iPod Mini Casing Replacement
Выберете то, что вам нужно
    1. iPod Mini Casing Replacement, Top Bezel: шаг 1, изображение 1 из 1
      • Before opening your iPod, ensure that the hold switch is in the locked position.
      Спросите у FixBot
      Добавить комментарий
    2. iPod Mini Casing Replacement: шаг 2, изображение 1 из 1
      Инструмент, используемый на этом этапе:
      Jimmy
      $7.95
      • Carefully insert a small flathead screwdriver or Jimmy in the seam between the metal casing and white plastic top. Use the screwdriver to pry up the white plastic top bezel. Be careful not to damage the soft plastic with your screwdriver.
      • The top bezel is held on with an adhesive, so it may be necessary to pry up in several different locations to free the part.
      • To make this job easier, heat up the adhesive with a hairdryer on low heat for a few seconds.
      Спросите у FixBot
    3. iPod Mini Casing Replacement: шаг 3, изображение 1 из 1
      • Lift the top bezel off of the iPod.
      Спросите у FixBot
    1. iPod Mini Casing Replacement, Bottom Bezel: шаг 4, изображение 1 из 1
      Jimmy
      $7.95
      • Carefully insert a small flathead screwdriver or Jimmy in the seam between the metal casing and white plastic bottom Use the screwdriver to pry up the white plastic bottom bezel. Be careful not to damage the soft plastic with your screwdriver.
      Спросите у FixBot
    2. iPod Mini Casing Replacement: шаг 5, изображение 1 из 1
      • A small pair of snap ring pliers is the easiest tool to remove the metal retaining bracket.
      • You can also use a flathead screwdriver to pry out the metal retaining bracket beneath the bottom bezel as shown. You can free the bracket by first pushing in the metal arms on the corners and then lifting the bracket.
      Спросите у FixBot
    3. iPod Mini Casing Replacement: шаг 6, изображение 1 из 1
      • Lift the metal retaining bracket out of the iPod.
      Спросите у FixBot
    1. iPod Mini Casing Replacement, Casing: шаг 7, изображение 1 из 1
      • Use a spudger or the tip of your finger to carefully disconect the orange click wheel ribbon from the logic board.
      Спросите у FixBot
    2. iPod Mini Casing Replacement: шаг 8, изображение 1 из 1
      • Remove the two #00 Phillips screws securing the headphone jack to the casing.
      Спросите у FixBot
    3. iPod Mini Casing Replacement: шаг 9, изображение 1 из 1
      • Carefully slide the iPod out of its casing by pushing on the logic board near the bottom edge of the click wheel.
      • Do not pull on the headphone jack board at the top of the iPod, as the connector to the logic board is fragile.
      Спросите у FixBot
    4. iPod Mini Casing Replacement: шаг 10, изображение 1 из 1
      • After pushing the logic board out sufficiently, gently grasp the logic board on either side of the display, and continue to slide the iPod out of its casing.
      Спросите у FixBot
    5. iPod Mini Casing Replacement: шаг 11, изображение 1 из 1
      • Use a spudger to pull back on the small black plastic tab holding the click wheel in place.
      Спросите у FixBot
    6. iPod Mini Casing Replacement: шаг 12, изображение 1 из 1
      • Continue to pull back on the black plastic tab and use your other hand to press down on the click wheel and begin to slide it out of the iPod.
      • It's important to press down on the click wheel as you slide it out, otherwise the click wheel could be scratched by the iPod's metal casing.
      Спросите у FixBot
    7. iPod Mini Casing Replacement: шаг 13, изображение 1 из 1
      • Continue to slide the click wheel out until it is free of the iPod.
      Спросите у FixBot
    8. iPod Mini Casing Replacement: шаг 14, изображение 1 из 1
      • Exterior casing remains.
      Спросите у FixBot
Заключение
24 человек успешно провели ремонт по этому руководству.
iRobot
Участник с: 09/24/09
1 Репутация
Автор 635 руководств
4 Комментарии к руководству
Followed your instructions to the letter. Put it back together and now it won't work . Thanks for breaking my iPod mini.
kolbyhardy - Ответить Поделиться
You probably &&^&@@ something up by mistake. Don’t blame the author for your own mistakes.
Crystal Haugh - Ответить Поделиться
dude the pod mini is an mp3 player from 2005 it literally does not matter, plus, you probably &&^&@@ up the repair anyways
Memez_idk - Ответить Поделиться
@kolbyhardy He didn't touch your ipod mini. Anything you did to it is YOUR fault, not anyone else's, own your mistakes.
Cactus12 - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 10
За последние 7 дней: 29
За последние 30 дней: 149
За всё время: 30,923
