iPod 1st Generation Display Replacement
Выберете то, что вам нужно
  1. iPod 1st Generation Display Replacement, Rear Panel: шаг 1, изображение 1 из 1
    • Before opening your iPod, ensure that the hold switch is in the locked position.
    Спросите у FixBot
    Добавить комментарий
  2. iPod 1st Generation Display Replacement: шаг 2, изображение 1 из 1
    • Opening the iPod can be challenging; don't get discouraged if it takes you a few tries to get the iPod to open.
    • Insert a plastic iPod opening tool in the seam between the white plastic front and metal back of the iPod. It helps to hold the iPod at top and bottom as shown and squeeze to help pop out the edge. Once you've inserted the tool, run it along the seam to free the five tabs holding the iPod together.
    Спросите у FixBot
  3. iPod 1st Generation Display Replacement: шаг 3, изображение 1 из 1
    • Continue to run the opening tool along the side of the case until all five tabs have been released.
    Спросите у FixBot
  4. iPod 1st Generation Display Replacement: шаг 4, изображение 1 из 1
    • Work around the corner of the iPod and release the two tabs holding the iPod together near the dock connector.
    Спросите у FixBot
  5. iPod 1st Generation Display Replacement: шаг 5, изображение 1 из 1
    • Free the five tabs holding the iPod together on the other side. You may be able to free the tabs by gently wiggling the front panel of the iPod.
    • Lift the rear panel away from the iPod.
    Спросите у FixBot
  6. iPod 1st Generation Display Replacement, Hard Drive: шаг 6, изображение 1 из 1
    • Lift the battery up from the adhesive holding it to the iPod.
    • Lay the battery next to the iPod (it is still connected to the logic board).
    Спросите у FixBot
  7. iPod 1st Generation Display Replacement: шаг 7, изображение 1 из 1
    • Carefully disconnect the orange ribbon cable from the hard drive.
    • If the cable doesn't come free easily, it may be helpful to gently wiggle the cable from side to side.
    • Lift the hard drive out of the iPod.
    Спросите у FixBot
  8. iPod 1st Generation Display Replacement, Display: шаг 8, изображение 1 из 1
    • Carefully disconnect the white battery connector from the logic board. Be sure to pull only on the connector itself and not on the cables.
    Спросите у FixBot
  9. iPod 1st Generation Display Replacement: шаг 9, изображение 1 из 1
    • Peel up the gray rubber bumper near the hard drive ribbon to reveal the T6 Torx screw beneath.
    • Remove the newly revealed T6 Torx screw.
    Спросите у FixBot
  10. iPod 1st Generation Display Replacement: шаг 10, изображение 1 из 1
    • Remove the 3 remaining T6 Torx screws from the logic board.
    Спросите у FixBot
  11. iPod 1st Generation Display Replacement: шаг 11, изображение 1 из 1
    • Slide the logic board away from the port end of the casing and lift it out of the iPod.
    Спросите у FixBot
  12. iPod 1st Generation Display Replacement: шаг 12, изображение 1 из 1
    • Note the location of the four white plastic tabs securing the display to the logic board. These tabs must be released before the display can be removed.
    Спросите у FixBot
  13. iPod 1st Generation Display Replacement: шаг 13, изображение 1 из 1
    • Use a spudger or your finger to free the four white plastic tabs indicated in the previous picture.
    Спросите у FixBot
  14. iPod 1st Generation Display Replacement: шаг 14, изображение 1 из 1
    • Use a spudger to carefully disconnect the display ribbon cable from beneath the scroll wheel.
    Спросите у FixBot
Заключение
Еще один человек закончил это руководство.
iRobot
Участник с: 09/24/09
1 Репутация
Автор 636 руководств
2 Комментарии к руководству
How do you connect new display screen?
tiarana_senele - Ответить Поделиться
iPod 初代のディスプレイは第2世代のディスプレイと全く同じものですか?
ryu mym - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 21
За последние 30 дней: 75
За всё время: 11,117
