Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
Follow the steps in this guide to remove or replace the Pentalobe screws in an iPhone 7.
  1. Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.4 mm pentalobe screws on the bottom edge of the iPhone.
    • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
  2. SKIP THE UPGRADE
    Save by fixing with an all-in-one kit.
    Shop iPhone Fix Kits
    SKIP THE UPGRADE
Заключение
38 участников успешно повторили данное руководство.
Evan Noronha
Участник с: 05.02.2015
196 698 Репутация
Автор 178 руководств
Команда
iFixit Участник iFixit
Community
128 членов
Автор 13 120 руководств
Комментариев: 3
are there any water seals associated with the pentalobe screws? I blew compressed air into my iphone 7 and two tiny square rubber gaskets (~3mm) popped out. They squares have a round hole in them. I can only figure they are part of the pentalobe screw water seals, but I’m not sure, and I don’t know how to put them back in the phone to restore the water seal. Can anyone offer a solution?
Austin Taterka - Ответить
@ataterka The screws themselves have a tiny ring-shaped rubber gasket on them. The two rubber squares you found slip onto the screw bosses. I don’t think those are needed for water sealing, and they’re not even included on newer models.
Jeff Suovanen -
Does iPhone 7 and iPhone 8 (including «Plus» models) share the same bottom pentelope screws?
Victor Rezai - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 20
За последние 7 дней: 91
За последние 30 дней: 439
За всё время: 25,330
