iPhone 3GS Display Assembly Replacement
Выберете то, что вам нужно
Видеообзор
    1. iPhone 3GS Display Assembly Replacement, Broken Glass: шаг 1, изображение 1 из 3 iPhone 3GS Display Assembly Replacement, Broken Glass: шаг 1, изображение 2 из 3 iPhone 3GS Display Assembly Replacement, Broken Glass: шаг 1, изображение 3 из 3
      • Lay overlapping strips of clear packing tape over the iPhone's display until the whole face is covered.
      • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
      Спросите у FixBot
      Добавить комментарий
    1. iPhone 3GS Display Assembly Replacement, Display Assembly: шаг 2, изображение 1 из 1
      • Remove the two Phillips #00 screws from the dock-connector end of the iPhone.
      Спросите у FixBot
    2. iPhone 3GS Display Assembly Replacement: шаг 3, изображение 1 из 1
      • Remove the metal handle from the suction cup. It's easier and safer to grip the suction cup's base instead of the metal handle.
      • Be very careful when opening the iPhone so that the cables under the display are not severed.
      • There is a rubber gasket between the silver front bezel and black display assembly. A bit of force is required in this step to separate the iPhone's display assembly.
      • Use a small suction cup near the Home button to gently pull up the bottom portion of the iPhone's display assembly.
      • If the display assembly is too damaged to allow the suction cup to adhere, tape with a strong adhesive such as duct tape may be used.
      Спросите у FixBot
    3. iPhone 3GS Display Assembly Replacement: шаг 4, изображение 1 из 1
      • The display assembly is still connected to the iPhone by several cables, so don't try to remove it entirely just yet.
      • Rotate the display assembly up until it is at an angle of approximately 45 degrees.
      Спросите у FixBot
    4. iPhone 3GS Display Assembly Replacement: шаг 5, изображение 1 из 1
      • Continue to hold the display assembly with one hand, and use your other hand and a spudger to disconnect the black ribbon cable labeled "1."
      Спросите у FixBot
    5. iPhone 3GS Display Assembly Replacement: шаг 6, изображение 1 из 1
      • Rotate the display assembly up until it is roughly vertical. This will allow easier access for disconnecting the remaining cables.
      • Use a spudger to disconnect the black ribbon cable labeled "2."
      Спросите у FixBot
    6. iPhone 3GS Display Assembly Replacement: шаг 7, изображение 1 из 1
      • Use a spudger to flip up the black plastic tab holding the remaining ribbon cable in place. The black will rotate up 90 degrees, releasing the ribbon cable.
      • The tab is very fragile, so be careful when flipping it up to unlock the cable and down to lock the cable.
      • The plastic tab may be white (instead of black) on some iPhone models.
      • Slide the ribbon cable out of its connector, and remove the display assembly from the iPhone.
      Спросите у FixBot
Заключение
407 человек успешно провели ремонт по этому руководству.
9 Комментарии к руководству
I had no issues taking the 3GS apart;however, putting the new screen assembly back together was a little more difficult. I can't get the new screen to 'stay flush' with the bezel. Also the 'gasket'(that runs around the length of the new assembly) keeps getting pinched and doesn't 'snap' under the bezel properly. I'm going through other procedures to see how to remedy this.
damuta - Ответить Поделиться
I did everything very simple to do for a Rookie, but the only issue I had was the screen wasn't calibrate I will type number and another number will show. I check the cables several time but no luck...anyone feel free to response...
barbara2333 - Ответить Поделиться
Replaced the dock with success, now my phone starts and does everything it should however I can't get any signal from my carrier, anybody have any suggestions other than buying a new phone!
James - Ответить Поделиться
Simple job. I made the mistake of ordering the assembly with the glass and the button and speaker in one. I'm glad I did. I have done the glass only repair, and it's a far more difficult job, to carve away the shattered shards on gorilla glass. My advice: spend a liitle extra, get the assembly with the electronics in tact, and just deal with attaching the LCD and the ribbon connections.
bearleton - Ответить Поделиться
I just received my order today and I was able to follow all of the steps with ease. And I was able to repair my iPhone 3GS in about 25 minutes. All I have to do now is charge the new battery and everything is good to go. Great guide and very easy to follow.
jtking007 - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 18
За последние 30 дней: 90
За всё время: 302,291
