iPhone 6s Plus Rear Case Replacement
Выберете то, что вам нужно
  1. iPhone 6s Plus Rear Case Replacement, Pentalobe Screws: шаг 1, изображение 1 из 1
    • Before disassembling your iPhone, discharge the battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.4 mm Pentalobe screws on either side of the Lightning port.
  2. iPhone 6s Plus Rear Case Replacement, Anti-Clamp instructions: шаг 2, изображение 1 из 3 iPhone 6s Plus Rear Case Replacement, Anti-Clamp instructions: шаг 2, изображение 2 из 3 iPhone 6s Plus Rear Case Replacement, Anti-Clamp instructions: шаг 2, изображение 3 из 3
    Инструмент, используемый на этом этапе:
    Anti-Clamp
    $24.95
    Купить
    • The next two steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
  3. iPhone 6s Plus Rear Case Replacement: шаг 3, изображение 1 из 3 iPhone 6s Plus Rear Case Replacement: шаг 3, изображение 2 из 3 iPhone 6s Plus Rear Case Replacement: шаг 3, изображение 3 из 3
    • Pull the blue handle forwards to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
    • Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait a few seconds between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next three steps.
  4. iPhone 6s Plus Rear Case Replacement, Opening Procedure: шаг 4, изображение 1 из 1
    Anti-Clamp
    $24.95
    Купить
    • If you don't have an Anti-Clamp, follow the next three steps to use a suction handle.
    • Apply mild heat to the lower edge of the iPhone using an iOpener or hair dryer for about a minute.
    • Heat softens the adhesive securing the display, making it easier to open.
  5. iPhone 6s Plus Rear Case Replacement: шаг 5, изображение 1 из 1
    • Opening the display on the 6s Plus separates a thin strip of adhesive around the perimeter of the display. If you prefer to replace the adhesive, have a set of new adhesive strips ready before you continue. It's possible to complete the repair without replacing the adhesive, and you probably won't notice any difference in functionality.
    • Apply a suction cup to the lower left corner of the display assembly.
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
  6. iPhone 6s Plus Rear Case Replacement: шаг 6, изображение 1 из 2 iPhone 6s Plus Rear Case Replacement: шаг 6, изображение 2 из 2
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case.
    • Pulling too hard may damage the display assembly. Apply just enough pressure to create a small gap between the display assembly and the rear case.
  7. iPhone 6s Plus Rear Case Replacement: шаг 7, изображение 1 из 3 iPhone 6s Plus Rear Case Replacement: шаг 7, изображение 2 из 3 iPhone 6s Plus Rear Case Replacement: шаг 7, изображение 3 из 3
    • The safest place to pry from is the notch in the front panel above the headphone jack.
    • While still maintaining pressure on the suction cup, insert the flat tip of a spudger into the gap, directly above the headphone jack.
  8. iPhone 6s Plus Rear Case Replacement: шаг 8, изображение 1 из 2 iPhone 6s Plus Rear Case Replacement: шаг 8, изображение 2 из 2
    • Twist the spudger to widen the gap between the front panel and the rear case.
  9. iPhone 6s Plus Rear Case Replacement: шаг 9, изображение 1 из 3 iPhone 6s Plus Rear Case Replacement: шаг 9, изображение 2 из 3 iPhone 6s Plus Rear Case Replacement: шаг 9, изображение 3 из 3
    • While firmly pulling up on the suction cup, slide the edge of the spudger under the bottom left corner of the display.
  10. iPhone 6s Plus Rear Case Replacement: шаг 10, изображение 1 из 2 iPhone 6s Plus Rear Case Replacement: шаг 10, изображение 2 из 2
    • Slide the tip of the spudger up the left side of the phone, between the front panel and the rear case.
  11. iPhone 6s Plus Rear Case Replacement: шаг 11, изображение 1 из 2 iPhone 6s Plus Rear Case Replacement: шаг 11, изображение 2 из 2
    • Insert the flat tip of the spudger under the right edge of the display.
