iPod 2nd Generation Front Panel Replacement
Выберете то, что вам нужно
  1. iPod 2nd Generation Front Panel Replacement, Rear Panel: шаг 1, изображение 1 из 1
    • Before opening your iPod, ensure that the hold switch is in the locked position.
    Спросите у FixBot
    Добавить комментарий
  2. iPod 2nd Generation Front Panel Replacement: шаг 2, изображение 1 из 1
    • Opening the iPod can be challenging. Don't get discouraged if it takes a few tries before the iPod is opened.
    • Insert a plastic iPod opening tool in the seam between the white plastic front and metal back of the iPod. Once you've inserted the tool, run it along the seam to free the five tabs holding the iPod together.
    Спросите у FixBot
  3. iPod 2nd Generation Front Panel Replacement: шаг 3, изображение 1 из 1
    • Continue to run the opening tool along the side of the case until all five tabs have been released.
    Спросите у FixBot
  4. iPod 2nd Generation Front Panel Replacement: шаг 4, изображение 1 из 1
    • Work around the corner of the iPod and release the two tabs holding the iPod together near the dock connector.
    Спросите у FixBot
  5. iPod 2nd Generation Front Panel Replacement: шаг 5, изображение 1 из 1
    • Free the five tabs holding the iPod together on the other side. You may be able to free the tabs by gently wiggling the front panel of the iPod.
    Спросите у FixBot
  6. iPod 2nd Generation Front Panel Replacement: шаг 6, изображение 1 из 1
    • Lift the rear panel away from the iPod, making sure it doesn't catch on the headphone jack.
    Спросите у FixBot
  7. iPod 2nd Generation Front Panel Replacement, Hard Drive: шаг 7, изображение 1 из 1
    • Peel up the metallic tape attached to the top of the battery.
    Спросите у FixBot
  8. iPod 2nd Generation Front Panel Replacement: шаг 8, изображение 1 из 1
    • Lift the battery up from the hard drive and lay it next the the iPod (it is still connected to the logic board).
    Спросите у FixBot
  9. iPod 2nd Generation Front Panel Replacement: шаг 9, изображение 1 из 1
    • Carefully disconnect the orange ribbon cable from the hard drive.
    • If the cable doesn't come free easily, it may be helpful to gently wiggle the cable from side to side.
    • Lift the hard drive out of the iPod.
    Спросите у FixBot
  10. iPod 2nd Generation Front Panel Replacement, Hard Drive Cable: шаг 10, изображение 1 из 1
    • For the following step, you only need to move the locking bar about 2 mm. Pushing too hard or too far will damage the connector.
    • Loosen the connector by pulling the brown locking bar toward the hard drive cable using the tips of your fingers.
    Спросите у FixBot
  11. iPod 2nd Generation Front Panel Replacement: шаг 11, изображение 1 из 1
    • Slide the hard drive cable out of its connector.
    Спросите у FixBot
  12. iPod 2nd Generation Front Panel Replacement, Touch Wheel: шаг 12, изображение 1 из 1
    • Lift the blue hard drive mounting bracket out of the iPod.
    Спросите у FixBot
  13. iPod 2nd Generation Front Panel Replacement: шаг 13, изображение 1 из 1
    • Carefully disconnect the white battery connector from the logic board. Be sure to pull only on the connector itself and not on the cables.
    Спросите у FixBot
  14. iPod 2nd Generation Front Panel Replacement: шаг 14, изображение 1 из 1
    • Like the hard drive connector, for the following step, you only need to move the connector about 2 mm. Pushing too hard or too far will damage the connector.
    • Loosen the touch wheel connector by pulling the brown locking bar toward the side of the iPod using the tips of your fingers.
    Спросите у FixBot
  15. iPod 2nd Generation Front Panel Replacement: шаг 15, изображение 1 из 1
    • Reove the 8 T6 Torx screws from the logic board.
    Спросите у FixBot
  16. iPod 2nd Generation Front Panel Replacement: шаг 16, изображение 1 из 1
    • Lift the logic board up enough to disconnect the orange touch wheel cable.
    • Lift the logic board out of the iPod.
    Спросите у FixBot
  17. iPod 2nd Generation Front Panel Replacement: шаг 17, изображение 1 из 1
    • Lift the touch wheel out of the front panel
    Спросите у FixBot
  18. iPod 2nd Generation Front Panel Replacement, Front Panel: шаг 18, изображение 1 из 1
    • Front panel remains.
    Спросите у FixBot
Заключение
2 человек успешно провели ремонт по этому руководству.
iRobot
Участник с: 09/24/09
1 Репутация
Автор 636 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 10
За последние 30 дней: 46
За всё время: 4,631
