Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
Prerequisite guide only. Remove the speaker assembly from an iPhone 6S Plus.
Выберете то, что вам нужно
Power off your iPhone before beginning disassembly.
Remove the two 3.4 mm Pentalobe screws on either side of the Lightning port.
Инструмент, используемый на этом этапе:Anti-Clamp$24.95
If you don't have an Anti-Clamp, follow the next three steps to use a suction handle.
Apply mild heat to the lower edge of the iPhone using an iOpener or hair dryer for about a minute.
Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case.
The safest place to pry from is the notch in the front panel above the headphone jack.
While still maintaining pressure on the suction cup, insert the flat tip of a spudger into the gap, directly above the headphone jack.
While firmly pulling up on the suction cup, slide the edge of the spudger under the bottom left corner of the display.
Slide the tip of the spudger up the left side of the phone, between the front panel and the rear case.
Insert the flat tip of the spudger under the right edge of the display.
Slide the spudger up the right side.
Use a plastic opening tool to hold down the rear case while pulling up the suction cup to open the phone.
Gently grasp the display assembly and lift it up to open the phone, using the clips at the top of the front panel as a hinge.
Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
Инструмент, используемый на этом этапе:Magnetic Project Mat$19.95
Remove two Phillips screws securing the battery connector bracket to the logic board, of the following lengths:
One 2.9 mm screw
One 2.3 mm screw
Use a spudger or a clean fingernail to disconnect the battery connector by prying it straight up off the logic board.
Bend the connector back to ensure it doesn't make contact and power the iPhone on while you're working on it.
Remove the following Phillips screws:
Three 1.3 mm screws
One 1.6 mm screw
One 3.0 mm screw
Use a plastic opening tool to disconnect the front-facing camera and sensor cable connector.
Use a plastic opening tool to disconnect the digitizer cable by prying it straight up from its socket on the logic board.
Disconnect the home button/fingerprint sensor cable by prying it straight up from its socket on the logic board.
Remove the following Phillips screws over the camera bracket:
One 1.9 mm screw
One 2.4 mm screw
Insert the flat end of the spudger between the iSight camera and rear casing.
Gently pry the camera out from its housing.
Insert a SIM eject tool into the hole in the SIM tray.
Press to eject the SIM tray.
Remove the single 1.4 mm Phillips screw holding the NFC bracket in place.
Remove the two 2.7 mm Phillips screws securing the audio control cable bracket to the logic board.
Disconnect the audio control cable by prying its connector straight up from its socket on the logic board.
Disconnect the cellular antenna cable by prying its connector straight up from its respective socket on the logic board.
Disconnect the Wi-Fi diversity antenna cable by prying its connector up from the logic board.
Use the flat end of a spudger to disconnect the Lightning connector flex cable from the logic board.
Deroute the antenna cable from the two clips on the right edge of the logic board.
Инструмент, используемый на этом этапе:Standoff Screwdriver for iPhones$5.49
Remove the following screws:
One 1.3 mm Phillips screw
One 2.6 mm Phillips screw
One 2.2 mm standoff screw
Deroute the upper left cellular antenna cable from the first logic board clip by nudging it out from under the clip, towards the battery.
Continue derouting the cellular antenna cable from the second and third logic board clips.
Use the pointed tip of a spudger to gently pry the cellular antenna cable from the middle logic board clip.
Carefully raise—but do not remove—the logic board, lifting it from the bottom edge nearest the Lightning connector.
Tip the logic board up to a vertical position to expose the single antenna connector on the underside, near the top edge of the board.
Gently lay the logic board upside-down, with the top portion resting against the rear case of the iPhone.
Use the flat end of the spudger to disconnect the Wi-Fi/Bluetooth antenna cable from its socket on the back of the logic board.
Use the flat end of a spudger to peel the Lightning connector flex cable off the speaker.
Remove the following three Phillips screws from the Taptic Engine cable bracket:
Two 3.5 mm screws
One 2.7 mm screw
Remove the bracket.
Remove the five Phillips screws securing the speaker to the rear case:
Two 2.7 mm screws
One 2.5 mm screw
One 1.5 mm screw
One 1.7 mm screw
Deroute the Wi-Fi diversity antenna cable from its rubber sleeve.
If the white water damage indicator sticker makes it difficult to deroute the antenna cable, gently peel the sticker back for better access.
Use a pair of tweezers to disconnect the Wi-Fi diversity antenna cable from the Lightning connector flex cable.
Use the flat end of a spudger to lift the speaker assembly out of its housing.
Remove the speaker assembly.