    • Slide the spudger up the right side.
  12. iPhone 6s Plus Rear Case Replacement: шаг 12, изображение 1 из 2 iPhone 6s Plus Rear Case Replacement: шаг 12, изображение 2 из 2
    • Use a plastic opening tool to hold down the rear case while pulling up the suction cup to open the phone.
    • Do not remove the display completely, or you will damage the data cables connecting the display near the top edge of the iPhone.
  13. iPhone 6s Plus Rear Case Replacement: шаг 13, изображение 1 из 2 iPhone 6s Plus Rear Case Replacement: шаг 13, изображение 2 из 2
    • Pull up on the small nub on the suction cup to remove it from the display.
  14. iPhone 6s Plus Rear Case Replacement: шаг 14, изображение 1 из 3 iPhone 6s Plus Rear Case Replacement: шаг 14, изображение 2 из 3 iPhone 6s Plus Rear Case Replacement: шаг 14, изображение 3 из 3
    • Gently grasp the display assembly and lift it up to open the phone, using the clips at the top of the front panel as a hinge.
    • Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
    • Don't open the display more than 90º—it is still connected to the top of the phone by the display, digitizer, and front camera cables which can tear easily.
    • Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
    • In a pinch, you can use an unopened canned beverage to support the display.
  15. iPhone 6s Plus Rear Case Replacement, Battery Connector: шаг 15, изображение 1 из 1
    Magnetic Project Mat
    $19.95
    Купить
    • Remove two Phillips screws securing the battery connector bracket to the logic board, of the following lengths:
    • One 2.9 mm screw
    • One 2.3 mm screw
    • Throughout this guide, keep careful track of your screws so that each one goes back where it came from during reassembly. Installing a screw in the wrong place can cause permanent damage.
  16. iPhone 6s Plus Rear Case Replacement: шаг 16, изображение 1 из 2 iPhone 6s Plus Rear Case Replacement: шаг 16, изображение 2 из 2
    • Remove the battery connector bracket.
  17. iPhone 6s Plus Rear Case Replacement: шаг 17, изображение 1 из 3 iPhone 6s Plus Rear Case Replacement: шаг 17, изображение 2 из 3 iPhone 6s Plus Rear Case Replacement: шаг 17, изображение 3 из 3
    • Use a spudger or a clean fingernail to disconnect the battery connector by prying it straight up off the logic board.
  18. iPhone 6s Plus Rear Case Replacement: шаг 18, изображение 1 из 3 iPhone 6s Plus Rear Case Replacement: шаг 18, изображение 2 из 3 iPhone 6s Plus Rear Case Replacement: шаг 18, изображение 3 из 3
    • Bend the connector back to ensure it doesn't make contact and power the iPhone on while you're working on it.
  19. iPhone 6s Plus Rear Case Replacement, Display Assembly: шаг 19, изображение 1 из 1
    • Remove the following Phillips screws:
    • Three 1.3 mm screws
    • One 1.6 mm screw
    • One 3.0 mm screw
    • During reassembly, it's critical to place this 3.0 mm screw in the top-right corner of the bracket. Placing it anywhere else may damage the logic board.
  20. iPhone 6s Plus Rear Case Replacement: шаг 20, изображение 1 из 2 iPhone 6s Plus Rear Case Replacement: шаг 20, изображение 2 из 2
    • Remove the display cable bracket.
  21. iPhone 6s Plus Rear Case Replacement: шаг 21, изображение 1 из 2 iPhone 6s Plus Rear Case Replacement: шаг 21, изображение 2 из 2
    • Be careful to only pry up on the connector itself and not the socket on the logic board.
    • Use a plastic opening tool to disconnect the front-facing camera and sensor cable connector.
