iPod 1st Generation Front Panel Replacement
Выберете то, что вам нужно
    1. iPod 1st Generation Front Panel Replacement, Rear Panel: шаг 1, изображение 1 из 1
      • Before opening your iPod, ensure that the hold switch is in the locked position.
      Спросите у FixBot
      Добавить комментарий
    2. iPod 1st Generation Front Panel Replacement: шаг 2, изображение 1 из 1
      • Opening the iPod can be challenging; don't get discouraged if it takes you a few tries to get the iPod to open.
      • Insert a plastic iPod opening tool in the seam between the white plastic front and metal back of the iPod. It helps to hold the iPod at top and bottom as shown and squeeze to help pop out the edge. Once you've inserted the tool, run it along the seam to free the five tabs holding the iPod together.
      Спросите у FixBot
    3. iPod 1st Generation Front Panel Replacement: шаг 3, изображение 1 из 1
      • Continue to run the opening tool along the side of the case until all five tabs have been released.
      Спросите у FixBot
    4. iPod 1st Generation Front Panel Replacement: шаг 4, изображение 1 из 1
      • Work around the corner of the iPod and release the two tabs holding the iPod together near the dock connector.
      Спросите у FixBot
    5. iPod 1st Generation Front Panel Replacement: шаг 5, изображение 1 из 1
      • Free the five tabs holding the iPod together on the other side. You may be able to free the tabs by gently wiggling the front panel of the iPod.
      • Lift the rear panel away from the iPod.
      Спросите у FixBot
    1. iPod 1st Generation Front Panel Replacement, Hard Drive: шаг 6, изображение 1 из 1
      • Lift the battery up from the adhesive holding it to the iPod.
      • Lay the battery next to the iPod (it is still connected to the logic board).
      Спросите у FixBot
    2. iPod 1st Generation Front Panel Replacement: шаг 7, изображение 1 из 1
      • Carefully disconnect the orange ribbon cable from the hard drive.
      • If the cable doesn't come free easily, it may be helpful to gently wiggle the cable from side to side.
      • Lift the hard drive out of the iPod.
      Спросите у FixBot
    1. iPod 1st Generation Front Panel Replacement, Front Panel: шаг 8, изображение 1 из 1
      • Carefully disconnect the white battery connector from the logic board. Be sure to pull only on the connector itself and not on the cables.
      Спросите у FixBot
    2. iPod 1st Generation Front Panel Replacement: шаг 9, изображение 1 из 1
      • Peel up the gray rubber bumper near the hard drive ribbon to reveal the T6 Torx screw beneath.
      • Remove the newly revealed T6 Torx screw.
      Спросите у FixBot
    3. iPod 1st Generation Front Panel Replacement: шаг 10, изображение 1 из 1
      • Remove the 3 remaining T6 Torx screws from the logic board.
      Спросите у FixBot
    4. iPod 1st Generation Front Panel Replacement: шаг 11, изображение 1 из 1
      • Slide the logic board away from the port end of the casing and lift it out of the iPod.
      Спросите у FixBot
    5. iPod 1st Generation Front Panel Replacement: шаг 12, изображение 1 из 1
      • Front panel remains.
      Спросите у FixBot
Заключение
3 человек успешно провели ремонт по этому руководству.
iRobot
Участник с: 09/24/09
1 Репутация
Автор 636 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 10
За последние 30 дней: 50
За всё время: 7,932
