iPhone 15 Pro Back Glass Replacement
Выберете то, что вам нужно
  1. iPhone 15 Pro Back Glass Replacement, Prepare your iPhone for disassembly: шаг 1, изображение 1 из 2 iPhone 15 Pro Back Glass Replacement, Prepare your iPhone for disassembly: шаг 1, изображение 2 из 2
    • Let your phone's battery drain below 25% before starting this repair—a charged lithium‑ion battery may catch fire if damaged.
    • Unplug all cables from your phone.
    • Hold the power and either volume button and slide to power off your phone.
  2. iPhone 15 Pro Back Glass Replacement, Tape over any cracks: шаг 2, изображение 1 из 2 iPhone 15 Pro Back Glass Replacement, Tape over any cracks: шаг 2, изображение 2 из 2
    • If your screen or back glass is cracked, lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier.
    • Make sure there's a smooth area near the bottom edge that's big enough for a suction cup to stick to.
  3. iPhone 15 Pro Back Glass Replacement, Mark your opening picks: шаг 3, изображение 1 из 3 iPhone 15 Pro Back Glass Replacement, Mark your opening picks: шаг 3, изображение 2 из 3 iPhone 15 Pro Back Glass Replacement, Mark your opening picks: шаг 3, изображение 3 из 3
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
    • Apple sells an Adhesive Cutter tool for cutting the display adhesive safely in their Self Repair Store.
  4. iPhone 15 Pro Back Glass Replacement, Remove the pentalobe screws: шаг 4, изображение 1 из 2 iPhone 15 Pro Back Glass Replacement, Remove the pentalobe screws: шаг 4, изображение 2 из 2
    • Use a P2 pentalobe screwdriver to remove the two 7 mm‑long screws on either side of the charging port.
  5. iPhone 15 Pro Back Glass Replacement, Heat the bottom edge: шаг 5, изображение 1 из 1
    • Use a hair dryer or heat gun to heat the bottom edge of the back glass until it's hot to the touch.
    • Be careful not to heat the phone hotter than this—the battery is susceptible to heat damage.
  6. iPhone 15 Pro Back Glass Replacement, Insert an opening pick: шаг 6, изображение 1 из 3 iPhone 15 Pro Back Glass Replacement, Insert an opening pick: шаг 6, изображение 2 из 3 iPhone 15 Pro Back Glass Replacement, Insert an opening pick: шаг 6, изображение 3 из 3
    • Apply a suction handle to the bottom edge of the back glass.
    • Pull up on the handle with a strong, steady force to create a gap between the back glass and the frame.
    • Insert the tip of an opening pick into the gap.
  7. iPhone 15 Pro Back Glass Replacement, Back glass information: шаг 7, изображение 1 из 1
    • As you slice the adhesive securing the back glass in the next steps, be careful of the wireless charging cable near the volume buttons.
  8. iPhone 15 Pro Back Glass Replacement, Separate the bottom edge adhesive: шаг 8, изображение 1 из 3 iPhone 15 Pro Back Glass Replacement, Separate the bottom edge adhesive: шаг 8, изображение 2 из 3 iPhone 15 Pro Back Glass Replacement, Separate the bottom edge adhesive: шаг 8, изображение 3 из 3
    • Don't insert your opening pick deeper than 5 mm along the bottom edge.
    • Slide your pick back and forth along the bottom edge to separate the adhesive.
    • Leave your pick inserted in the bottom left corner to prevent the adhesive from re-sealing.
  9. iPhone 15 Pro Back Glass Replacement, Heat the left edge: шаг 9, изображение 1 из 1
    • Heat the left edge of the back glass until it's hot to the touch.
  10. iPhone 15 Pro Back Glass Replacement, Separate the left edge adhesive: шаг 10, изображение 1 из 2 iPhone 15 Pro Back Glass Replacement, Separate the left edge adhesive: шаг 10, изображение 2 из 2
    • Don't insert your pick deeper than 5 mm along the left edge.
    • Insert a second opening pick to the left of the first one.
    • Slide this pick to the top left corner of the back glass to separate the left edge adhesive.
    • Leave this pick inserted to prevent the adhesive from resealing.
  11. iPhone 15 Pro Back Glass Replacement, Heat the top edge: шаг 11, изображение 1 из 1
    • Heat the top edge of the back glass until it's hot to the touch.
  12. iPhone 15 Pro Back Glass Replacement, Separate the top edge adhesive: шаг 12, изображение 1 из 3 iPhone 15 Pro Back Glass Replacement, Separate the top edge adhesive: шаг 12, изображение 2 из 3 iPhone 15 Pro Back Glass Replacement, Separate the top edge adhesive: шаг 12, изображение 3 из 3
    • Don't insert your pick deeper than 5 mm along the top edge.
    • Insert a third opening pick in the top left corner of the back glass.