  22. iPhone 6s Plus Rear Case Replacement: шаг 22, изображение 1 из 2 iPhone 6s Plus Rear Case Replacement: шаг 22, изображение 2 из 2
    • Use a plastic opening tool to disconnect the digitizer cable by prying it straight up from its socket on the logic board.
    • When reconnecting the digitizer cable, do not press the center of the connector. Press one end of the connector, then press the opposite end. Pressing in the center of the connector can bend the component and cause digitizer damage.
  23. iPhone 6s Plus Rear Case Replacement: шаг 23, изображение 1 из 2 iPhone 6s Plus Rear Case Replacement: шаг 23, изображение 2 из 2
    • Make sure the battery is disconnected before you disconnect or reconnect the cable in this step.
    • Disconnect the home button/fingerprint sensor cable by prying it straight up from its socket on the logic board.
  24. iPhone 6s Plus Rear Case Replacement: шаг 24, изображение 1 из 2 iPhone 6s Plus Rear Case Replacement: шаг 24, изображение 2 из 2
  25. iPhone 6s Plus Rear Case Replacement, iSight Camera: шаг 25, изображение 1 из 3 iPhone 6s Plus Rear Case Replacement, iSight Camera: шаг 25, изображение 2 из 3 iPhone 6s Plus Rear Case Replacement, iSight Camera: шаг 25, изображение 3 из 3
    • Peel up any tape covering the iSight camera bracket screws.
  26. iPhone 6s Plus Rear Case Replacement: шаг 26, изображение 1 из 1
    • Remove the following Phillips screws over the camera bracket:
    • One 1.9 mm screw
    • One 2.4 mm screw
  27. iPhone 6s Plus Rear Case Replacement: шаг 27, изображение 1 из 2 iPhone 6s Plus Rear Case Replacement: шаг 27, изображение 2 из 2
    • Remove the iSight camera bracket.
  28. iPhone 6s Plus Rear Case Replacement: шаг 28, изображение 1 из 2 iPhone 6s Plus Rear Case Replacement: шаг 28, изображение 2 из 2
    • Disconnect the iSight camera connector from its socket on the logic board.
    • Be sure to pry up only the connector and not the socket on the logic board.
  29. iPhone 6s Plus Rear Case Replacement: шаг 29, изображение 1 из 2 iPhone 6s Plus Rear Case Replacement: шаг 29, изображение 2 из 2
    • Insert the flat end of the spudger between the iSight camera and rear casing.
    • Gently pry the camera out from its housing.
  30. iPhone 6s Plus Rear Case Replacement: шаг 30, изображение 1 из 2 iPhone 6s Plus Rear Case Replacement: шаг 30, изображение 2 из 2
    • Remove the iSight camera.
  31. iPhone 6s Plus Rear Case Replacement, SIM Tray: шаг 31, изображение 1 из 2 iPhone 6s Plus Rear Case Replacement, SIM Tray: шаг 31, изображение 2 из 2
    • Insert a SIM eject tool into the hole in the SIM tray.
    • Press to eject the SIM tray.
  32. iPhone 6s Plus Rear Case Replacement: шаг 32, изображение 1 из 1
    • Remove the SIM tray.
    • When reinserting the SIM tray, be sure to orient the tray such that the SIM eject hole is on the bottom.
  33. iPhone 6s Plus Rear Case Replacement, Logic Board: шаг 33, изображение 1 из 1
    • Remove the single 1.4 mm Phillips screw holding the NFC bracket in place.
  34. iPhone 6s Plus Rear Case Replacement: шаг 34, изображение 1 из 2 iPhone 6s Plus Rear Case Replacement: шаг 34, изображение 2 из 2
    • Remove the NFC bracket.
  35. iPhone 6s Plus Rear Case Replacement: шаг 35, изображение 1 из 1
    • Remove the two 2.7 mm Phillips screws securing the audio control cable bracket to the logic board.
  36. iPhone 6s Plus Rear Case Replacement: шаг 36, изображение 1 из 2 iPhone 6s Plus Rear Case Replacement: шаг 36, изображение 2 из 2
    • Remove the audio control cable bracket.
