iPhone 3GS Camera Replacement
Выберете то, что вам нужно
  1. iPhone 3GS Camera Replacement, Broken Glass: шаг 1, изображение 1 из 3 iPhone 3GS Camera Replacement, Broken Glass: шаг 1, изображение 2 из 3 iPhone 3GS Camera Replacement, Broken Glass: шаг 1, изображение 3 из 3
    • Lay overlapping strips of clear packing tape over the iPhone's display until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
    Спросите у FixBot
    Добавить комментарий
  2. iPhone 3GS Camera Replacement, Camera: шаг 2, изображение 1 из 1
    • Remove the two Phillips #00 screws from the dock-connector end of the iPhone.
    Спросите у FixBot
  3. iPhone 3GS Camera Replacement: шаг 3, изображение 1 из 1
    • Remove the metal handle from the suction cup. It's easier and safer to grip the suction cup's base instead of the metal handle.
    • There is a rubber gasket between the silver front bezel and black display assembly. A bit of force is required in this step to separate the iPhone's display assembly.
    • Be very careful when opening the iPhone so that the cables under the display are not severed.
    • Use a small suction cup near the Home button to gently pull up the bottom portion of the iPhone's display assembly.
    • If the display assembly is to damaged to allow the suction cup to adhere, tape with a strong adhesive such as duct tape maybe used.
    Спросите у FixBot
  4. iPhone 3GS Camera Replacement: шаг 4, изображение 1 из 1
    • The display assembly is still connected to the iPhone by several cables, so don't try to remove it entirely just yet.
    • Rotate the display assembly up until it is at an angle of approximately 45 degrees.
    Спросите у FixBot
  5. iPhone 3GS Camera Replacement: шаг 5, изображение 1 из 1
    • Continue to hold the display assembly with one hand, and use your other hand and a spudger to disconnect the black ribbon cable labeled "1."
    Спросите у FixBot
  6. iPhone 3GS Camera Replacement: шаг 6, изображение 1 из 1
    • Rotate the display assembly up until it is roughly vertical. This will allow easier access for disconnecting the remaining cables.
    • Use a spudger to disconnect the black ribbon cable labeled "2."
    Спросите у FixBot
  7. iPhone 3GS Camera Replacement: шаг 7, изображение 1 из 1
    • Ribbon cable "3" is held in place by an FPC style connector. Unlocking this connector is a must before removing the ribbon cable: use a plastic spudger to flip up the white plastic tab holding the remaining ribbon cable in place. The white tab will rotate up 90 degrees, releasing the ribbon cable.
    • Slide the black ribbon cable out of its connector, and remove the display assembly from the iPhone.
    Спросите у FixBot
  8. iPhone 3GS Camera Replacement: шаг 8, изображение 1 из 1
    • Insert your SIM eject tool or a paper clip into the hole next to the headphone jack.
    • Press down on the tool until the SIM card tray pops out.
    • Grasp the SIM card tray and slide it out of the iPhone.
    Спросите у FixBot
  9. iPhone 3GS Camera Replacement: шаг 9, изображение 1 из 1
    • Use a spudger to disconnect the ribbon cable labeled "4."
    Спросите у FixBot
  10. iPhone 3GS Camera Replacement: шаг 10, изображение 1 из 1
    • Use a spudger to disconnect the ribbon cable labeled "5."
    Спросите у FixBot
  11. iPhone 3GS Camera Replacement: шаг 11, изображение 1 из 2 iPhone 3GS Camera Replacement: шаг 11, изображение 2 из 2
    • Use a spudger to disconnect the ribbon cable labeled "6."
    • If you have an iPhone 3GS, refer to picture 2 and use a spudger to disconnect the ribbon cable labeled "7."
    Спросите у FixBot
  12. iPhone 3GS Camera Replacement: шаг 12, изображение 1 из 1
    • Carefully peel up the small sticker labeled "Do not remove."
    Спросите у FixBot
  13. iPhone 3GS Camera Replacement: шаг 13, изображение 1 из 1
    • Remove the following 8 screws:
    • Five 2.3 mm Phillips #00 screws with partial threads securing the logic board to the rear panel.
    • Two 2.3 mm Phillips #00 screws with full threads securing the logic board and camera.
    • One 2.9 mm Phillips #00 screw from beneath the "Do not remove" sticker.
    Спросите у FixBot
  14. iPhone 3GS Camera Replacement: шаг 14, изображение 1 из 1
    • Use a spudger to gently pry the camera up and out of its housing in the rear panel. The camera cannot be removed entirely yet because it's connected to the bottom of the logic board.
    Спросите у FixBot
  15. iPhone 3GS Camera Replacement: шаг 15, изображение 1 из 1
    • Use a spudger to gently pry up the end of the logic board closest to the dock connector.
    • If the board won't lift up, double check to make sure all the screws securing the logic board have been removed.
    Спросите у FixBot
  16. iPhone 3GS Camera Replacement: шаг 16, изображение 1 из 1
    • Slide the logic board towards the dock connector and out of the iPhone.
    Спросите у FixBot
  17. iPhone 3GS Camera Replacement: шаг 17, изображение 1 из 1
    • Use a spudger to disconnect the camera from the logic board.
    Спросите у FixBot
Заключение
75 человек успешно провели ремонт по этому руководству.
1 Комментарий к руководству
Was easier than i thought. Now have a legit phone with no camera to use at work.
tecmomike - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 16
За последние 30 дней: 65
За всё время: 77,514
