iPod Mini Headphone Jack Board Replacement
Выберете то, что вам нужно
    1. iPod Mini Headphone Jack Board Replacement, Top Bezel: шаг 1, изображение 1 из 1
      • Before opening your iPod, ensure that the hold switch is in the locked position.
      Спросите у FixBot
      Добавить комментарий
    2. iPod Mini Headphone Jack Board Replacement: шаг 2, изображение 1 из 1
      Инструмент, используемый на этом этапе:
      Jimmy
      $7.95
      • Carefully insert a small flathead screwdriver or Jimmy in the seam between the metal casing and white plastic top. Use the screwdriver to pry up the white plastic top bezel. Be careful not to damage the soft plastic with your screwdriver.
      • The top bezel is held on with an adhesive, so it may be necessary to pry up in several different locations to free the part.
      • To make this job easier, heat up the adhesive with a hairdryer on low heat for a few seconds.
      Спросите у FixBot
    3. iPod Mini Headphone Jack Board Replacement: шаг 3, изображение 1 из 1
      • Lift the top bezel off of the iPod.
      Спросите у FixBot
    1. iPod Mini Headphone Jack Board Replacement, Bottom Bezel: шаг 4, изображение 1 из 1
      Jimmy
      $7.95
      • Carefully insert a small flathead screwdriver or Jimmy in the seam between the metal casing and white plastic bottom Use the screwdriver to pry up the white plastic bottom bezel. Be careful not to damage the soft plastic with your screwdriver.
      Спросите у FixBot
    2. iPod Mini Headphone Jack Board Replacement: шаг 5, изображение 1 из 1
      • A small pair of snap ring pliers is the easiest tool to remove the metal retaining bracket.
      • You can also use a flathead screwdriver to pry out the metal retaining bracket beneath the bottom bezel as shown. You can free the bracket by first pushing in the metal arms on the corners and then lifting the bracket.
      Спросите у FixBot
    3. iPod Mini Headphone Jack Board Replacement: шаг 6, изображение 1 из 1
      • Lift the metal retaining bracket out of the iPod.
      Спросите у FixBot
    1. iPod Mini Headphone Jack Board Replacement, Headphone Jack Board: шаг 7, изображение 1 из 1
      • Use a spudger or the tip of your finger to carefully disconect the orange click wheel ribbon from the logic board.
      Спросите у FixBot
    2. iPod Mini Headphone Jack Board Replacement: шаг 8, изображение 1 из 1
      • Remove the two #00 Phillips screws securing the headphone jack to the casing.
      Спросите у FixBot
    3. iPod Mini Headphone Jack Board Replacement: шаг 9, изображение 1 из 1
      • Carefully slide the iPod out of its casing by pushing on the logic board near the bottom edge of the click wheel.
      • Do not pull on the headphone jack board at the top of the iPod, as the connector to the logic board is fragile.
      Спросите у FixBot
    4. iPod Mini Headphone Jack Board Replacement: шаг 10, изображение 1 из 1
      • After pushing the logic board out sufficiently, gently grasp the logic board on either side of the display, and continue to slide the iPod out of its casing.
      Спросите у FixBot
    5. iPod Mini Headphone Jack Board Replacement: шаг 11, изображение 1 из 1
      • Lift the battery off of the logic board and lay it to the side of the iPod.
      Спросите у FixBot
    6. iPod Mini Headphone Jack Board Replacement: шаг 12, изображение 1 из 1
      • Use a spudger to carefully pry up the headphone jack board from the logic board. Be careful to pry up near the connector to prevent unnecessary strain on the board.
      • Lift the headphone jack board off of the logic board.
      Спросите у FixBot
Заключение
15 человек успешно провели ремонт по этому руководству.
iRobot
Участник с: 09/24/09
1 Репутация
Автор 635 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 10
За последние 7 дней: 48
За последние 30 дней: 139
За всё время: 30,508