  37. iPhone 6s Plus Rear Case Replacement: шаг 37, изображение 1 из 2 iPhone 6s Plus Rear Case Replacement: шаг 37, изображение 2 из 2
    • Disconnect the audio control cable by prying its connector straight up from its socket on the logic board.
  38. iPhone 6s Plus Rear Case Replacement: шаг 38, изображение 1 из 2 iPhone 6s Plus Rear Case Replacement: шаг 38, изображение 2 из 2
    • Disconnect the cellular antenna cable by prying its connector straight up from its respective socket on the logic board.
  39. iPhone 6s Plus Rear Case Replacement: шаг 39, изображение 1 из 2 iPhone 6s Plus Rear Case Replacement: шаг 39, изображение 2 из 2
    • Disconnect the Wi-Fi diversity antenna cable by prying its connector up from the logic board.
  40. iPhone 6s Plus Rear Case Replacement: шаг 40, изображение 1 из 2 iPhone 6s Plus Rear Case Replacement: шаг 40, изображение 2 из 2
    • Disconnect the power button flex cable from its socket on the logic board.
  41. iPhone 6s Plus Rear Case Replacement: шаг 41, изображение 1 из 2 iPhone 6s Plus Rear Case Replacement: шаг 41, изображение 2 из 2
    • Disconnect the antenna cable by prying it up from the logic board.
  42. iPhone 6s Plus Rear Case Replacement: шаг 42, изображение 1 из 2 iPhone 6s Plus Rear Case Replacement: шаг 42, изображение 2 из 2
    • Use the flat end of a spudger to disconnect the Lightning connector flex cable from the logic board.
  43. iPhone 6s Plus Rear Case Replacement: шаг 43, изображение 1 из 3 iPhone 6s Plus Rear Case Replacement: шаг 43, изображение 2 из 3 iPhone 6s Plus Rear Case Replacement: шаг 43, изображение 3 из 3
    • Deroute the antenna cable from the two clips on the right edge of the logic board.
  44. iPhone 6s Plus Rear Case Replacement: шаг 44, изображение 1 из 2 iPhone 6s Plus Rear Case Replacement: шаг 44, изображение 2 из 2
    Standoff Screwdriver for iPhones
    $5.49
    Купить
    • Remove the following screws:
    • One 1.3 mm Phillips screw
    • One 2.6 mm Phillips screw
    • One 2.2 mm standoff screw
    • Standoff screws are best removed using a standoff screwdriver or bit.
    • In a pinch, a small flathead screwdriver will do the job—but use extra caution to ensure it doesn't slip and damage surrounding components.
  45. iPhone 6s Plus Rear Case Replacement: шаг 45, изображение 1 из 2 iPhone 6s Plus Rear Case Replacement: шаг 45, изображение 2 из 2
    • Remove the bracket.
  46. iPhone 6s Plus Rear Case Replacement: шаг 46, изображение 1 из 2 iPhone 6s Plus Rear Case Replacement: шаг 46, изображение 2 из 2
    • Deroute the upper left cellular antenna cable from the first logic board clip by nudging it out from under the clip, towards the battery.
  47. iPhone 6s Plus Rear Case Replacement: шаг 47, изображение 1 из 3 iPhone 6s Plus Rear Case Replacement: шаг 47, изображение 2 из 3 iPhone 6s Plus Rear Case Replacement: шаг 47, изображение 3 из 3
    • Continue derouting the cellular antenna cable from the second and third logic board clips.
    • Use the pointed tip of a spudger to gently pry the cellular antenna cable from the middle logic board clip.
    • Don't try to remove it by pulling on the cable, as it will tear easily.
    • In order for the cable to reach its socket on the logic board, you must route it above the logic board and underneath the audio control flex cable, as shown in the first photo.
