iPod 1st Generation Battery Replacement
Выберете то, что вам нужно
    1. iPod 1st Generation Battery Replacement, Rear Panel: шаг 1, изображение 1 из 1
      • Before opening your iPod, ensure that the hold switch is in the locked position.
      Спросите у FixBot
      Добавить комментарий
    2. iPod 1st Generation Battery Replacement: шаг 2, изображение 1 из 1
      • Opening the iPod can be challenging; don't get discouraged if it takes you a few tries to get the iPod to open.
      • Insert a plastic iPod opening tool in the seam between the white plastic front and metal back of the iPod. It helps to hold the iPod at top and bottom as shown and squeeze to help pop out the edge. Once you've inserted the tool, run it along the seam to free the five tabs holding the iPod together.
      Спросите у FixBot
    3. iPod 1st Generation Battery Replacement: шаг 3, изображение 1 из 1
      • Continue to run the opening tool along the side of the case until all five tabs have been released.
      Спросите у FixBot
    4. iPod 1st Generation Battery Replacement: шаг 4, изображение 1 из 1
      • Work around the corner of the iPod and release the two tabs holding the iPod together near the dock connector.
      Спросите у FixBot
    5. iPod 1st Generation Battery Replacement: шаг 5, изображение 1 из 1
      • Free the five tabs holding the iPod together on the other side. You may be able to free the tabs by gently wiggling the front panel of the iPod.
      • Lift the rear panel away from the iPod.
      Спросите у FixBot
    1. iPod 1st Generation Battery Replacement, Battery: шаг 6, изображение 1 из 1
      • Lift the battery up from the adhesive holding it to the iPod.
      • Lay the battery next to the iPod (it is still connected to the logic board).
      Спросите у FixBot
    2. iPod 1st Generation Battery Replacement: шаг 7, изображение 1 из 1
      • Lift up the end of the hard drive near the Firewire port to allow easy access to the battery connector.
      Спросите у FixBot
    3. iPod 1st Generation Battery Replacement: шаг 8, изображение 1 из 1
      • Carefully disconnect the white battery connector from the logic board. Be sure to pull only on the connector itself and not on the cables.
      Спросите у FixBot
Заключение
34 человек успешно провели ремонт по этому руководству.
iRobot
Участник с: 09/24/09
1 Репутация
Автор 636 руководств
2 Комментарии к руководству
There are so many iPods, it's confusing as to what battery to buy. I have 3 of these old bricks and sure it's battery time. Can you please provide a link to the specific battery for this (above) iPod?
caseyhales - Ответить Поделиться
The iPod that I,m trying to resssurect has a connection that has 50t pin connection. I ordered the battery shown in the picture and now have to exchange it
drich92346 - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 12
За последние 7 дней: 77
За последние 30 дней: 330
За всё время: 51,867
