iPhone 1st Generation Camera Replacement
Выберете то, что вам нужно
    1. iPhone 1st Generation Camera Replacement, SIM Card: шаг 1, изображение 1 из 1
      • Insert a SIM card eject tool or paper clip into the hole next to the headphone jack.
      • Press down on the paper clip until the SIM card tray pops out.
      Спросите у FixBot
      Добавить комментарий
    2. iPhone 1st Generation Camera Replacement: шаг 2, изображение 1 из 1
      • Grasp the SIM card tray and slide it out of the iPhone.
      Спросите у FixBot
    1. iPhone 1st Generation Camera Replacement, Antenna Cover: шаг 3, изображение 1 из 1
      • This image shows the two tabs and two catches located on the underside of the antenna cover. The two tabs at the top of the image must be pushed towards the black cover to release them.
      Спросите у FixBot
    2. iPhone 1st Generation Camera Replacement: шаг 4, изображение 1 из 1
      • Be sure to slide the metal spudger between the dock connector and the antenna cover, and not into the dock connector itself.
      • Insert a metal spudger into the slot between the dock connector and the antenna cover. Gently pry up near the two tabs to create a small gap between the antenna cover and the silver front bezel.
      Спросите у FixBot
    3. iPhone 1st Generation Camera Replacement: шаг 5, изображение 1 из 1
      • Insert an iPod opening tool in the gap between the antenna cover and the front bezel. The wedge of the tool should be pointing towards the antenna cover. Slide the tool around the corner and up until you reach the metal backing.
      • Repeat the same procedure on the other side of the dock connector.
      Спросите у FixBot
    4. iPhone 1st Generation Camera Replacement: шаг 6, изображение 1 из 1
      • Grasp the antenna cover on either side and slide it up and away from the iPhone. This requires some force. If it does not come free, ensure that the antenna cover is lifted up enough to free the catches.
      Спросите у FixBot
    1. iPhone 1st Generation Camera Replacement, Case: шаг 7, изображение 1 из 1
      • Remove the three Phillips #00 screws securing the rear panel to the iPhone.
      Спросите у FixBot
    2. iPhone 1st Generation Camera Replacement: шаг 8, изображение 1 из 1
      • Getting the iPhone open is a challenging feat, so don't get discouraged. Take a deep breath and make sure you have plenty of time to get the job done.
      • The small square hole is the location to insert the dental pick in the next step.
      Спросите у FixBot
    3. iPhone 1st Generation Camera Replacement: шаг 9, изображение 1 из 1
      • Start removing the rear panel on the side with the buttons.
      • Slide the dental pick completely into the square hole. You may need to wiggle the tool and apply a good amount of force to get it to go all the way.
      Спросите у FixBot
    4. iPhone 1st Generation Camera Replacement: шаг 10, изображение 1 из 1
      • Pry up the rear panel by pulling the dental pick counterclockwise in a quick motion. Apply force perpendicular to the plane of the display assembly. You may be afraid to go fast, but going slowly is more likely to bend the case.
      Спросите у FixBot
    5. iPhone 1st Generation Camera Replacement: шаг 11, изображение 1 из 1
      • Use a spudger to free the rear panel from the iPhone along the corner and top.
      Спросите у FixBot
    6. iPhone 1st Generation Camera Replacement: шаг 12, изображение 1 из 1
      • Repeat the same procedure on the other side of the iPhone. Slide the dental pick completely into the square hole. You may need to wiggle the tool and apply a good amount of force to get it to go all the way.
      Спросите у FixBot
    7. iPhone 1st Generation Camera Replacement: шаг 13, изображение 1 из 1
      • Pry up the rear panel by pulling the dental pick clockwise in a quick motion. Apply force perpendicular to the plane of the display assembly. You may be afraid to go fast, but going slowly is more likely to bend the case.
      • The rear panel is still attached to the iPhone by the headphone jack cable, so don't entirely remove the rear panel from the iPhone just yet.
      Спросите у FixBot
    8. iPhone 1st Generation Camera Replacement: шаг 14, изображение 1 из 1
      • Make sure the phone is off before disconnecting the headphone jack cable.
      • Use a spudger to disconnect the headphone jack cable from the logic board.
      Спросите у FixBot
    1. iPhone 1st Generation Camera Replacement, Camera: шаг 15, изображение 1 из 1
      • Use a spudger to disconnect the camera connector.
      Спросите у FixBot
    2. iPhone 1st Generation Camera Replacement: шаг 16, изображение 1 из 1
      • Lift the camera out of the iPhone.
      Спросите у FixBot
Заключение
29 человек успешно провели ремонт по этому руководству.
iRobot
Участник с: 09/24/09
1 Репутация
Автор 636 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 7
За последние 7 дней: 20
За последние 30 дней: 72
За всё время: 71,216