  48. iPhone 6s Plus Rear Case Replacement: шаг 48, изображение 1 из 1
    • Remove the final 2.0 mm Phillips screw directly below the SIM card reader.
  49. iPhone 6s Plus Rear Case Replacement: шаг 49, изображение 1 из 3 iPhone 6s Plus Rear Case Replacement: шаг 49, изображение 2 из 3 iPhone 6s Plus Rear Case Replacement: шаг 49, изображение 3 из 3
    • Carefully raise—but do not remove—the logic board, lifting it from the bottom edge nearest the Lightning connector.
  50. iPhone 6s Plus Rear Case Replacement: шаг 50, изображение 1 из 3 iPhone 6s Plus Rear Case Replacement: шаг 50, изображение 2 из 3 iPhone 6s Plus Rear Case Replacement: шаг 50, изображение 3 из 3
    • Tip the logic board up to a vertical position to expose the single antenna connector on the underside, near the top edge of the board.
    • Do not attempt to fully remove the logic board yet, as the Wi-Fi/Bluetooth antenna is still connected to the underside of the board.
  51. iPhone 6s Plus Rear Case Replacement: шаг 51, изображение 1 из 2 iPhone 6s Plus Rear Case Replacement: шаг 51, изображение 2 из 2
    • Gently lay the logic board upside-down, with the top portion resting against the rear case of the iPhone.
    • Use the flat end of the spudger to disconnect the Wi-Fi/Bluetooth antenna cable from its socket on the back of the logic board.
  52. iPhone 6s Plus Rear Case Replacement: шаг 52, изображение 1 из 1
    • Remove the logic board.
  53. iPhone 6s Plus Rear Case Replacement, Speaker Assembly: шаг 53, изображение 1 из 3 iPhone 6s Plus Rear Case Replacement, Speaker Assembly: шаг 53, изображение 2 из 3 iPhone 6s Plus Rear Case Replacement, Speaker Assembly: шаг 53, изображение 3 из 3
    • Use the flat end of a spudger to peel the Lightning connector flex cable off the speaker.
  54. iPhone 6s Plus Rear Case Replacement: шаг 54, изображение 1 из 2 iPhone 6s Plus Rear Case Replacement: шаг 54, изображение 2 из 2
    • Remove the following three Phillips screws from the Taptic Engine cable bracket:
    • Two 3.5 mm screws
    • One 2.7 mm screw
  55. iPhone 6s Plus Rear Case Replacement: шаг 55, изображение 1 из 1
    • Remove the five Phillips screws securing the speaker to the rear case:
    • Two 2.7 mm screws
    • One 2.5 mm screw
    • One 1.5 mm screw
    • One 1.7 mm screw
  56. iPhone 6s Plus Rear Case Replacement: шаг 56, изображение 1 из 3 iPhone 6s Plus Rear Case Replacement: шаг 56, изображение 2 из 3 iPhone 6s Plus Rear Case Replacement: шаг 56, изображение 3 из 3
    • Deroute the Wi-Fi diversity antenna cable from its rubber sleeve.
    • If the white water damage indicator sticker makes it difficult to deroute the antenna cable, gently peel the sticker back for better access.
  57. iPhone 6s Plus Rear Case Replacement: шаг 57, изображение 1 из 2 iPhone 6s Plus Rear Case Replacement: шаг 57, изображение 2 из 2
    • Use a pair of tweezers to disconnect the Wi-Fi diversity antenna cable from the Lightning connector flex cable.
  58. iPhone 6s Plus Rear Case Replacement: шаг 58, изображение 1 из 1
    • Remove the final 2.6 mm Phillips screw securing the speaker to the rear case.
  59. iPhone 6s Plus Rear Case Replacement: шаг 59, изображение 1 из 3 iPhone 6s Plus Rear Case Replacement: шаг 59, изображение 2 из 3 iPhone 6s Plus Rear Case Replacement: шаг 59, изображение 3 из 3
    • Use the flat end of a spudger to lift the speaker assembly out of its housing.