    • Slide your pick to the top right corner to separate the top edge adhesive.
    • If the top edge of the back glass doesn't separate, the top clips may be stuck. Use the flat end of a spudger to press the clips inward until they release.
  13. iPhone 15 Pro Back Glass Replacement, Separate the top right corner adhesive: шаг 13, изображение 1 из 3 iPhone 15 Pro Back Glass Replacement, Separate the top right corner adhesive: шаг 13, изображение 2 из 3 iPhone 15 Pro Back Glass Replacement, Separate the top right corner adhesive: шаг 13, изображение 3 из 3
    • Don't slide your pick past the volume up button to avoid slicing the wireless charging cable.
    • Rotate your pick around the top right corner of the back glass.
    • Slide your pick to the volume up button.
    • Leave this pick in place to prevent the adhesive from resealing.
  14. iPhone 15 Pro Back Glass Replacement, Heat the right edge: шаг 14, изображение 1 из 1
    • Heat the right edge of the back glass until it's hot to the touch.
  15. iPhone 15 Pro Back Glass Replacement, Separate the right edge adhesive: шаг 15, изображение 1 из 3 iPhone 15 Pro Back Glass Replacement, Separate the right edge adhesive: шаг 15, изображение 2 из 3 iPhone 15 Pro Back Glass Replacement, Separate the right edge adhesive: шаг 15, изображение 3 из 3
    • Don't slide your pick past the volume down button to avoid slicing the wireless charging cable.
    • Insert a fourth opening pick at the bottom edge of the back glass.
    • Rotate your pick around the bottom right corner of the back glass.
    • Slide your pick to the volume down button.
  16. iPhone 15 Pro Back Glass Replacement, Swing open the back glass: шаг 16, изображение 1 из 3 iPhone 15 Pro Back Glass Replacement, Swing open the back glass: шаг 16, изображение 2 из 3 iPhone 15 Pro Back Glass Replacement, Swing open the back glass: шаг 16, изображение 3 из 3
    • Gently swing open the back glass over the right edge of the phone.
    • If the back glass feels stuck, go back around the perimeter to check for missed sections of adhesive or stuck clips.
    • Rest the back glass against a box or similar object so it doesn't strain the cable.
  17. iPhone 15 Pro Back Glass Replacement, Remove the wireless charging connector cover: шаг 17, изображение 1 из 3 iPhone 15 Pro Back Glass Replacement, Remove the wireless charging connector cover: шаг 17, изображение 2 из 3 iPhone 15 Pro Back Glass Replacement, Remove the wireless charging connector cover: шаг 17, изображение 3 из 3
    Инструмент, используемый на этом этапе:
    • Use a tri-point Y000 driver to remove the 1.0 mm screw securing the wireless charging connector cover.
    • Use tweezers to slide the cover out of its slot on the logic board and remove it.
  18. iPhone 15 Pro Back Glass Replacement, Disconnect the wireless charging coil: шаг 18, изображение 1 из 2 iPhone 15 Pro Back Glass Replacement, Disconnect the wireless charging coil: шаг 18, изображение 2 из 2
    • Use the tip of an opening pick to pry up and disconnect the wireless charging coil press connector.
    • To reconnect a press connector, align it over its socket and gently press down on one side until it clicks into place, then press down on the other side.
  19. iPhone 15 Pro Back Glass Replacement, Remove the back glass: шаг 19, изображение 1 из 2 iPhone 15 Pro Back Glass Replacement, Remove the back glass: шаг 19, изображение 2 из 2
    • Remove the back glass.
    • During reassembly, use this guide to reapply adhesive and install your back glass.
Заключение
To reassemble your iPhone, follow this guide to apply adhesive and install your back glass.
After your repair, depending on the replacement part, you may be able to calibrate it using Apple's Repair Assistant, available as of iOS 18. Update your device, navigate to Settings General About Parts & Service History, tap Restart & Finish Repair, and follow the onscreen prompts.
24 человек успешно провели ремонт по этому руководству.
Spencer Day
Участник с: 09/14/22
159 991 Репутация
Автор 1 045 руководств
Команда
iFixit Участник iFixit
Staff
123 членов
Автор 23 991 руководств
11 Комментарии к руководству
Dont understand why Apple used all-glueed back glass earlier.
Oleksandr Ivanov - Ответить
Is the flash camera still tied to the motherboard?
Duck - Ответить
The flash unit is glued to the back glass, along with the wireless charging coil. The rear cameras are accessible by entering through the screen.
Clay Eickemeyer -
Wo bekomme ich denn eine solche Rückseite her?
Kim Riedel - Ответить
does ifixit sell parts for this?
Meow Purr - Ответить
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 169
За последние 7 дней: 1,016
За последние 30 дней: 5,022
За всё время: 92,740
