iPod 2nd Generation Hard Drive Replacement
Выберете то, что вам нужно
    1. iPod 2nd Generation Hard Drive Replacement, Rear Panel: шаг 1, изображение 1 из 1
      • Before opening your iPod, ensure that the hold switch is in the locked position.
      Спросите у FixBot
      Добавить комментарий
    2. iPod 2nd Generation Hard Drive Replacement: шаг 2, изображение 1 из 1
      • Opening the iPod can be challenging. Don't get discouraged if it takes a few tries before the iPod is opened.
      • Insert a plastic iPod opening tool in the seam between the white plastic front and metal back of the iPod. Once you've inserted the tool, run it along the seam to free the five tabs holding the iPod together.
      Спросите у FixBot
    3. iPod 2nd Generation Hard Drive Replacement: шаг 3, изображение 1 из 1
      • Continue to run the opening tool along the side of the case until all five tabs have been released.
      Спросите у FixBot
    4. iPod 2nd Generation Hard Drive Replacement: шаг 4, изображение 1 из 1
      • Work around the corner of the iPod and release the two tabs holding the iPod together near the dock connector.
      Спросите у FixBot
    5. iPod 2nd Generation Hard Drive Replacement: шаг 5, изображение 1 из 1
      • Free the five tabs holding the iPod together on the other side. You may be able to free the tabs by gently wiggling the front panel of the iPod.
      Спросите у FixBot
    6. iPod 2nd Generation Hard Drive Replacement: шаг 6, изображение 1 из 1
      • Lift the rear panel away from the iPod, making sure it doesn't catch on the headphone jack.
      Спросите у FixBot
    1. iPod 2nd Generation Hard Drive Replacement, Hard Drive: шаг 7, изображение 1 из 1
      • Peel up the metallic tape attached to the top of the battery.
      Спросите у FixBot
    2. iPod 2nd Generation Hard Drive Replacement: шаг 8, изображение 1 из 1
      • Lift the battery up from the hard drive and lay it next the the iPod (it is still connected to the logic board).
      Спросите у FixBot
    3. iPod 2nd Generation Hard Drive Replacement: шаг 9, изображение 1 из 1
      • Carefully disconnect the orange ribbon cable from the hard drive.
      • If the cable doesn't come free easily, it may be helpful to gently wiggle the cable from side to side.
      • Lift the hard drive out of the iPod.
      Спросите у FixBot
Заключение
2 человек успешно провели ремонт по этому руководству.
iRobot
Участник с: 09/24/09
1 Репутация
Автор 635 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 15
За последние 30 дней: 91
За всё время: 19,576