    • Remove the speaker assembly.
  60. iPhone 6s Plus Rear Case Replacement, Lightning Connector and Headphone Jack: шаг 60, изображение 1 из 2 iPhone 6s Plus Rear Case Replacement, Lightning Connector and Headphone Jack: шаг 60, изображение 2 из 2
    • Use the point of a spudger to disconnect the Taptic Engine flex cable from the lower flex cable.
  61. iPhone 6s Plus Rear Case Replacement: шаг 61, изображение 1 из 2 iPhone 6s Plus Rear Case Replacement: шаг 61, изображение 2 из 2
    • Remove the two Phillips screws securing the Taptic Engine to the rear case:
    • One 3.1 mm screw
    • One 2.1 mm screw
    • Remove the Taptic Engine.
  62. iPhone 6s Plus Rear Case Replacement: шаг 62, изображение 1 из 2 iPhone 6s Plus Rear Case Replacement: шаг 62, изображение 2 из 2
    • Peel back the tape over the screw securing the Lightning connector flex cable to the lip of the phone.
  63. iPhone 6s Plus Rear Case Replacement: шаг 63, изображение 1 из 2 iPhone 6s Plus Rear Case Replacement: шаг 63, изображение 2 из 2
    • Remove the following five Phillips screws:
    • One 2.9 mm screw
    • One 1.9 mm screw
    • One 1.5 mm screw
    • One 1.6 mm screw
    • One 1.3 mm screw set in the bottom edge of the rear case
  64. iPhone 6s Plus Rear Case Replacement: шаг 64, изображение 1 из 1
    • Prepare an iOpener and lay it across the bottom of the phone to soften the adhesive holding the Lightning connector flex cable in place.
    • Wait about a minute for the adhesive to soften before removing the iOpener and continuing.
  65. iPhone 6s Plus Rear Case Replacement: шаг 65, изображение 1 из 3 iPhone 6s Plus Rear Case Replacement: шаг 65, изображение 2 из 3 iPhone 6s Plus Rear Case Replacement: шаг 65, изображение 3 из 3
    • Insert an opening pick under the Lightning connector flex cable and slowly slice through the adhesive holding the cable to the rear case.
  66. iPhone 6s Plus Rear Case Replacement: шаг 66, изображение 1 из 3 iPhone 6s Plus Rear Case Replacement: шаг 66, изображение 2 из 3 iPhone 6s Plus Rear Case Replacement: шаг 66, изображение 3 из 3
    • Continue sliding the opening pick underneath the flex cable.
  67. iPhone 6s Plus Rear Case Replacement: шаг 67, изображение 1 из 3 iPhone 6s Plus Rear Case Replacement: шаг 67, изображение 2 из 3 iPhone 6s Plus Rear Case Replacement: шаг 67, изображение 3 из 3
    • Use an opening pick to pry the left microphone off the edge of the rear case.
  68. iPhone 6s Plus Rear Case Replacement: шаг 68, изображение 1 из 2 iPhone 6s Plus Rear Case Replacement: шаг 68, изображение 2 из 2
    • Insert the point of a spudger into the headphone jack and wiggle it slightly to loosen the headphone jack from the bottom edge of the case.
  69. iPhone 6s Plus Rear Case Replacement: шаг 69, изображение 1 из 3 iPhone 6s Plus Rear Case Replacement: шаг 69, изображение 2 из 3 iPhone 6s Plus Rear Case Replacement: шаг 69, изображение 3 из 3
    • Remove the Lightning connector assembly.
    • If your replacement part did not come with a headphone jack gasket, use tweezers to remove the gasket from the old part and transfer it to the replacement part.
    • Before re-installation, use a spudger to scour any remaining adhesive residue from the rear case. You can use high concentration isopropyl alcohol to help with the process.
