separate the top edge adhesive: шаг 12, изображение 1 из 2 iPhone 15 Plus Screen Replacement, Separate the top edge adhesive: шаг 12, изображение 2 из 2
    • Don't insert your pick deeper than 3 mm along the top edge.
    • Insert a third opening pick in the top right corner and slide it along the top edge to release the two clips and adhesive securing it.
  13. iPhone 15 Plus Screen Replacement, Heat the left edge: шаг 13, изображение 1 из 1
    • Heat the left edge of the screen until it's hot to the touch.
  14. iPhone 15 Plus Screen Replacement, Separate the left edge adhesive: шаг 14, изображение 1 из 3 iPhone 15 Plus Screen Replacement, Separate the left edge adhesive: шаг 14, изображение 2 из 3 iPhone 15 Plus Screen Replacement, Separate the left edge adhesive: шаг 14, изображение 3 из 3
    • Don't insert your pick deeper than 3 mm along the left edge to avoid the two cables connecting the screen to the phone.
    • Slide your pick around the top left corner of the screen and along the left edge to release the clips and separate the adhesive securing it.
  15. iPhone 15 Plus Screen Replacement, Swing open the screen: шаг 15, изображение 1 из 2 iPhone 15 Plus Screen Replacement, Swing open the screen: шаг 15, изображение 2 из 2
    • Gently swing open the screen over the left edge of the phone.
    • If the screen feels stuck, go back around the perimeter to check for missed sections of adhesive or stuck clips.
    • Rest the screen against a box or similar object so it doesn't strain the cables.
  16. iPhone 15 Plus Screen Replacement, Unfasten the front sensor connector cover: шаг 16, изображение 1 из 1
    • Use a tri-point Y000 driver to remove the 0.9 mm‑long screw securing the front sensor connector cover.
  17. iPhone 15 Plus Screen Replacement, Remove the cover: шаг 17, изображение 1 из 3 iPhone 15 Plus Screen Replacement, Remove the cover: шаг 17, изображение 2 из 3 iPhone 15 Plus Screen Replacement, Remove the cover: шаг 17, изображение 3 из 3
    Инструмент, используемый на этом этапе:
    • Use tweezers to lift the cover to a 90-degree angle.
    • Unhook the cover from its slot in the logic board.
    • Remove the cover.
    • During reassembly, insert the cover at a 90-degree angle to re-engage the hook before laying it flat against the press connector.
  18. iPhone 15 Plus Screen Replacement, Disconnect the front sensor: шаг 18, изображение 1 из 2 iPhone 15 Plus Screen Replacement, Disconnect the front sensor: шаг 18, изображение 2 из 2
    • Use the tip of an opening pick to pry up and disconnect the front sensor press connector.
    • To reconnect a press connector, align it over its socket and gently press down on one side until it clicks into place, then press down on the other side.
  19. iPhone 15 Plus Screen Replacement, Unfasten the screen connector cover: шаг 19, изображение 1 из 1
    • Use your tri-point Y000 driver to remove the 0.9 mm‑long screw securing the screen connector cover.
  20. iPhone 15 Plus Screen Replacement, Remove the cover: шаг 20, изображение 1 из 3 iPhone 15 Plus Screen Replacement, Remove the cover: шаг 20, изображение 2 из 3 iPhone 15 Plus Screen Replacement, Remove the cover: шаг 20, изображение 3 из 3
    • Use tweezers to lift the cover and unlatch it from its hook on the logic board.
    • Remove the cover.
  21. iPhone 15 Plus Screen Replacement, Disconnect the screen: шаг 21, изображение 1 из 2 iPhone 15 Plus Screen Replacement, Disconnect the screen: шаг 21, изображение 2 из 2
    • Use the tip of an opening pick to pry up and disconnect the screen press connector.
  22. iPhone 15 Plus Screen Replacement, Remove the screen: шаг 22, изображение 1 из 3 iPhone 15 Plus Screen Replacement, Remove the screen: шаг 22, изображение 2 из 3 iPhone 15 Plus Screen Replacement, Remove the screen: шаг 22, изображение 3 из 3
    • Remove the screen.
    • During reassembly, use this guide to reapply adhesive and install your new screen.
    • Be careful not to damage any of the spring contacts as you clean the frame.
Заключение
To reassemble your phone, follow this guide to reapply adhesive and install your screen.
After your repair, depending on the replacement part, you may be able to calibrate it using Apple's Repair Assistant, available as of iOS 18. Update your device, navigate to Settings General About Parts & Service History, tap Restart & Finish Repair, and follow the onscreen prompts.
6 человек успешно провели ремонт по этому руководству.
Clay Eickemeyer
Участник с: 09/19/22
96 804 Репутация
Автор 466 руководств
Команда
Guide Team Участник Guide Team
Staff
10 членов
Автор 15 961 руководств
4 Комментарии к руководству
Battery still plugged in? You would need to take the back glass also
Smarterthanyou - Ответить
You actually won’t need to unplug the battery before hand. Just attach the new screen, and if the phone is still “on” do a soft reset, and the screen will start normally
Rob Preston -
Incomplete guide. No instructions for reassembly. Part ordered directly from ifixit is different than part removed. Unsure how to proceed. Refund requested
Blake Rhodenizer - Ответить
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 40
За последние 7 дней: 301
За последние 30 дней: 1,228
За всё время: 16,401