  70. iPhone 6s Plus Rear Case Replacement, Power Button Cable Assembly: шаг 70, изображение 1 из 2 iPhone 6s Plus Rear Case Replacement, Power Button Cable Assembly: шаг 70, изображение 2 из 2
    • Remove the following four Phillips screws:
    • Three 2.0 mm screws holding the power button bracket in place
    • One 1.3 mm Phillips screw over the flash and microphone bracket
  71. iPhone 6s Plus Rear Case Replacement: шаг 71, изображение 1 из 2 iPhone 6s Plus Rear Case Replacement: шаг 71, изображение 2 из 2
    • Remove the flash/microphone bracket.
  72. iPhone 6s Plus Rear Case Replacement: шаг 72, изображение 1 из 2 iPhone 6s Plus Rear Case Replacement: шаг 72, изображение 2 из 2
    • Use the pointed end of a spudger to lift the flash out of its housing in the rear case.
  73. iPhone 6s Plus Rear Case Replacement: шаг 73, изображение 1 из 2 iPhone 6s Plus Rear Case Replacement: шаг 73, изображение 2 из 2
    • Use the flat end of a spudger to peel the power button flex cable off the rear case.
  74. iPhone 6s Plus Rear Case Replacement: шаг 74, изображение 1 из 3 iPhone 6s Plus Rear Case Replacement: шаг 74, изображение 2 из 3 iPhone 6s Plus Rear Case Replacement: шаг 74, изображение 3 из 3
    • Insert the tip of a spudger underneath the microphone portion of the flex cable and gently pry it off of the rear case.
  75. iPhone 6s Plus Rear Case Replacement: шаг 75, изображение 1 из 3 iPhone 6s Plus Rear Case Replacement: шаг 75, изображение 2 из 3 iPhone 6s Plus Rear Case Replacement: шаг 75, изображение 3 из 3
    • Slide an opening pick underneath the power button flex cable to pry the cable off the rear case.
  76. iPhone 6s Plus Rear Case Replacement: шаг 76, изображение 1 из 2 iPhone 6s Plus Rear Case Replacement: шаг 76, изображение 2 из 2
    • Remove the power button flex cable.
  77. iPhone 6s Plus Rear Case Replacement, Power Button Cover: шаг 77, изображение 1 из 2 iPhone 6s Plus Rear Case Replacement, Power Button Cover: шаг 77, изображение 2 из 2
    • Gently nudge the power button cover out of its slot in the rear case.
  78. iPhone 6s Plus Rear Case Replacement: шаг 78, изображение 1 из 2 iPhone 6s Plus Rear Case Replacement: шаг 78, изображение 2 из 2
    • Remove the button cover.
  79. iPhone 6s Plus Rear Case Replacement, Rear Case: шаг 79, изображение 1 из 1
    • Remove the following screws holding the cellular antenna in place:
    • One 2.7 mm Phillips screw
    • One 1.7 mm Phillips screw
  80. iPhone 6s Plus Rear Case Replacement: шаг 80, изображение 1 из 2 iPhone 6s Plus Rear Case Replacement: шаг 80, изображение 2 из 2
    • Remove the cellular antenna.
  81. iPhone 6s Plus Rear Case Replacement: шаг 81, изображение 1 из 1
    • Remove the single 1.3 mm Phillips screw securing the Wi-Fi/Bluetooth antenna to the rear case.
  82. iPhone 6s Plus Rear Case Replacement: шаг 82, изображение 1 из 2 iPhone 6s Plus Rear Case Replacement: шаг 82, изображение 2 из 2
    • Remove the Wi-Fi/Bluetooth antenna.
  83. iPhone 6s Plus Rear Case Replacement: шаг 83, изображение 1 из 3 iPhone 6s Plus Rear Case Replacement: шаг 83, изображение 2 из 3 iPhone 6s Plus Rear Case Replacement: шаг 83, изображение 3 из 3
    • Use a pair of tweezers to peel back the tips of the three battery adhesive strips along the bottom edge of the battery.
  84. iPhone 6s Plus Rear Case Replacement: шаг 84, изображение 1 из 1
    • Gather all three tips of the battery adhesive strips in one hand.
    • Be sure to not wrinkle any of the strips during this procedure—they will become very difficult to deal with and will not straighten out again.
  85. iPhone 6s Plus Rear Case Replacement: шаг 85, изображение 1 из 3 iPhone 6s Plus Rear Case Replacement: шаг 85, изображение 2 из 3 iPhone 6s Plus Rear Case Replacement: шаг 85, изображение 3 из 3
    • Pull the adhesive strips straight out, keeping the strips flat and wide until they are completely removed. For best results, pull the strips at a 60º angle or less.
    • The strips will stretch to many times their original length. Continue pulling until you completely remove all three strips.
    • Hold down the battery with one hand as you're pulling, or the elastic strips will fling the battery from the phone once they're separated from the rear case.
  86. iPhone 6s Plus Rear Case Replacement: шаг 86, изображение 1 из 2 iPhone 6s Plus Rear Case Replacement: шаг 86, изображение 2 из 2
    Plastic Cards
    $2.99
    Купить
    • If you successfully removed all three adhesive strips, move on to the next step. Otherwise, you will need to pry the battery from the rear case.
    • Prepare an iOpener and apply it to the back of the rear case, directly over the battery. Alternatively, you can apply heat using a heat gun or hair dryer.
    • After about a minute, flip the phone over and use a plastic card to tear through any remaining adhesive.
  87. iPhone 6s Plus Rear Case Replacement: шаг 87, изображение 1 из 1
    • Remove the battery.
  88. iPhone 6s Plus Rear Case Replacement: шаг 88, изображение 1 из 1
    • Remove the three 2.4 mm Phillips screws over the audio control cable bracket.
  89. iPhone 6s Plus Rear Case Replacement: шаг 89, изображение 1 из 3 iPhone 6s Plus Rear Case Replacement: шаг 89, изображение 2 из 3 iPhone 6s Plus Rear Case Replacement: шаг 89, изображение 3 из 3
    • Use the flat end of a spudger to peel up the volume control flex cable.
  90. iPhone 6s Plus Rear Case Replacement: шаг 90, изображение 1 из 2 iPhone 6s Plus Rear Case Replacement: шаг 90, изображение 2 из 2
    • Remove the volume control flex cable.
    • During reassembly, put the volume control switch in place first, followed by the mute switch.
  91. iPhone 6s Plus Rear Case Replacement: шаг 91, изображение 1 из 3 iPhone 6s Plus Rear Case Replacement: шаг 91, изображение 2 из 3 iPhone 6s Plus Rear Case Replacement: шаг 91, изображение 3 из 3
    • Use the pointed tip of a spudger to nudge the volume control button covers out of their slots in the rear case.
  92. iPhone 6s Plus Rear Case Replacement: шаг 92, изображение 1 из 2 iPhone 6s Plus Rear Case Replacement: шаг 92, изображение 2 из 2
    • Remove the volume control button covers.
  93. iPhone 6s Plus Rear Case Replacement: шаг 93, изображение 1 из 1
    • Only the rear case remains.
Заключение
38 участников успешно повторили данное руководство.
Evan Noronha
Участник с: 02/05/15
223 523 Репутация
Автор 168 руководств
6 Комментариев
Absolutely brilliant clear instructions
i like a challenge !
whomever wrote this instruction is a star
many thx
chris
christopherfirth - Ответить
Wow Evan! This is Ashwin from bellarmine. This was done really well and it came in handy, thanks for the contribution!
Ashwin Chalaka - Ответить
perfect step by step guide.
Took me 3 hours to swap the cover.
only think that missed is the application of the adhesive for the battery and the screen.
Alphons Hermans - Ответить
Gave my broken iPhone 6s Plus a new life. Thank you!
aramis - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 22
За последние 30 дней: 75
За всё время: 39,751
